Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 12-28-2008, 09:51 AM   #3136
aplusmiami is an unknown quantity at this point
John - Sorry for your loss. Condolences to you & your family.
aplusmiami is offline   Reply With Quote
Old 12-28-2008, 09:52 AM   #3137
Top Spectrum ovelay in Music Player
Is there a text file explaining the "How to do this"
Old 12-28-2008, 04:03 PM   #3138
Dougw133 is an unknown quantity at this point
Just got a new system up and running.
My problem is that when I allocate a button for "HD Radio" when I press it, nothing happens. It doesn't load the HDradio.skin or anything. I checked the Exectblb.ini and where the button is (HD Radio 31) it just says "Radio". It doesn't have anything commanded to load. I saved my old INI and I can't seem to fins a difference. Any ideas?
Dougw133 is offline   Reply With Quote
Old 12-28-2008, 06:02 PM   #3139
assuming you hve the latest version of RR this is how I git it working.
Under the hdradio dir run the runme1st.cmd to register the dlls
Run rrconfig. Select Radio and set the HD Radio COM port.
Old 12-28-2008, 09:02 PM   #3140
jessekilner's Avatar
jessekilner is an unknown quantity at this point
I was checking out the coverJUke.. is it possible to get this to appear where the flash is located in the menu.skin? This is a cool feature in the perfect location. Anyone play with this in DFX yet?
Did it.. Done it... now I got to keep the neighbors kids away!!
jessekilner is offline   Reply With Quote
Old 12-28-2008, 09:16 PM   #3141
Yeah I did that...It's not actually hooked up to the HD radio yet though. I figured even without the radio hooked it should at least go into the radio skin. The button does nothing though.
Old 12-28-2008, 09:31 PM   #3142
the button should mine does and i dont have no radio tuner or anything hooked to it..
Old 12-29-2008, 12:21 AM   #3143
bemenaker's Avatar
bemenaker is on a distinguished road
I have the Visteon radio, and the normal Radio skin works just fine for controlling it. What's different about the HDRadio skin?
bemenaker is offline   Reply With Quote
Old 12-29-2008, 03:19 AM   #3144
kyjoe is on a distinguished road
How to do the spectrum analyzer..Its in the DFX helper files.......Roadrunner/skins/DFX4/Helper files/DigitalFX Help....
kyjoe is offline   Reply With Quote
Old 12-29-2008, 06:55 AM   #3145
micutu is an unknown quantity at this point
hi, nice skin, however, i am using for video mediaplayer clasic, and when waching a video,the eq function is good, but without the winamp mixer setting
micutu is offline   Reply With Quote
Old 12-29-2008, 09:05 AM   #3146
That's what I am talking about. He has nothing hooked to it yet when presses the button it goes to the skin.
I have the visteon as well, which is HD. When you are choosing the button in the button selector in the skin, there is a button for "HDRadio".
Mine does not function.
Old 12-29-2008, 09:20 AM   #3147
utd09bry's Avatar
utd09bry is an unknown quantity at this point
Did you try just changing "Radio" to "HD Radio" in your Exectbl for that button?
In mine... the button in MyApps that calls for it uses an "HD Radio" label.
I don't have mine hooked up anymore, so I can't test any of this... but I would try that
utd09bry is offline   Reply With Quote
Old 12-29-2008, 04:48 PM   #3148
Mine would not until it detected a radio was connected
Old 12-29-2008, 06:41 PM   #3149
fixerofallthing's Avatar
fixerofallthing is on a distinguished road
If you set the HDradio port to -1 it puts it in test mode and will launch the radio skin without the hardware present.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Old 12-29-2008, 07:45 PM   #3150
Well it's connected and set up correclt yas far as I can tell...I installed it before so I don't see what the problem is. The Skin still does NOTHING when I press the HD Radio button in the main menu of DFX4...Could someone post their Exectbl.ini so I can compare please? Also, when RR starts up I here the radio initialize and trun on, and then their is a pop in my speakers which never happened before, as if the line wasn't muted....
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
