Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 01-06-2009, 12:15 AM   #3196
Minoritydan is an unknown quantity at this point
Quote: Originally Posted by Blue ZX3 View Post
Adding media to winamps library does nothing for the RRMedia plugin, this would just allow you to browse WA's library while using the old audio browser.
See above explanation...
Thanks blue.
I guess I'll just try to manually delete the playlists I have and see how that works out.
I seem to recall selecting a directory with a couple of gigs of music, then doing an "add selected" to put all of the files in a playlist. Then I browsed the full screen playlist and thats when I first noticed that I could not change to another mp3 file. I tried in the full screen playlist window to do it and from there I can't change mp3's at all without exiting and restarting RR.
So I guess tomorrow I'll start with deleting the playlists and see if that helps.
Minoritydan is offline   Reply With Quote
Old 01-06-2009, 01:57 AM   #3197
silvi4000 is an unknown quantity at this point
Quote: Originally Posted by Moby58 View Post
What processor/speed is your car computer? Mine is a 1gig and bogs down if running anything with flash.
Thanks for the comment but if speed were the issue, then exiting and re-entering RR wouldn't fix the problem. Im running an ultra low power celeron 1.2GHz and I have no problem running RRCam + iGUidance + WinAMP as the normal daily usage setup. Its just when resuming from hibernation that all labels and values freeze and the CPU is not even under high load. Whatever process is responsible for the tick/refresh stops working
Something stops working on RR/DigitalFX after resuming from hibernation that stops all values from refreshing.
silvi4000 is offline   Reply With Quote
Old 01-06-2009, 02:14 AM   #3198
Squadfer is an unknown quantity at this point
Hey, I did a search in this thread but I most of read over it if it has already been addressed... My problem I'm having is when I'm in the normal menu screen, the menu button is showing that it is being pressed. I have the mouse set to hide and it still has the white border around the menu button...When I press another button (like the volume or seek)the white border goes away for 1 second and then comes back... This skin is awesome so far and this is my only bug that I cant figure out why it is doing this. I downloaded and installed this skin about 2 days ago from your website so everything is up to date.
Squadfer is offline   Reply With Quote
Old 01-06-2009, 03:00 AM   #3199
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Its a small issue with where that button area is defined. It just needs to adj so that its bottom left border corner is not at the bottom left most part of the screen.
Go into the Skins\DFX folder and open up the "Menu.skin" file in notepad and look for a line like the one below
B90,0,518,101,81,"LOAD;menu2.skin",""
and change it to something like this:
B90,3,518,101,78,"LOAD;menu2.skin",""
Also do the same in the the "Menu2.skin"
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 01-06-2009, 04:44 AM   #3200
Dougw133 is an unknown quantity at this point
How about that! I always wondered about it...
Dougw133 is offline   Reply With Quote
Old 01-06-2009, 08:57 AM   #3201
This morning on my way to work I tried to play around with it some more (while parked of course).
This time when I tried to change songs, once again it bombed, but on the player page instead of seeing any album art I saw the following message:
Good Morning, Auto Set to Day Time.
Lol - what the heck is that about.
Still can't change songs, still have to exit RR and restart RR to play a different tune - confused...
Old 01-06-2009, 11:04 AM   #3202
Is there a way I can debug this to see whats going on?
I'd hate to have to pull the PC out of my car to resolve this issue.
Old 01-06-2009, 11:08 AM   #3203
The Curator
Blue ZX3's Avatar
Not other than turning on the debug and after it happens kill rr and take a look at the last few entries in the log to see if anythings weird..
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 01-06-2009, 01:30 PM   #3204
I'm sorry blue, I went through the whole thread but can't seem to find it. How do I turn on debugging, and where is the output file written?
** I guess I just add the following to RR.ini
debugmode=true
Where is the output written?
Old 01-06-2009, 01:38 PM   #3205
Thanks for the fast response blue, that solved it
Old 01-06-2009, 02:02 PM   #3206
pierrotm777's Avatar
pierrotm777 will become famous soon enough
Sentence on French
I John,
Dfx4 play sentence when it run .
Where can i modify this .
I had added this on exectbl.ini file :
"OnSkinStart","SAY;$VOICEGREETING$||SetApps||SetCo mmandLabels01||SetAppLabels||SetIcons||GammaSlider ||ExtraPrograms||GPSEXEC"
and add on skin.ini file that:
[SKIN SETTINGS]
VOICEGREETING=Bienvenue dans RoadRunner=Bienvenue dans RoadRunner
Ok After the VOICEGREETING sentence ,DFX play another sentence than i would like to stop .
How can i to do that please.
pierrotm777 is offline   Reply With Quote
Old 01-06-2009, 02:11 PM   #3207
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Good question! it's a mistery where those voices come from.
treetop777 is offline   Reply With Quote
Old 01-06-2009, 02:28 PM   #3208
MGD
MGD's Avatar
MGD is on a distinguished road
The best way to stop road runner's chatter box is to set voice enable = false. Then change all SAY commands to TALK. No more mistery voices.
MGD is offline   Reply With Quote
Old 01-06-2009, 04:00 PM   #3209
Well, I got the debug.txt file, but I'm at work so I can't upload it yet (don't have a flash drive on me).
Anyway, the problem is definitely in Winamp.
I opened winamp and played a song with no issues, then when I double click another song (or the same song) thinking that the new song would start playing, but winamp closes unexpectedly.
So how do I fix this issue? Its weird that it just started happening.
Old 01-06-2009, 04:49 PM   #3210
The Curator
Blue ZX3's Avatar
WA issues??? Maybe a fresh reinstall of WA would solve it. I have never had to do this but i've read bout others doing it when thay WA issues arise.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
