05-24-2009, 09:43 AM
#3661
Quote: Originally Posted by junhe
i try to play the rmvb video file using the Video, but it sometimes pop up the error said " media player classic cannot render some of the pins in the graph,you may not have the needed codecs or filter installed on the system"
looks like as media player says, "you may not have the needed codecs or filter installed on the system"...
try to install the following codecs:
Real alternative; (this one is for rmvb)
ffdshow.
they will solve your problem.
Engineering: Where the rubber meets the road!
05-24-2009, 10:19 AM
#3662
i play with the MPC without problem, but when running the video in DFX, it show this error.
05-25-2009, 06:50 PM
#3663
the manage playlist function not working,i create the new playlist, and it show saved, but i see nothing at the playlist
05-25-2009, 09:30 PM
#3664
On page 1 of the music section of RRConfig make sure ".m3u" (no quotes) is included in the Audio File Types box.
05-26-2009, 08:20 AM
#3665
i included d, but how to add new?
i click on "Manage Playlist" then it is nothing there,
even i click "New" and Enter, it show playlist saved.
but it is nothing there also
05-26-2009, 10:51 AM
#3666
Did you create a folder for playlists on your computer and then point to it in Page 1 of the music settings in RRConfig?
05-27-2009, 08:04 AM
#3667
got it. thanks!!!
any ppl noe how to play RMVB file?
05-27-2009, 09:22 AM
#3668
^ the answer is in the first post on this page.
05-27-2009, 07:09 PM
#3669
i tried, it hanged after play 2 second.
05-29-2009, 12:43 AM
#3670
Quote: Originally Posted by Flaring_Afro
this didnt happen originally, but the in the main menu the only (bottom) button that looks right is the far left one. all others have numbers on them instead of the play/pause symbols etc. same thing happens in music player and in video half of them (same ones like play) dont show and have numbers too.
i tried going back to restore point, reinstalling rr, fx, flash, divx, winamp, everything i had installed and it still does this. how could this be? at one point it worked fine then nothing. also, all firewalls are disabled.
EDIT: pic
alright, I have the exact same problem.
I have found the solution on the first page--that I need to reinstall the digitalfx font from the helper files, I found the font, but can't figure out how to install it. I tried copying the font over, but it still doesn't work. what am I doing wrong?
05-29-2009, 05:39 AM
#3671
The Curator
Win key + R
Fonts
File>Install new font
05-29-2009, 08:17 AM
#3672
is the DFX support lyric display?
05-29-2009, 03:36 PM
#3673
Quote: Originally Posted by Blue ZX3
Win key + R
Fonts
I can´t believe on this kind of question!!!!
Maybe they can search for a solution in the micro$oft forum as well! hehehehe
05-30-2009, 05:04 PM
#3674
ok, I am having a problem with the player. I was trying to get the automatically created playlist that was created by the database to appear in manage playlist. Well, I did something, and now neither the playlists appear, nor can I play anything. the songs show up, but when I press play select or add select, nothing shows up on the default playlist! I am sure its just a setting, but I don't know which one it is. I should have left well enough alone, but I am trying to do more with this software. Please help? Yes, I have created a folder for the playlists, and have it pointed to there and still nothing and now my DGFX skin is non functional with regards to music.
****Update*****
Reset the path to the playlist to what it was before (empty) and that restored everything once I rebooted the system. Still can't "manage" playlists like I'd like to, and I've tried the suggestions I've seen here in other posts. Can someone tell me what I am doing wrong? Why is something that should be so simple not work?
06-01-2009, 01:28 AM
#3675
Problem I have never had.
My year lasted install of XP had finally corrupt. I had major TCP/IP issues. Either way, I installed tinyxp and everythings is running great
"""""ECEPT"""" DFX 4.
I have intalled and re installed rr/dfx4 many times over the past year.(and 3). New problem I cannot seem to tackle seems to be a flash issue. The compass and gauges screen has blue and white block looking backgrounds to items. I have latest flash and Shock installed. Applied fixflash.exe in helper file.. I am 99.9% sure it's flash. Any ideas? thanks.
| Thread Tools |
| Display Modes |
Linear Mode
