Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 06-01-2009, 12:08 PM   #3676
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Were you using TinyXP before? I wonder if there are some stripped out files that you need. Did you check the stickies and run that exe that Mitch linked to for Flash 10, that's what the latest versions of RR are built upon now.
I had a flash problem on my newly built CarPC, ran that flash 10.exe and everything was perfect from there. In fact on the gauges screen, my little 2.4 ghz intel celleron shows 1% CPU! That screen has 5 flash applets / sfw's in it, 1% I was floored
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 06-01-2009, 12:43 PM   #3677
Flaring_Afro's Avatar
Flaring_Afro is an unknown quantity at this point
i also have flash problems. around the clock and logos is the white block. updated everything like flash as well and this is on tinyxp, xp, vista 64, and vista32. every time i had this happen. i never planed on using the clock or logos though, just a thought.
Flaring_Afro is offline   Reply With Quote
Old 06-01-2009, 01:41 PM   #3678
Dougw133 is an unknown quantity at this point
No i wasn't running TinyXP before. I installed flash 10 as well and it persists. I can't seem to get a handle on it. The compass has a blue rectangle behind it, and the gauges screen is just a mess.. Yeah I have 0-1% CPU use on the guages screen with a 45Watt 2.5GHZ, it's nice!
I'll mess around with it some more today. I'll do some more research. If I find anything I will be sure to report..Thanks!
Dougw133 is offline   Reply With Quote
Old 06-01-2009, 05:25 PM   #3679
Tried a few more things. Nothing works..Flash website spins the little logo and says it's installed correctly. I also have no video in the built in RR vide player. MPC plays them fine and I have all the same codecs I had before. Those are my two issues right now. If nothing happens soon I think I'm going to abandon TinyXP and just do a full install..
Old 06-01-2009, 05:51 PM   #3680
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
From now-on, all about flash should begin with the statement: "I updated flash USING INTERNET EXPLORER"
treetop777 is offline   Reply With Quote
Old 06-01-2009, 06:32 PM   #3681
I didn't...I used Firefox
Old 06-01-2009, 07:04 PM   #3682
i used firefox too. ^^^ did you set the media player classic path in rr configuration? mine worked fine on all platforms.
Old 06-01-2009, 07:27 PM   #3683
Yeah I set it but it shouldnt matter. RR uses WinMM MCI an old built in deal for windows. I could use MPC if I wanted to,,but i dont! Im thinking TinyXP doesn't have the Winmm MCI. I need to pursue my flash and media player issue in the RR thread I guess. Figured maybe someone using DFX 4 was also using TinyXp and coould shed some light..Thanks anyhow.
Old 06-01-2009, 07:33 PM   #3684
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
You all talk about TinyXP, and is what i use in car as well, but what you ALL failed to mention is which revision of TinyXP? I'm using Rev 9, have used both 3 & 5 in the past as well.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 06-01-2009, 07:46 PM   #3685
youre right...but im using rev 9 sp3 as well.
blue..does rrmedia use flash? the lists dont show up in database browse mode.
Old 06-01-2009, 07:49 PM   #3686
The Curator
Blue ZX3's Avatar
Did you see post#2 for some fixed skin files? Yes, RRMedia works just fine, iList are NOT flashed based, as some somehow think.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 06-01-2009, 08:01 PM   #3687
SOLVED:
Well I feel like an idiot..I don't understand what the deal was but on my old XP Full build I never updated to Mitch's flash 10 and did not have flash issues. I just used the Flash 10 supplied by mithc and my flash issues are solved! Still no RR media lists though (I understand it's not flash). I only have the video left to figure out. Thanks.
Old 06-01-2009, 08:04 PM   #3688
No Blue I had no idea about Post #2. I will will install them tonight. Thank you.
EDIT: Of course that did the trick, thanks a million.
Old 06-03-2009, 07:18 PM   #3689
drewbp is an unknown quantity at this point
Gas Prices and Movie times are not working for me. It has been a while since I used either of them. It is not just that info is not coming up in the screens, the screens are not even loading. I check in the skin editor and the screens are there and seem to look okay. I use DFX 4.0, and have the latest 5/1/2009 build of Ride Runner. I also realize that Gas Prices may not yet have been fixed for loading the data.
Thanks.
drewbp is offline   Reply With Quote
Old 06-03-2009, 08:14 PM   #3690
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Internal Gas Prices was broken by a website change and has been replaced by an external plugin called RRGas.
Movietimes was also broken due to a website change, Sonic is working on a new version but is coming across issues with websites issuing desist orders.
Enforcer is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
