Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 07-10-2009, 05:41 PM   #3721
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
The plugins do not come with any skins included.
It makes more sense for the supporting skins to be in the main skin package, it will get very confusing for people to have to install skins from a plugin package.
However if you don't feel you can provide support and skins for my plugins I understand.
Enforcer is offline   Reply With Quote
Old 07-10-2009, 08:21 PM   #3722
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
It's not a matter of supporting your plugins at all... Just many times I have downloaded plugins in the past, they come with a few different skins to match a skin someone may be using. What I meant, is that I can create the skins in the DFX style, that you can package with your plugin.
When they DL the plugin from your site, they have to configure it, move files and such into place, so it kind of makes sense to have the skins with the plugin. If I remember, you had a couple of different skins that came with a plugin you did...
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 07-10-2009, 09:02 PM   #3723
Confusion Master
Enforcer's Avatar
The plugin's don't come with any skins. I have done BMV2 and iDrive example skins and put them in the release threads.
It was the standalone ones that came with the skins, and that makes sense, because they won't work otherwise.
But for extensions it's better to have the .skin files and graphics in with the main skin and not have to copy skin files from the plugin package.
I think you are getting mixed up with standalone programs that get embedded and extension plugins.
Old 07-11-2009, 03:11 AM   #3724
JosepZ is on a distinguished road
What are the right folders to choose when installing?
I have last Ride Runner in D:\Ride Runner folder, so, I choose D:\Ride Runner\Skins as destination folder when installing DigitalFX 4.0...
The installation program created me a folder called DigitalFX 4.0 inside my Ride runner\skins folder, but it digitalFx skin appears when I start rr and I can´t choose it in RRconfig....
Only if I move D:\Copia de RideRunner\Skins\Digital fx 4\Skins\Digital FX 4 to my
D:\Copia de RideRunner\Skins\ folder I can choose the skin in RRconfig... but not sure where must go the files inside D:\Copia de RideRunner\Skins\Digital fx 4\...
JosepZ is offline   Reply With Quote
Old 07-11-2009, 04:51 AM   #3725
Ok, I solved it... the installation folder must be the one you have RR.. the problem was my old skin config, RR was searching something for it... just a new RR installation, and all is working fine now...
Old 07-11-2009, 02:08 PM   #3726
Super Moderator
JohnWPB's Avatar
Yes, the installer asks what folder you have Road Runner installed into:
D:\Program Files\Road Runner\
Would be correct, as it uses the root folder to know where to put everything.
Old 07-11-2009, 02:46 PM   #3727
Where is the phone button?
Is possible to use bluetooth phones with it?
Old 07-13-2009, 12:48 AM   #3728
hmonay is an unknown quantity at this point
When I press the browse button
in the music section I get an error
say "we've intercepted a com error"
does anyone know how to fix this?
Thank You!
hmonay is offline   Reply With Quote
Old 07-13-2009, 05:16 AM   #3729
I have a problem with Gauges...
Even I installed last flash player, gauges work, but still I see a white backgroung around left bar and gauges.
No problem with 3D logos, color changers, etc... only gauges....
Maybe I need an old flash player version??
Old 07-13-2009, 09:12 AM   #3730
kbreeden
Quote: Originally Posted by JohnWPB View Post
I have started to work on the skin again, and am getting it ready for an update in the coming weeks.
Glad to hear, John.
Menu3.skin?
kbreeden is offline   Reply With Quote
Old 07-13-2009, 01:20 PM   #3731
Thank You!
I had the same problem because I had a old database file in rr before I moved my music to another place....
I fixed it writing the new music place in RRconfig and a new scan... never see it again.
Old 07-13-2009, 05:01 PM   #3732
Super Moderator
JohnWPB's Avatar
Look in the stickies for the Flash 10 updater. This should fix it for you.
Quote: Originally Posted by kbreeden View Post
Glad to hear, John.
Menu3.skin?
Yes, there is a menu3.skin now I had to , as there are so many options for just 2 screens.
The menu button also displays what menu screen you are in "Menu 1", "Menu 2" ect.
Going through the latest RR source code, I notices some weather labels that are available, and were just not documented. Mainly local time for the weather city, as well as Lat & Lon coordinates for the WeatherCity.
I was able to use the Lat & Lon labels for use with the animated radar map. When ever you change the city at the top of the screen, and then go to the satellite radar map, it will be centered with that city.
Gas prices are working perfectly now with Enforcers latest plugin code, as well as a lot of tweaks and additions.
I do mean tons of tweaks and additions, so many I am not sure what ones hahah! Mainly all of the bugs and problems since the last release a year ago have been worked out.
Old 07-13-2009, 05:29 PM   #3733
Confusion Master
Enforcer's Avatar
Is that with the new 1.6 modifications
Old 07-13-2009, 05:53 PM   #3734
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
1.6 ?? there is no such animal! - unless you too are holding back on us
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 07-13-2009, 06:30 PM   #3735
Confusion Master
Enforcer's Avatar
First post of the rrgas thread has some clues as to what is added in the new version.
Will be PM'ing John the new dll overnight
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
