08-29-2009, 04:08 PM
#3841
Quote: Originally Posted by JohnWPB
Just use either rrconfig, or put that line in the rr.ini and you will be a very happy person, as it it is a 100% fix for the problem.
No it's not a 100% fix. That's what we're saying.
A lot of times the lower left start icon is still there even after using the "hide task bar" option.
08-29-2009, 11:44 PM
#3842
another issue...when in RR, the CPU goes up relatively high to like 50% + and i tried updating the flash but nothing to my avail...can u shine any light upon me John?
08-30-2009, 01:00 AM
#3843
Are you using a 3d logo like a clock? Could be eating up your CPU time..
08-30-2009, 01:11 AM
#3844
Your right... I am using the clock. Is there any way to change that out? I tried changing to a car logo but it didn't work via RR options.
08-30-2009, 01:28 AM
#3845
You change it through the skin, under Settings > DFX settings
08-30-2009, 01:31 AM
#3846
thank you, i shall give it a try.
08-31-2009, 12:25 AM
#3847
hmm i tried it and its freezing ride runner...music keeps playing but riderunner itself freezes up.
08-31-2009, 07:53 AM
#3848
Blue, John,
is there a way to use the content of a .txt file in a indicator box? like the icons in the menu, where we use "setvar" to create a var that points to a png image, and we can change this image on the fly...
could it be done with a TXT?
Engineering: Where the rubber meets the road!
08-31-2009, 10:32 PM
#3849
Super Moderator
Hmmm no way that I can think of.... The easiest way would be to create a sub folder in the skin folder with the different variations of the image. Then whatever it is that is supposed to change the contents of the text file, just do a file copy instead to the correct name to be displayed by the file indicator.
Something like:
copy <Skinpath>/Indicators/IndicaorStatusOn.png <SkinPath>indicator.png.
When an image that is displayed with the file indicator changes on the drive, it is updated instantly in RR.
I am in Canada for the next few days, if nothing else, when I get back I could make a small AutoIt script or something to possibly do something like this....
08-31-2009, 11:05 PM
#3850
Hi John
Is this a flaw or is it supposed to be like this only.....
I have 12 stations in my Radio page... ( using Si Labs )..
While in this page i can use the Forward/reverse buttons to go to next or previous tuned radio station ( i guess it works like this ... Fine )
but when i am on the main menu screen ( while the radio still playing ) the Forward / reverse buttons dont work to change the channel....
Should this also not work like in the radio page
Thanx
vicky
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
08-31-2009, 11:13 PM
#3851
Super Moderator
since the last release of DFX, new commands have been added in rr to go to the next and prev of whatever is playing EA: next video, song, radio station all with one button command. I will get this all sorted out before the next release.
09-01-2009, 12:08 AM
#3852
The Last Good Gremlin
Quote: Originally Posted by vicky_obee
Hi John
Thanx
vicky
I've run into this type issue on several skins. The easiest way to fix it is get a multi-file editor (WildEdit is what I use) and search and replace all NEXT and PREV commands to RRNEXT and RRPREV in all your .skin files.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
09-01-2009, 12:26 AM
#3853
any ideas why i cant switch out the clock?? when i go change it to the lexus logo, it freezes up and i have to shut it down via task manager.
09-01-2009, 09:00 AM
#3854
Something like:
John, I think I don´t make myself clear, I want to show the content of a TXT file in the skin, and I want this content to be updated every time I press a button in the skin.
(I will have a txt with a percent value that changes every time I press a button, and I want to see this value on the screen)...
Do you think that will be easy to understand if I put here a image of the screen/skin?? (cause my english sucks... hehehe)
thanks
09-01-2009, 11:26 AM
#3855
The Curator
Like how much is in this txt file? One line, serveral lines/pages? Would just be easier if we knew what your trying to do..
Like do you want to display the whole txt file in one big label or ???
Thinking that a screen cap might show what your not telling us..
| Thread Tools |
| Display Modes |
Linear Mode
