Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 09-01-2009, 12:15 PM   #3856
marteline's Avatar
marteline is an unknown quantity at this point
As soon as I back to home I will printscreen the skin...
but I just want to show a few characters in a small label, like: "50% - 08%"
Engineering: Where the rubber meets the road!
marteline is offline   Reply With Quote
Old 09-01-2009, 03:22 PM   #3857
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by hailrazer View Post
No it's not a 100% fix. That's what we're saying.
A lot of times the lower left start icon is still there even after using the "hide task bar" option.
Ok, i was able to look at RR config and find it. Open RRConfig, go to General and Page 1. Check mark the Taskbar under the hide section. This will work, as it completely turns off the task bar 100%. I was having the same problem here on a new install I am working on, and remembered where that setting is, and now when I go to GPS or to Video, there is no task bar anywhere in sight
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 09-01-2009, 06:02 PM   #3858
achillealb is an unknown quantity at this point
netStumbler
can help my to embedding netStumbler on roadrunner
achillealb is offline   Reply With Quote
Old 09-01-2009, 06:59 PM   #3859
marteline's Avatar
As promissed, attached the image of the mixer skin. Please see inside the red circles the text that should be captured from a txt.
The buttons above and below the skulls controls my front/rear speakers, and every time that I press those buttons, the text must be refreshed...
all this trouble because I canīt figure out how to use the sliders with my system (the name used by the system is analog and analog:2, and the slider just donīt work with that...)
(I am using the skulls to show the level, the guitars change the color acording to the level of the sound)
anyway, what I need right now is a way to show the value of the speaker level (txt file) in the marked place...
Old 09-01-2009, 08:09 PM   #3860
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
What does the txt file look like?
How are you creating the txt file?
how are you changing the levels of those two lines?
Enforcer is offline   Reply With Quote
Old 09-01-2009, 08:20 PM   #3861
marteline's Avatar
WYSIWYG, I just put the percent value inside the txt, example:
level1.txt = 50% level2.txt = 10% (after "=" is the content)
I create an Autohotkey to increase/decrease the value of the mixer channels and use the "RUN" command to call the script when i press the buttons
the same script create/overwrite the txt after I press the button
Old 09-02-2009, 12:03 PM   #3862
marteline's Avatar
Any Ideas?
Old 09-02-2009, 01:36 PM   #3863
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
My next Q would be Y are U using a sep app to control the lines? Should all be able to be done in RR code.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 09-02-2009, 01:46 PM   #3864
LiCelsior is an unknown quantity at this point
Quote: Originally Posted by LiCelsior View Post
any ideas why i cant switch out the clock?? when i go change it to the lexus logo, it freezes up and i have to shut it down via task manager.
bump........................
LiCelsior is offline   Reply With Quote
Old 09-02-2009, 02:20 PM   #3865
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by marteline View Post
Any Ideas?
Yeah.
Have the script send a command to RR which sets a variable and then writes that variable to the skin.ini rather than your own text file.
then read that variable for your label.
Old 09-02-2009, 04:48 PM   #3866
marteline's Avatar
I canīt manage to make the RR control my rear/front lines of the mixer...
I donīt know why... everything else works fine, like master, balance, wave, but the rear and front lines not...
the name of the controls are ANALOG and ANALOG:2... I try the sliders... no joy...
Old 09-02-2009, 04:49 PM   #3867
marteline's Avatar
Yeah.
enlight me... pls
Old 09-02-2009, 05:25 PM   #3868
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
You have to first chose the correct menu layout - have you done that?
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 09-02-2009, 05:37 PM   #3869
The Curator
Blue ZX3's Avatar
Using the SkinTool, does "SETVOL;ANALOG;46" or SETVOL;ANALOG:2;25" work?
Are those the exact line names as found at the top of the RR debug log?
Or C&P the lines that look like this...
8/25/2009 10:52:02 PM: Source: xxxxxxx
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 09-02-2009, 06:14 PM   #3870
Confusion Master
Enforcer's Avatar
enlight me... pls
Let me see the script you are using.
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
