Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 11-02-2009, 02:59 PM   #4126
dawnn is an unknown quantity at this point
I need help with image viewer, I finally got it to load and see the pics but none of the buttons work. I can sometimes use the keyboard to go to next and the others.
I downloaded imageviewer 3.
dawnn is offline   Reply With Quote
Old 11-02-2009, 03:01 PM   #4127
The calender does not work for me either
Old 11-02-2009, 05:01 PM   #4128
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Both the picture viewer and the calandar have been revamped and will be in the next release.... hopefully not too much longer.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 11-03-2009, 07:04 AM   #4129
marteline's Avatar
marteline is an unknown quantity at this point
John, the next release still use the RRcan as webcam recorder?
Engineering: Where the rubber meets the road!
marteline is offline   Reply With Quote
Old 11-03-2009, 10:12 AM   #4130
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
RRcan? Is that a toilet plugin?
Enforcer is offline   Reply With Quote
Old 11-03-2009, 11:14 AM   #4131
marteline's Avatar
What software you use today for this function Enforcer??
Old 11-04-2009, 12:49 AM   #4132
utd09bry's Avatar
utd09bry is an unknown quantity at this point
MP3Can, for all of your CanPC needs
utd09bry is offline   Reply With Quote
Old 11-04-2009, 06:23 AM   #4133
marteline's Avatar
ok ok, funny boys... RRCAM.... "M"...
is there any better software for replace it? I just find the "capture!", could you tell me what are you using nowadays?
Old 11-05-2009, 04:22 AM   #4134
achillealb is an unknown quantity at this point
men 2
Why is this happening
achillealb is offline   Reply With Quote
Old 11-05-2009, 08:53 AM   #4135
marteline's Avatar
First of all make sure you have your adobe flash updated...
then use the skin editor and remove the 2 boxes (buttons if I remember) above and beyond the clock... (in both menu and menu2)
I remember that something like that happen to me when I update the RideRunner...
this procedure should solve it...
Old 11-05-2009, 11:59 AM   #4136
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Yes, those "button" area's are to change the visu prev/next and where only ok if you where using the stationary logo/pic menu styles. This has been address and already fixed in the next one....
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 11-05-2009, 10:03 PM   #4137
CannonBaller is an unknown quantity at this point
Quote: Originally Posted by JohnWPB View Post
You will need a button to press to let the system know you are about to speak. This does a couple of things, it mute's the audio so if you are jamming out, press the button, audio is muted, so you the system can clearly hear what you are saying. When the command is recognized, the audio will resume.
Hooking up a button can be done in many different ways.
- Jebus designed a Serial Port Plugin so you can hook a button to 2 wires on the serial port.
- Use an available input on the Fusion Brain.
- Use CDRSkull's JoyPad plugin to take any old USB game pad to add a button
- Using RR's keytbl.ini, you can set a key on a keyboard, that when pushed will trigger it to listen.
- Use a mouse/trackball and assign a button.
- iBus
- Girder
John...
How difficult would it be to have it completely voice activated?
You could have the system always waiting for a specific command to activate.
"Computer, arche!"
Maybe someone can compile a module to emulate the seral port commnd when the voice phrase is heard.
CannonBaller is offline   Reply With Quote
Old 11-05-2009, 10:13 PM   #4138
Quote: Originally Posted by Dougw133 View Post
On another note...
What if we could make the pre commands "Kit", and instead of the beep confirming, a recording says "Yes, Michael"
Better yet. how about custom reponses using text-to-speach.
Old 11-05-2009, 10:24 PM   #4139
Dougw133 is an unknown quantity at this point
Well, it's really not a DFX 4/5 process. This is possible through the plugin made by Jebus, John is just customizing aspects of that plugin for DFX 5 countability etc.. Follow the thread Jebus has up as it is ever developing each day.
Dougw133 is offline   Reply With Quote
Old 11-05-2009, 10:31 PM   #4140
Jebus's Avatar
Jebus is an unknown quantity at this point
Actually the audio volume is lowered to zero, and set back to previous level, not muted...
"Computer, arche!"
The precommand was removed due to false recognitions in the vehicle environment....
The manual VR attention trigger is the best overall way to achieve optimum results.
The vehicle manufacturers use this technique, and they spend millions on R & D...
...JJG
SerialSwitch Version 5.0
Major Rewrite
RRVoiceControl Version 1.1.0.83 BETA
RRVCConfig Version 1.0.0.44 BETA
Jebus is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
