Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 03-31-2008, 10:35 PM   #676
silvi4000 is an unknown quantity at this point
Quote: Originally Posted by muldrick View Post
Maybe one should disable all anti virus/anti spam programs. My McAfee also caused problems with 2 different files...forget which ones...in this thread here somewhere.
symantec 11 (SymantecEndpointProtection) hasnt complianed (yet) about anything on the digitalFX installation.
This is on my daily use laptop, I dont run antivirus on the carPC.
silvi4000 is offline   Reply With Quote
Old 03-31-2008, 11:14 PM   #677
monty9991 is an unknown quantity at this point
Norton anti-virus 2007 and Norton internet security said nothing wile i installed DFX3.NAV if friendly with RR and its skins.. lol
monty9991 is offline   Reply With Quote
Old 04-01-2008, 09:14 AM   #678
dmistry is an unknown quantity at this point
https://buy.garmin.com/shop/shop.do?pID=13484#
Looks like John may need to soon add another GPS screen to his collection, Garmin's UMPC Mobile is coming out very soon!
dmistry is offline   Reply With Quote
Old 04-01-2008, 11:52 AM   #679
jumbodogs's Avatar
jumbodogs is an unknown quantity at this point
I posted a few pages back about using T-Mobile in my truck for internet connection and how the weather and CNN are not updating. I did some more reading and searching but still no luck with this. I think I read somewhere that the weather info is coming from www.weather.com but I was wondering if anyone could explain how the skin is getting the info. I can use IE or Firefox to browser to the site and get locale weather but from inside the skin it just sits there trying to load. This also freezes RR for a little bit.
If this doesn't seem like a skin problem sorry for posted here. Just let me know and I will try posting somewhere else for help on this.
My RAMPUTER
jumbodogs is offline   Reply With Quote
Old 04-01-2008, 01:14 PM   #680
dhmv2001 is an unknown quantity at this point
In my opinion Dest 7 for pc is the best
dhmv2001 is offline   Reply With Quote
Old 04-01-2008, 01:37 PM   #681
jimp is an unknown quantity at this point
I had, well still do till I call and cancel, a Tmobile data plan, it was the sorriest connection I have ever seen, at least in the houston area, maybe where your at its better, but I couldn't get updates and such either. My T-mobile connection was rarely ever better than 50k, I signed up for ATT and with this little USB sierra 881 I have never connected under .5M and ussualy more like 1.5M plus upspeed is always up over 1M . everything works like it should with this.
jimp is offline   Reply With Quote
Old 04-01-2008, 01:48 PM   #682
I use an ATT usb sierra card too. Works good, 1.5down/.5up
In the case of ATT card, it installs an "accelerator" service. I just get rid of it because what it does is that it proxies the connections and messes with image compression etc.. Most likely it connects you to an ATT proxy to do the compression magic.
Make sure yours is not setting a proxy on the browsers that RR is not aware of.
Old 04-01-2008, 01:55 PM   #683
Mine gave me the choice to install the accelerator service when I installed the software and naturally I declined.
Old 04-01-2008, 02:15 PM   #684
BREWDOG52's Avatar
BREWDOG52 is an unknown quantity at this point
Quote: Originally Posted by Machinehead View Post
First thing to test, are you actually connected to the internet. Do this by opening a web browser outside of RR. If that doesn't work, then it's your connection. If it does work, it's something with the RR or DFX.
Might as well make sure it's actually working before you play with anything else.
he already said it works outside of RR
BREWDOG52 is offline   Reply With Quote
Old 04-01-2008, 04:03 PM   #685
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by klundy View Post
Ok, a few pages back I mentioned a problem with hibernation based on elapsed time on laptop battery.
I have narrowed it down. There is a variable autoupdateinterval (I believe that's it off the top of my head) that is used by at least weather and zip code locator. I set that to 0 which I believe disables it. Hibernation resumed working.
AutoUpdateInterval is the setting for the zipcode database lookup. That will set the labels for city, state, zipcode and county even without internet connection. This is also where the gas price finder takes your location (Internet required for this part) and finds the cheap gas stations close to your location.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 04-01-2008, 04:05 PM   #686
shot598 is an unknown quantity at this point
hello all...my gaspricefinder used to work but now is now workin..i have john patch,i have internet.any help would be thankfull
shot598 is offline   Reply With Quote
Old 04-01-2008, 04:17 PM   #687
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Sometimes it helps if I read the whole post. I lost interest about half way though.
Edit: I went and deleted my retarded post.
Machinehead is offline   Reply With Quote
Old 04-01-2008, 04:30 PM   #688
Super Moderator
JohnWPB's Avatar
I'm not sure of all the specifications and such, but it appears just to be a re-branded NavTeq map set, just like iGuidance. They have skinned it, which makes it look a little different, but it appears to be running on the same exact back end as iGuidance 4.0.
Old 04-01-2008, 05:11 PM   #689
the_crooked_toe's Avatar
the_crooked_toe is an unknown quantity at this point
your sig says you're from Brooklyn but i highly doubt it...engrish prease?
1. what's a john patch
2. i have the internets too!
do u have iGuidance 4.0?
the_crooked_toe is offline   Reply With Quote
Old 04-01-2008, 10:59 PM   #690
BREWDOG52's Avatar
If it's NOW working I don't see a problem
Ok...my translation...
His gas price finder used to work, but now it doesn't...he downloaded John's umpc patch, he has a internet connection in his car...
More information would be helpful...what changes if any were made before it stopped working...does the gas price screen not show up or does the gas station/prices just not show up...
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
