Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 04-05-2008, 04:11 AM   #766
funkyphil's Avatar
funkyphil is an unknown quantity at this point
Need Help With This Error!!!
Please help me with why I keep getting this error. Here is the link where this thread is. thank you
Phil
http://www.mp3car.com/vbulletin/gps/...ml#post1196900
funkyphil is offline   Reply With Quote
Old 04-05-2008, 12:30 PM   #767
brodgar is an unknown quantity at this point
Quote: Originally Posted by barnyard View Post
I could be wrong, but I don't think you need to use radiator... set up radiomode=1 in rr.ini and see what that does
Tried as above, result -- nothing worked.
It looks as though I need Radiator to control the radio. The problem remains getting the skin and Radiator to talk to each other.
For the present I have set up Radiator as an external application. Not ideal I admit, but at least I can control the radio from within the skin.
brodgar is offline   Reply With Quote
Old 04-05-2008, 03:43 PM   #768
funkyphil's Avatar
Need Help Ig And Dfx Error
Hi Guys,
I was hoping that maybe someone has a fix for this error i keep getting. Here is the link from a different thread I have posted!
Thanks in advance.
http://www.mp3car.com/vbulletin/gps/...-new-post.html
Old 04-05-2008, 04:30 PM   #769
Woofnstuff's Avatar
Woofnstuff is an unknown quantity at this point
just a note.. when i uninstalled this (it has so much stuff ill never use ) some how it either removed or crippled Comdlg32.ocx, and as a result i could not get the skin editor to work. reinstalling this skin didnt fix it, so i tracked down Comdlg32.ocx and reinstalled that and its all good again..
Woofnstuff is offline   Reply With Quote
Old 04-06-2008, 02:41 AM   #770
monty9991 is an unknown quantity at this point
Quote: Originally Posted by PacketSniffer View Post
Good idea. Let's take it a step further. My opinion is that the we should save as much real estate for the multimedia info. The guts of the CarPC should go humming along and if something is wrong, we should be proactively alerted by the system. So, wipe the skins of the temp numbers and alert us with a pop-up screen if the temp goes over "XXX" degrees. The temp could be user configurable to suit everyone.
My 2 cents.
looks like no one is intrested in this kind of mod on the skin..
is there any one who can write some codes on this???
monty9991 is offline   Reply With Quote
Old 04-06-2008, 03:24 AM   #771
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Actually I did start on an ext plugin that would perform this action..
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 04-06-2008, 04:07 AM   #772
megagoo's Avatar
megagoo is on a distinguished road
to get the temperature to display properly, do i simply go to menu.skin and menu2.skin and look for:
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," TEMP2","left"
L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial", "=Computer:","right"
L,212,4,89,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," =Interior:","right"
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," TEMP1","left"
and replace TEMP2 and TEMP1 with the variables from ShowSpeedFanData.exe ?
also, my xm radio stopped working. when i click it, it takes a little longer, then simply shows my mp3 playlist in the window where my xm channels usually are. what could that be?
megagoo is offline   Reply With Quote
Old 04-06-2008, 04:07 AM   #773
megagoo's Avatar
oh and this skin needs its own subforum. i would make asking and answering questions a lot easier/organized.
Old 04-06-2008, 05:15 AM   #774
yes you hvae to change temp1 and temp2 to the speedfan variables.
Old 04-06-2008, 05:16 AM   #775
Thanks.. hope you finish this soon
how do i make a clock like this with my company logo in it in the main menu like other clocks.
and if nay one can make it for me the ill send you the logo.
Old 04-06-2008, 08:52 AM   #776
kbreeden
to get the temperature to display properly ...
If you want it to display on all your menu screens, you will need to make the change in all menu.skin and menu2.skin files, including those in the menus sub folder. Of course, you also need to make sure speedfan is running.
kbreeden is online now   Reply With Quote
Old 04-06-2008, 10:01 AM   #777
PacketSniffer is an unknown quantity at this point
Either that or at the very least a separate discussion thread (one used to actually discuss). Either way, it would go a long way towards fostering better communication about this great skin. As it is now, communication is being stifled in the name of a clean thread of which I agree and disagree with. We're working against ourselves here and need a better way.
I second the request for a DFX forum.
PacketSniffer is offline   Reply With Quote
Old 04-06-2008, 11:27 AM   #778
Ramanator's Avatar
Ramanator will become famous soon enoughRamanator will become famous soon enough
Where are the speedfan varibles located? (I may need help on this one).
If you cant DODGE em, RAM em.
Ramanator is offline   Reply With Quote
Old 04-06-2008, 12:45 PM   #779
barnyard is an unknown quantity at this point
It does that when it can't find the xm tuner. Check your connections, as well as the xmport in rr.ini
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
barnyard is offline   Reply With Quote
Old 04-06-2008, 06:16 PM   #780
PontiacGA's Avatar
PontiacGA is on a distinguished road
Ok, after spending 2 days getting this new MB working (Had to buy XP...again and install it), now it seems the Autoit features dont work. Before you ask, yes I have AVG and no thats not the cause. I uninstalled and reinstalled DFX....nothing. Still no Album art selection, 3Dlogo, etc etc. If I click on, say, Change3Dlogo, I get an error saying 'Error:Array variables has incorrect number of subscripts or subscripts dimension range exceeded'. What does that mean?
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PontiacGA is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
