Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 04-09-2008, 03:36 PM   #826
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by brandensin View Post
YEAP.. i was gonna ask about that too... that sometimes rr doesn't close winamp, endedup up having a winamp processor hanging in the memory.. So, when rr starts nexttime, new instance of winamp having some issue with the one hanging in the memory..... Most of the time, rr will successfully close winamp, but not all the time...
This has happened to me a LOT during testing the skin. Having to end Task Winamp all the time when restarting the skin ect. I can't beleive it took me so long, but I finally resolved it When you exit the skin now, Winamp is end tasked I have been running the skin like that for a few days now, and it works perfectly, with no ill side effects such as drowsiness, diarrhea , sore throat, blurred vision and so forth
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 04-09-2008, 05:23 PM   #827
brandensin is an unknown quantity at this point
cool... now i don't have to have task manager opened all the time, sort it, find winamp and KILL it... Became my routine...
brandensin is offline   Reply With Quote
Old 04-09-2008, 05:47 PM   #828
k1hog's Avatar
k1hog is an unknown quantity at this point
JohnWPB, your work on the software is outstanding. Calling Streets and trips, the buttons are dark, your thoughts on same? Would it be possible to access CoPilot within the program?
Thanks Johnnie
k1hog is offline   Reply With Quote
Old 04-09-2008, 05:53 PM   #829
k1hog's Avatar
JohnWPB, oops, disregard the streets question, saw the answer.
Johnnie
Old 04-10-2008, 01:05 AM   #830
drewbp is an unknown quantity at this point
Quote: Originally Posted by copter View Post
Try installing DFX 2.5 and then trying it in both skins. I had the same problem after I uninstalled DFX 2.5. After I re-installed 2.5, 3.0 works again. Don't ask, it just works and the un-install was the only thing that changed. Hope this helps.
Well that was the trick. At least on my test computer. That got it working. Thanks for reading through the posts and responding. I am finding that once you post a question, you might get one or two quick responses but then it gets lost in the vastness of this thread.
Once again thanks for the help.
drewbp is offline   Reply With Quote
Old 04-10-2008, 01:53 AM   #831
megagoo's Avatar
megagoo is on a distinguished road
Quote: Originally Posted by megagoo View Post
to get the temperature to display properly, do i simply go to menu.skin and menu2.skin and look for:
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," TEMP2","left"
L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial", "=Computer:","right"
L,212,4,89,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," =Interior:","right"
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," TEMP1","left"
and replace TEMP2 and TEMP1 with the variables from ShowSpeedFanData.exe ?
Quote: Originally Posted by monty9991 View Post
yes you hvae to change temp1 and temp2 to the speedfan variables.
ok i did this so it looks like:
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," SFT0","left"
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," SFT1","left"
and it didn't work, i think it said in the skin
Quote:
Computer: right Interior: right
......i just noticed though on my monitor there is a space before the 'temp1' and 'temp2' that i probably didnt put in. maybe thats it?
megagoo is offline   Reply With Quote
Old 04-10-2008, 08:33 AM   #832
Mini Sumo is an unknown quantity at this point
S&t
Normally I can figure things out and learn, but I'm stumped on this one. I can't get streets & Trips to load when I select Streets & trips button on the button selector. If I choose the IG Button S&T will load with the IG png file ? I know in 2.5 I had to edit the button skin to read "GPS" as supposed to "Remembergps"
"B06,559,261,240,83,"RememberGPS",@gaspricefinder@ " this was changed to -
B06,559,261,240,83,"GPS",@gaspricefinder@ for it to load S&T .. I tried the exectbl file and it still won't work ? I can select the IG button get S&T to load then go back and select the S&T button and it will load, but once I reboot it won't load again ?
Stumped !
Mini Sumo Was Here
Mini Sumo is offline   Reply With Quote
Old 04-10-2008, 09:33 AM   #833
BlackStealth is on a distinguished road
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," SFT0",""
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," SFT1",""
I removed the "left" phrase, try it again.
BlackStealth is offline   Reply With Quote
Old 04-10-2008, 11:22 AM   #834
Update: Well that worked on the car pc as well. It seems to solve a couple of other issues with the way songs are displayed in the music browser also. There must have been a couple of files in DFX 2.5 that did not make it into or are different in the installer for DFX 3.0.
Old 04-10-2008, 07:42 PM   #835
MantisX is an unknown quantity at this point
On my GPS screen, I dont get an option to select which GPS I want to use. Id like to use my copy of streets and trips but it never gives me the option to choose it. When I hit the GPS button, it loads S&T but it loads it separately from the skin. Any ideas?
MantisX
MantisX is offline   Reply With Quote
Old 04-11-2008, 05:51 AM   #836
kbreeden
Black, is this working for you? Are you able to see the computer temp on the menu screens?
kbreeden is offline   Reply With Quote
Old 04-11-2008, 08:13 AM   #837
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
MantisX
You need to adjust your RRconfig settings for S&T.
Machinehead is offline   Reply With Quote
Old 04-11-2008, 09:58 AM   #838
Yes it works for me. You need to keep the speed fan programming running at all times.
Is anyone using IGQwerty program? The ABC keyboard on iGuidance drives me crazy, and I just discovered that cool program that converts it into a QWERTY keyboard. It works great, but I'm not happy with the colors. JohnWPB made some skins for it and I've been unable to locate his IGQwertyBlueDevilSkins.zip file. The old links are dead. Can someone provide those skins again? Thanks.
Old 04-11-2008, 01:44 PM   #839
cMags's Avatar
cMags is on a distinguished road
Great, so can I just re-download the installer and install over the top, or how do I add the fix so I can keep my already-configured skin (button choices, theme, etc)?
CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
cMags is offline   Reply With Quote
Old 04-11-2008, 06:01 PM   #840
THEREALRAWPWR is an unknown quantity at this point
Click On My Mp3 List To Play ?
Hi,I'm Trying To Click On My Mp3 List of songs for each album to play but ,the only way it plays back is if you put in play lists? why, i didn't have to do this with brush metal skin ,i tapped (click) once the song played. what I'm trying to say is i don't want to populate a play list to be able to play back my tunes. In Need Of Help , Thanx a Bunch.
THEREALRAWPWR is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
