Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 04-21-2008, 09:57 AM   #901
leatherboy's Avatar
leatherboy is on a distinguished road
Hi again.
I try all these days to find a solution about the 100% percentage when I enable the gps port in RR. The flash clock is enabled and RR never hangs. It only does when GPS port is other than 0.
So In the menu.ini I disabled these 2 lines because I don't need them. (In menu2.ini they are enabled and they don't affect what I will write).
L,1,0,1,1,0,0,0,12,"Arial","GPSHDG",
L,1,1,1,1,0,0,0,8,"Arial","GPSCompass",
So when I disable them RR don't start. If I enable these 2 lines RR starts normally. I try to figure out if these 2 lines affects the 100% load of the cpu when gps is enabled. But I can't delete them because RR don't sarts. Bingo. Any idea?
leatherboy is offline   Reply With Quote
Old 04-22-2008, 04:55 AM   #902
Dougw133 is an unknown quantity at this point
Apologize if this has been adressed, I have looked. When I am in the Music player screen and playing a song, when the song ends, if I switch back to the main menu the song starts playing again from a random point. This happens vice versa ocassionaly as well. I believe it has happened switching back ffrom the GPS screen as well. Anyone have this happen?
Dougw133 is offline   Reply With Quote
Old 04-22-2008, 10:07 AM   #903
silvi4000 is an unknown quantity at this point
Yes, I have seen this happen when you play a single song and let it finish. Once you start switching screens, it will start playing again from around the middle of the song.
At first I thought I was hitting the progress bar and resetting the song back to the middle but that was not the case.
silvi4000 is offline   Reply With Quote
Old 04-22-2008, 06:02 PM   #904
Exactly what is happening...
Old 04-23-2008, 08:05 AM   #905
leatherboy's Avatar
Quote: Originally Posted by leatherboy View Post
Hi again.
Can anyone try what I describe? I do this in 2 computers and I get the same behavior. Is this a real problem?
Old 04-23-2008, 08:41 AM   #906
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
No problem here. I'm running a flash clock and the GPS port is set in RR..CPU load is around 10% normaly.
If haven't done this yet, delete ziplocator.dll and zips.dat from the RR folder (if they are there).
treetop777 is offline   Reply With Quote
Old 04-23-2008, 11:14 AM   #907
Hi again.
what process is using 100% CPU?
what kind of CPU ?
Old 04-23-2008, 03:02 PM   #908
leatherboy's Avatar
what kind of CPU ?
celeron 1,7 , 1gb ram. RR loads the cpu at 100% but only when gps port is enabled.
If you change these 2 lines
to
/L,1,0,1,1,0,0,0,12,"Arial","GPSHDG",
/L,1,1,1,1,0,0,0,8,"Arial","GPSCompass",
in menu.ini, does RR starts?
Old 04-23-2008, 03:07 PM   #909
leatherboy's Avatar
There is no ziplocator.dll or zips.dat. I checked it, somedays before. Thanks.
Old 04-23-2008, 04:29 PM   #910
to
yes, it loads without issues
Old 04-23-2008, 04:40 PM   #911
leatherboy's Avatar
Thanks. Maybe something is wrong with my installation files. I don't know. I will try to download everything again and reinstall RR and DFX3.
Thanks again.
Old 04-23-2008, 05:15 PM   #912
moelsaied88 is an unknown quantity at this point
Hey guys, im trying to install this skin, but it gets stuck at 30% while installing ActiveWinamp.exe I installed the newest version of winamp, could that be the problem? thanks in advance.
moelsaied88 is offline   Reply With Quote
Old 04-23-2008, 09:22 PM   #913
muldrick's Avatar
muldrick is on a distinguished road
I had the same problem, never did figure it out. It did not do that on my home PC, so I installed it there, then copied the entire RR folder and put it on my carPC. Haven't got all the bugs out, but it works mostly.
One problem...help please...I set up HD Radio on another PC and it worked fine. Now I'm trying to set it up on my own car and I can't get it to work in the DFX skin. Works fine as as stand alone...with the OE software.
What was the deal with the rr config...set the radiomode=0...or radiomode=8 ????
AtmosUSA.biz, E-Cig Mods
muldrick is offline   Reply With Quote
Old 04-24-2008, 07:36 AM   #914
leatherboy's Avatar
I did a reboot and then it installed fine.
Old 04-24-2008, 08:57 AM   #915
the_crooked_toe's Avatar
the_crooked_toe is an unknown quantity at this point
yeeeeep...download 5.13. its in the help file. dont install modern skin support either. go original skin.
the_crooked_toe is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
