Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 05-15-2008, 10:58 PM   #1126
MGD
MGD's Avatar
MGD is on a distinguished road
Quote: Originally Posted by THEREALRAWPWR View Post
Hi all ,Thanks for everything ,I have everything up and running great! But i have just 2 questions - (1) when I open Xport window it shows at the bottom like it's scanning but never stops,is this normal? My input line is #3 and my outputs are #5,6. and it shows that #5 is checked(dot) but not #6,why? is this normal also? - (2) i notice my red led light on my GPS usb unit keeps on blinking when i shut off or hibernate my carpc.is this normal? Thanks again.........
When it is blinking, that means you have a lock on satellites.
When you open XPort and see only data on the bottom line that means you have a valid signal.
If you run Road Runner and then open up XPort you will see that one other port is getting the same signal. If you run Road Runner AND your GPS program then you will see data going to com5 and com6.
MGD is offline   Reply With Quote
Old 05-16-2008, 12:14 AM   #1127
THEREALRAWPWR is an unknown quantity at this point
Hi MGD, lets clarify a bit .The data that scrolls at the very bottom means it's still looking to lock on ,or it is locked? Also forgot to mention about the list of things that needs to be checked like storage,hubs,etc.-Which ones do ya' check and why? sorry about all the questions on this. I don't know jack about GPS stuff. But I wish this Xport add-on was given some kind of readme file. this sure would of helped. thanx.
THEREALRAWPWR is offline   Reply With Quote
Old 05-16-2008, 12:36 AM   #1128
utd09bry's Avatar
utd09bry is an unknown quantity at this point
ok utd09bry,where do i find these settings? i own a via MII10000 Board....... also anyone know the answer to #1 question???..............
It would be set by your power supply.
For example, I use an M2-ATX. You set the "HARDOFF" delay (meaning, the power supply completely shuts off its output power) by setting jumpers on the power board itself.
If you are using an intelligent power supply that has a shutdown controller, you should have some kind of control over that setting. Just look up whatever literature you can for that model. It is completely independent of the motherboard you are using.
utd09bry is offline   Reply With Quote
Old 05-16-2008, 07:54 AM   #1129
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
The data that scrolls across the bottom is the raw data coming from your GPS unit. If you didn't have a lock you wouldn't be getting data out of the GPS.
I don't think you need to check anything. I never did when I used Xport. Here's a quote right off the Xport home page:
"The device list at the bottom works much like DevCon, and is for devices that have trouble with hibernation. Check only the devices you have trouble with. XPort will stop the driver before hibernation, then start after resume, then retry any driver that fails to start a few seconds later. Use with caution. Some devices may freeze XPort or fail to disable or enable. Each device may add several seconds delay, so it may not be a good option to use. You can test each device by disabling/enabling in Device Manager."
Machinehead is offline   Reply With Quote
Old 05-16-2008, 09:06 AM   #1130
Pseudo Nim's Avatar
Pseudo Nim is on a distinguished road
Hey all,
Do I need a dedicated temperature board to show the CPU gauges? Using a D201GLY2A motherboard, I don't think MBM supports it... does it?
Cheers,
-pN
Doko ni datte, hito wa tsunagatte iru...
My BMW 335xi install
My Subaru Impreza install (now retired...)
Realtime audio freestyle hiphop battles online - www.letsbeef.com!
Pseudo Nim is offline   Reply With Quote
Old 05-16-2008, 09:35 AM   #1131
MGD
MGD's Avatar
Quote: Originally Posted by Pseudo Nim View Post
Hey all,
Cheers,
-pN
As far as I know, DFX comes with SPEEDFAN. If not, Google for speedfan and install it, then change the labels in the skin for your temp and fan speed sensors.
EDIT. Just checked the skin folder. No speedfan. download speedfan (Free) and run it. You will see the sensors where your cpu and speed and temp are located.
Old 05-16-2008, 09:45 AM   #1132
Pseudo Nim's Avatar
Got it, thanks. What do I need to do to make DFX show the values? I went to Menu > Settings > System Diagnostics in the skin but I have 0's everywhere (and I think there's nowhere else that the CPU temperature is shown, right?).
Old 05-16-2008, 09:51 AM   #1133
Pseudo Nim's Avatar
Um... here's another one from me. Would anybody have any idea why the bottom function keys have become numbers?...
[EDIT] a reinstall of the skin seems to have fixed it. Weird.
Old 05-16-2008, 10:04 AM   #1134
VmtSquad's Avatar
VmtSquad is an unknown quantity at this point
Sorry if it's a repost, I wanted to check if anybody did modify IG to display bigger buttons as in this thread
I run in 1024 reso so the iG buttons are really to small for easy usage. I really need to get those buttons bigger!!
Thanks!
VmtSquad - I sold my soul to Honda!
Final Install
CarPC progress: 95%
VmtSquad is offline   Reply With Quote
Old 05-16-2008, 10:09 AM   #1135
barnyard is an unknown quantity at this point
You need to reinstall the DFXFont
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
barnyard is online now   Reply With Quote
Old 05-16-2008, 10:11 AM   #1136
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Thanks!
Even with the UMPC version?
treetop777 is offline   Reply With Quote
Old 05-16-2008, 10:12 AM   #1137
Pseudo Nim's Avatar
Thanks!
Are you using iGuindance UMPC instead of the usual one? It has larger buttons/fonts.
Oooh, gotcha. Thanks! Something must've overwritten it.
Old 05-16-2008, 10:17 AM   #1138
Raw Wave
treetop777's Avatar
It's best to try to go by the instructions in the help file and if you get stuck, then ask specifics.
Old 05-16-2008, 10:37 AM   #1139
Pseudo Nim's Avatar
Shame on me - you're quite right, it's right there in the help. Thanks.
Old 05-16-2008, 10:41 AM   #1140
VmtSquad's Avatar
So I basically need to download the UMPC version or is there a simple patch that we can install ??
Final Install
CarPC progress: 95%
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
