05-28-2008, 03:34 PM
#1216
Super Moderator
Cameron, I wish you the best of luck  Getting a phone to work with the PC is something I gave up on long ago.. I just use a parrot bluetooth device (google it) hard wired into the the sound system in my car. I would think that you would have better luck posting this in the FreePhone thread, as it really is not a skin issue.
05-28-2008, 03:43 PM
#1217
Quote:
I am trying to get freefone to work with my motorola q. I am on Verizon. I have a bluetooth dongle that goes through Widcomm's audio gateway. Is there a way to change the comport on freefone? Also what other things do I have to do to get it to work?
Thanks,
Cameron
Cam...
I just recently tried to do this same thing with my XV6800 pocket pc. no love. as of yet, there are no software solutions to truely run your computer via your phone. I tried the "remote control" program and it wouldnt even install on a friends phone which they said it would work.
good luck man...i gave up just as John did.
05-28-2008, 04:35 PM
#1218
I guess you can't have it all. Oh well...Let me know if you hear anything..
Thanks for the response.
05-28-2008, 04:39 PM
#1219
I was looking at the text file for freefone and can't find the comport like the standalone version. Is that something I can change in digitalfx?
05-28-2008, 05:42 PM
#1220
Raw Wave
Quote: Originally Posted by nst6563
So I've created new .skin files (Garmin_WIDE.skin - based loosely off the IGuidance_WIDE) which allow more screen area for the Garmin app. Also removed the buttons which don't offer any function to Garmin (which was basically all of them for now). Edited the exectbl.ini with the following lines (section listed above the line):
/----------------- Dynamic Menu Buttons -----------------------
/ RR Command to execute when button is pressed
"MyApp48","Load;Garmin_WIDE.skin;Garmin;C:\GarminM obilePC\Que.exe;Garmin"
/----------------This is the label that is displayed on the Main Menu Buttons ----------------
"SetAppLabels","SETVAR;ButtonLabel;=MUSIC<<=RADIO< <=VIDEO<<=DVD<<=XM<<=SIRIUS<<=PHONE<<=UTILITIES<<= RIP CD<<=TV<<=WEATHER<<=PICTURES<<=GAMES<<=GAUGES STATS<<=BROWSER<<=SETTINGS<<=GPS<<=GPS<<=GPS<<=GPS <<=GAS PRICES<<=CAMERA<<=TRAFFIC CAMS<<=CALENDAR<<=MEDIA COPY<<=COLORS<<=LOTTO<<=NET RADIO<<=RADAR<<=SCANNER<<=HD RADIO<<=LAUNCH<<=SKINS<<=SYS DIAG<<=G. EARTH<<=Lyrics<<=JUKEBOX<<=TASK MAN<<=G MAPS<<=THEME<<=WIRELESS<<=THEATERS<<=RRMEDIA<<=CNN NEWS<<=DAYTIME<<=GPS<<=CLEAN SCREEN<<=Garmin"
/ These are the labels for the application that will show
/ up on the screen that gives the selection of buttons to choose from
"SetCommandLabels48","SETVAR;MyApp48LB;Garmin||Set CommandLabels49"
however being the total noob to skin editing whenever I run RR and make a button for Garmin and then push said button, it loads the skin editor...
clues? Garmin seems to embed fine...I've just run into a road block with this skin editing issue.
:EDIT: Nevermind...I got it
I'll post a screenshot in a few
Excellent work! Would you mind posting the .skin file and a more polished how-to; John will pay you!
05-28-2008, 06:31 PM
#1221
I have also made a larger gps screen. I use with it with iGuidance.
I started with the StreetsTrips skin file that has the regular playback audio buttons at the bottom.
I also edited the png file to remove the top row of buttons as I find the menu buttons inside iGuidance more than adequate, and the added screen space for the program is what I am after.
I also edited the exectbl.ini the same way as in the above post, to add a button for the program.
Hope this helps along the way.
PS. Actually I use this as my replacement for the regular Iguidance wide skin, but have also used it for several of my own embedded programs, where I create my own button to add into the menu system of DFX3
05-28-2008, 07:20 PM
#1222
sure thing
I'm leaving for Houston tomorrow morning but will try to post it up tonight.
btw, used it while out today and I could bounce back and forth between iG and Garmin without a hitch. I like the way the maps look on iG better, but the directions/routes that Garmin picks seem to make more sense. iG would zig-zag me through entire neighborhoods to get from point a to b...Garmin tends to stick to the more major traveled roads which I think is better when someplace you've never been.
:EDIT: Here's the zip file with the skin files and a readme.txt. Hopefully that's simple enough for any ol' noob skinner to figure out...'cause I did
Reason: removed attachment...newer revision next page
05-29-2008, 11:17 AM
#1223
So i was bored today and flelt like going a little glasy.
JohnWPB, if you give me permission i can upload the png here if you want to or i gould provide it to you and you could include it if you so wished.
I am not 100% done yet but here it is so far:
--me
Reason: Put a carriage return between the images to seperate them
05-29-2008, 11:22 AM
#1224
Raw Wave
Much Obliged.
05-29-2008, 01:40 PM
#1225
The Curator
--me
Wow... I think I really like the way that looks.
05-29-2008, 02:06 PM
#1226
Super Moderator
Yea, that does look really nice! I would at least love to have a copy of that background to include with the skin, if you do not mind of course
05-29-2008, 06:33 PM
#1227
Raw Wave
Darn! That CPU is about to blow-up!
05-29-2008, 07:14 PM
#1228
The Curator
I think that I can even here it calling out....I think I can, I think I can, I think I can....
05-29-2008, 07:17 PM
#1229
that CPU HAS LOWLIFE
05-30-2008, 02:32 AM
#1230
yar, for some strange reason RR does not run to well in a virtuallised scenario its ok'ish in VMware but does not handle to well in VirtualBox.
Any yes I'm a unix boy so no i cant run it natively in windows.
--me
| Thread Tools |
| Display Modes |
Linear Mode
