Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 05-31-2008, 03:17 AM   #1231
flat6 is an unknown quantity at this point
Question possible suggestion
Hey JohnWPB,
DFX is simply fantastic!
One possibility (and hopefully this is the right place to suggest an idea):
In the XM window I can save the current artist/song to a textfile with a button. It would be mighty cool if the Jukebox could use that list to fetch? Sometimes I'm not "online" when driving, so the ability to fetch later in Jukebox might also be desireable?
Is that even possible?
thx for all the great work!
flat6 is offline   Reply With Quote
Advertisement Sponsored links
Old 06-01-2008, 04:26 AM   #1232
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Ok, that glassy look above by nitra is in the works That is exactly what I wanted the skin to look like when I started 3.0. Hopefully all works out, and that will be an alternative to the way the skin looks currently.
As far as tagging songs, and saving them in the jukebox, that is an idea for sure, but at the same time not one I was wanting to peruse. The jukebox was actually something I did for myself, and really did no mean to release to the masses. If someone wants to take over that area, and release something to go along with the skin, that is fine, but not something I personally am going to work on.
As yet another note Thanks to all that contributed to the "beer fund" with the donations to PayPal, I put it to good use last night
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 06-01-2008, 01:32 PM   #1233
Maheriano will become famous soon enoughMaheriano will become famous soon enough
I can't download the file.
"[path]\DigitalFX3 could not be saved because the source file could not be read."
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 06-01-2008, 03:18 PM   #1234
Super Moderator
JohnWPB's Avatar
I checked the FTP server, and the file is still in place, and I just tested the Download here with Fire Fox, and it is working ok.
Old 06-01-2008, 05:09 PM   #1235
insaneramman's Avatar
insaneramman is an unknown quantity at this point
Cool So far So Good...
DL'd and installed today. Great skin. Still some tweaking to do - mitches cable on the way and garmin to install. John great job once I get all of it working I will do my best to look out for your effort.
insaneramman is offline   Reply With Quote
Old 06-01-2008, 06:24 PM   #1236
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
Old 06-01-2008, 06:47 PM   #1237
Cool ^^^^^^^Works^^^^^
I went to Johns site and DL'd . It work for me Prob might be on your end. J/K
Also nst6563 DL'd your Garmin wide.zip in the readme you said add these lines in the Exectbl.ini file would that be in the same area as the ig parts? If so before...after? Got the software just to dang hot outside to install.
Old 06-02-2008, 02:53 AM   #1238
Super Moderator
JohnWPB's Avatar
test
The Forum screwed up and put posts in front of the first post in this thread. I had to move some things around, and lost the post by Pseudo Nim, so it follows here:
Pseudo Nim Wrote: I found two strange bugs with the skin (or RR? Forgive me if these are RR bugs). Anybody know if there are fixes or if there is something I should do?
1. When I click "Browser", I cannot scroll through directories, I have to first _tap_ the directory window, and only AFTER that it becomes possible to use the scroll arrows (seems to be a focus issue of some sort).
2. At times, DFX just stops responding to mouse clicks. It's as if the whole interface just locked. Absolutely nothing can fix it - the computer needs a reboot (or, if you have a keyboard connected, Windows Key + U + R + Enter (shutdown/restart).
1. Hmmm I have not seen that happen here, not sure what could cause that, but it does sound like a focus issue. The strange part is the button codes "talk" to the list, so are supposed to "bring it into focus"
2. Can you hit Ctrl Alt Del and see what the CPU is doing, and what is causing it?
Old 06-02-2008, 02:31 PM   #1239
drewbp is an unknown quantity at this point
My question is when is the next update coming. I know your update is based on Blue's media browser release date, but from reading there are some other cool features that are incorporated in the rest of your release.
Thanks.
drewbp is offline   Reply With Quote
Old 06-02-2008, 03:39 PM   #1240
nst6563 is an unknown quantity at this point
I updated the skin slightly, added the current song in the format Artist - Title to the right side of the lower screen in the un-used space.
@ insaneramman - The lines go into the sections of the ini that they are in the readme. Not sure how else to explain it...
/----------------- Dynamic Menu Buttons -----------------------
/ RR Command to execute when button is pressed
is a section as is
/----------------This is the label that is displayed on the Main Menu Buttons ----------------
just like
/ These are the labels for the application that will show
/ up on the screen that gives the selection of buttons to choose from
in your ini, look for those sections, and the code will go in there, at the bottom of the section usually. In the SetApplabels line, you'll basically need to add <<=Garmin at the end.
nst6563 is offline   Reply With Quote
Old 06-02-2008, 08:51 PM   #1241
Cool Thanks
Nst6563 I think I understand. Just put the lines of code in under the headers are listed-
"MyApp48","Load;Garmin_WIDE.skin;Garmin;C:\GarminM obilePC\Que.exe;Garmin||ACTIVATE;Garmin Mobile PC||SENDKEY;{ESC}"
These lines would go under the Dynamic Menu Buttons part of the ini. file right?
Also I can't get the config to run in DFX or out it's me right? Just locks up (cpu 100%) and freezes. Anywho got all but garmin installed and all is working.
Old 06-02-2008, 09:12 PM   #1242
only the line without the / would go at the bottom of the Dynamic Menu Buttons. I included the header so people could tell what section to add the lines.
as for your config, I never run mine inside RR. Always drop to desktop, run, then save and restart RR.
Old 06-03-2008, 12:51 PM   #1243
Wink Thanks
Nst6563 I've tried in and out of the skin still no luck. I'm gonna reinstall RR today. I'm sure it's something I done. The tweak gene at it again( the part of SOME people that can't leave well enough alone). Still love RR and DFX. Oh, and thanks for the help with garmin after reinstall and a check to make sure all is still working, it's going in.
Old 06-03-2008, 01:09 PM   #1244
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
I have made a quick util to edit the dynamic dfx buttons very easly w/o even opening the skin's exectbl fiile..
When I have a chance I'll have to post it up....
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 06-03-2008, 06:04 PM   #1245
Red face Got Garmin?
nst6563I got it all reinstalled and all of my stuff still works NOW I added you lines of text in the spots you told me and put the skins in the dfx 3.0 folder but...It's a no go I am at a my wits end.
Last edited by insaneramman; 06-03-2008 at 08:44 PM. Reason: No More Hair to pull out.
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
