Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 06-07-2008, 05:19 PM   #1291
Maheriano will become famous soon enoughMaheriano will become famous soon enough
Quote: Originally Posted by TiBook_Swe View Post
I also got the problem with the vertical-bar instead of the skin? I have the latest version of RoadRunner installed but still it's not working??? I donwloaded the skin to try it on my home-computer instead of my car-computer, but there the installation stops at 30% (just like someone else got). But I only want a solution to get it to work in my car. This skin seems awesome by the pictures, so ofcourse I want to try it out .
i'm assuming the verical bar is about 30% the way across the screen and is mostly green or transparent? You need to update your flash engine. I've seen that before.
But the download stopping at 30%....YES! Someone else with my problem and I don't have another computer to download it on, just my Blackberry. I could try that I guess.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 06-07-2008, 06:15 PM   #1292
TiBook_Swe is on a distinguished road
I've got everything to work now...Suddently it worked (didn't change anything )
But just so u know, it's not the download hat stops, only the installation-wizard.
This skin seems pretty cool now when i have tried it for like 5-10 minutes
TiBook_Swe is offline   Reply With Quote
Old 06-09-2008, 12:23 AM   #1293
utd09bry's Avatar
utd09bry is an unknown quantity at this point
Quote: Originally Posted by bambam View Post
Hopefully this is a quickie. I've looked all over trying to find an answer to this but without any luck.
Simple question, I want to train Dragon Dictate to send a command to RoadRunner (obviously, DigitalFX skin) but don't have any idea what text to send.
What should Dragon Dictate send to RoadRunner, say for instance, to switch to GPS screen?
Any help is appreciated and thanks in advance to all who reply.
Edit: I tried the builtin voice control and had no luck so that is why I am trying to use Dragon Dictate which seems very accurate from my "training" sessions...
you might want to start a new thread for that, cause it's really not DFX dependent, it's RR.
utd09bry is offline   Reply With Quote
Old 06-09-2008, 08:37 AM   #1294
kbreeden
Quote: Originally Posted by Maheriano View Post
Can someone please host this download on a mirror? I've been trying to download it for days and always get the same error.
Are you using Hughes satellite for Internet by any chance? Back when I was using that I couldn't download from the site either. Like you, I was the only one having the problem. I never figured out what it was about John's site that Hughes didn't like. If I were you, I would take a flash drive to a friend's house and try from there.
kbreeden is offline   Reply With Quote
Old 06-09-2008, 09:25 AM   #1295
kbreeden
Blue,
I'm getting this error message when running the button editor.
(I did make the change to the first line of exectbl per your post above.)
Old 06-09-2008, 11:20 AM   #1296
GhostRiderDad's Avatar
GhostRiderDad is an unknown quantity at this point
I had an error in DFX 3 that was strange. I tried to access the mileage part and when I tried to enter something, I got what looked liked a transparent keyboard with nothing on it. Is this a known bug?
GhostRiderDad is offline   Reply With Quote
Old 06-09-2008, 12:25 PM   #1297
HuntingKnightSM is an unknown quantity at this point
Quote: Originally Posted by kbreeden View Post
Blue,
I am getting this error as well
1997 Pontiac Bonneville RIP 10/29/09
1997 JEEP Grand Cherokee
Software: (|||||||---) 70%
Hardware: (|||||||---) 70%
Car PC Install (----------) 0%
HuntingKnightSM
HuntingKnightSM is offline   Reply With Quote
Old 06-09-2008, 01:36 PM   #1298
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
You guys must have changed something in your skin's exectbl file as that line should have fixed it. I'm panning on giving it some more AI (Artificial Intelligence), some rework is needed.
One of you attatch your skin exectbl.ini file, and I'll see about a quick fix till I add that AI.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 06-09-2008, 01:46 PM   #1299
kbreeden
Blue, this message is different than the one that comes up if you don't change the first line.
I had made some manual button changes through exectbl months ago. Does your proggy require that exectbl.ini is totally in its original form except for the first line modification you mentioned?
Here's my file.
Old 06-09-2008, 01:49 PM   #1300
Here you go
Here you go Blue ZX3. I made it into a txt file to upload it.
HuntingKnightSM
Old 06-09-2008, 02:53 PM   #1301
funkyphil's Avatar
funkyphil is an unknown quantity at this point
Anyone having this problem, because I am still!! lol
I still can't get the GAS Prices to work or the Theater listings to work. I even tried to uninstall and reinstall it. Any Ideas??????
Phil
www.philscustomcomputers.com
funkyphil is offline   Reply With Quote
Old 06-09-2008, 03:03 PM   #1302
The Curator
Blue ZX3's Avatar
Thanks guys, I will check those...
I did change my mind, instead of a quick fix I'm going to just fix it as a whole. 1/2 done already!
@kbreeden
The one that is currently posted, yes. The next one will not matter as the AI will compensate for it.
For you to fix untill next update, these need to be in this order, can be located anywhere, just keeping the order..
#1
"SetApps","SETVAR;AppToRun;MyApp01<<MyApp02... .."
#2
"SetAppLabels","SETVAR;ButtonLabel;=MUSIC<<=RADIO. ...."
#3
"MyApp01","AUDIO"
"MyApp02","XM" ... ect
#4
"SetCommandLabels01","SETVAR;MyApp01LB;Music||SetC ommandLabels02"
"SetCommandLabels02","SETVAR;MyApp01LB;Music||SetC ommandLabels03" ... ect
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 06-09-2008, 05:32 PM   #1303
rsrblade is an unknown quantity at this point
Blue,
Blue Looking over the 2 exectbl.ini files submitted by kbreeden and HuntingKnightSM and comparing with my own exectbl I found that the
"SetApps","SETVAR;AppToRun;MyApp01<<MyApp02<<MyApp 03<<MyApp04 runs out to <<MyApp51" but the DynamicMenuButtons list only goes to MyApp47. If I delete MyApp48 thru MyApp51 the button editor works perfect. Hope this helps. ;-)
Okay premature exhileration. Making the above change does allow the editor to open, however a new button when created does not show its name in the "hold button" screen after running the editor. Also the exectbl.ini file has to be manually edited for the new button to work.
rsrblade is offline   Reply With Quote
Old 06-09-2008, 05:49 PM   #1304
The Curator
Blue ZX3's Avatar
Sorta, just reminds me that I also have to add some error trapping to catch unequal sets.
There should be an equal set of all the button lines.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 06-09-2008, 06:22 PM   #1305
kbreeden
Thanks, Blue.
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
