Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 06-09-2008, 06:26 PM   #1306
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Quote: Originally Posted by rsrblade View Post
Okay premature exhileration. Making the above change does allow the editor to open, however a new button when created does not show its name in the "hold button" screen after running the editor. Also the exectbl.ini file has to be manually edited for the new button to work.
Um...silly question, did you use the save under file? That is when the changes get saved.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 06-09-2008, 09:48 PM   #1307
rsrblade is an unknown quantity at this point
...Honest enough question. Yeah, I clicked on file then save when I edited the exectbl (I assume this is the file you're asking about) When I first create a new button, it shows up in the 'holdbutton' menu as a blank button. Not till after I added DynamicMenu Button 'MyApp48', a corresponding 'SetCommandLabels48', an entry for SetApps of 'MyApp48' and its SetAppsLabel did the button show up correctly in the "HoldButton' menu. I even tried opening the RR app under settings and did a 'save and restart' thinking that would fix the issue.
Okay, I see now. Dont click on 'done' till after clicking 'File and save' in the button editor. Dohh!
Thanks Blue
rsrblade is offline   Reply With Quote
Old 06-10-2008, 09:57 AM   #1308
The Curator
Blue ZX3's Avatar
No, just like any other program, you only need to save when your done. Hopefully I'll have the update done today post it..
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 06-10-2008, 10:35 AM   #1309
LinuxRacr's Avatar
LinuxRacr
One problem I've been having is that when my carputer comes back from hibernation, I don't have any of the channels showing up in the list, but I still hear music. The same thing happens when playing mp3 music. The song list doesn't re-populate after hibernation. Anyone know why this happens?
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Current build! Here
Completion Progress Bar: [*********99%]
LinuxRacr is offline   Reply With Quote
Old 06-10-2008, 10:39 AM   #1310
dmistry is an unknown quantity at this point
I get the play list I just do not get sound when I resume from hibernate until I click either sirius or music
dmistry is offline   Reply With Quote
Old 06-10-2008, 11:12 AM   #1311
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
(disable iLists) Search for iList and hibernation
Enforcer is offline   Reply With Quote
Old 06-10-2008, 11:13 AM   #1312
LinuxRacr's Avatar
LinuxRacr
Thanks. I have been searching for a while, and hadn't came across that.
Current build! Here
Old 06-10-2008, 11:47 AM   #1313
The Curator
Blue ZX3's Avatar
Ok, here is the update that has AI added...
If no one has problems with this one I'll update the previous posting
Sections listed above can now be in anyorder anywhere within the file!!
Happy Button Modding...
[Edit]
See either posting below or posting above for current version
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 06-10-2008, 01:18 PM   #1314
cameronlazzari is an unknown quantity at this point
Quote: Originally Posted by JohnWPB View Post
Main Menu with Visualizations turned on:
How do I set up the visuals like what you have in your video demo?
Last edited by JohnWPB; 06-10-2008 at 01:51 PM. Reason: Removed the ENTIRE first post being quoted for the 3rd time this month.
cameronlazzari is offline   Reply With Quote
Old 06-10-2008, 01:28 PM   #1315
The Curator
Blue ZX3's Avatar
EDIT YOUR POST AND REMOVE THE QUOTE!!
We do not need a repeat of the first post, and if you look in the included help file you will find your answer to that question and possible more that you will have in the furture.
Thanks,
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 06-10-2008, 02:31 PM   #1316
HuntingKnightSM is an unknown quantity at this point
DFX Menu Button Editor Runs (But)
Ok it ran ok but after I saved and Exited it. But when I opened RR all of the menu buttons were blank. Do I need to set up every button?
1997 Pontiac Bonneville RIP 10/29/09
1997 JEEP Grand Cherokee
Software: (|||||||---) 70%
Hardware: (|||||||---) 70%
Car PC Install (----------) 0%
HuntingKnightSM
HuntingKnightSM is offline   Reply With Quote
Old 06-10-2008, 03:29 PM   #1317
drewbp is an unknown quantity at this point
I opened up the button editor and all of the buttons were blank. Which means it is not reading what is already in the skin .ini. I would assume that this would be the case everytime it is opened, which would not be good since all the buttons would have to be put in each time the button editor is opened.
I also had to add the line: / DigitalFX Skin Code & Commands to get it to read my .ini, even though I downloaded the latest .exe which I thought fixed this.
Thanks.
drewbp is offline   Reply With Quote
Old 06-10-2008, 04:52 PM   #1318
randyre is an unknown quantity at this point
Thanks.
Same thing here.
randyre is offline   Reply With Quote
Old 06-10-2008, 06:06 PM   #1319
The Curator
Blue ZX3's Avatar
Will have a look as soon as I get home from work today...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 06-10-2008, 09:24 PM   #1320
insaneramman's Avatar
insaneramman is an unknown quantity at this point
Cool Wow
Blue you got way more patience than I do. I would have chucked this one a long time ago. You ROCK
insaneramman is offline   Reply With Quote
Advertisement Sponsored links
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
