Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 06-13-2008, 07:00 AM   #1336
kbreeden
Quote: Originally Posted by Cotjuh View Post
hey guys, i've tried to reach you on msn,
but what my question is, is that i get a very small vertical ahm.. stripe instead of the full skin.. Is it possible it has to do something with my set up?? I mean memory and CPU??
Its a pentium 4 with 337mhz ddr memory.. I know it's not much but it did all i needed it to do.. untill now..
Make sure you have the latest version of RR (12/07) and run RRConfig. Usually this problem results where a valid rr.ini file is not found by RR or a valid skin is not found by RR. Running RRConfig creates the necessary rr.ini file. This is not related to any problem with your hardware.
kbreeden is offline   Reply With Quote
Old 06-13-2008, 12:53 PM   #1337
Cotjuh is an unknown quantity at this point
well.. very strange.. i found that i posted in the fx3 skin.. and.. i downloaded this one..
installed it.. and.. runs without (to much) problems..
some things arn't running as i think they should.. but thats acceptable and possible to change :P thx kbreeden (Y)
Cotjuh is offline   Reply With Quote
Old 06-13-2008, 08:21 PM   #1338
stonestatue's Avatar
stonestatue is on a distinguished road
Quote: Originally Posted by Blue ZX3 View Post
Have you used the one from the second posting of the editor?
Yes, that is the one I tried.
Self proclaimed environmentalist.
stonestatue is offline   Reply With Quote
Old 06-13-2008, 09:05 PM   #1339
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
I don't know if by mistake, I miss read your post wording wrong, this is to be placed in the DFX folder and not the folder containing the DFX skin folder, like as in the Skins folder.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 06-13-2008, 09:57 PM   #1340
I placed the file in "C:\Program Files\RoadRunner\skins\DigitalFX 3.0".
Old 06-13-2008, 10:23 PM   #1341
That is what comes up.
Old 06-13-2008, 10:30 PM   #1342
HuntingKnightSM is an unknown quantity at this point
stonestatue
Open the exectbl.ini file and replace the first line with this.
Code:
/ DigitalFX Skin Code & Commands
1997 Pontiac Bonneville RIP 10/29/09
1997 JEEP Grand Cherokee
Software: (|||||||---) 70%
Hardware: (|||||||---) 70%
Car PC Install (----------) 0%
HuntingKnightSM
HuntingKnightSM is offline   Reply With Quote
Old 06-13-2008, 10:41 PM   #1343
Did that, now this comes up:
"Line -1: Error: Array variable has incorrect number of subscripts or subscript dimension range exceeded."
Old 06-13-2008, 11:37 PM   #1344
bambam's Avatar
bambam is on a distinguished road
I'm just about set to put my pc in the car but I have one last problem within DFX.
First off, I am using WinDVD as an external video player because I couldn't get the internal to work. The problem now is that when I have a video file selected, pressing the play button does nothing. If I press the Sel option on the left, that does nothing. The only way I can get it to play is to double click on the file name in the list.
I changed the skin to BVM2 for testing and everything worked great. In fact, if I selected a folder that contained movie(s) and pressed the play button, it would play all the movies within the folder (the way I thought it should work).
I noticed that there is a windvd skin in the DFX folder. Should I use this skin and if so, what is the easiest way to set it up?
I did a search in this thread on WinDVD and it came up with nothing.
Thanks in advance to all responses
EDIT:
I looked at the BVM2 button code for the play button and then went into the DFX video browser skin and changed the PLAY button to B,299,525,100,73,"SELECT","SELECT" and everything works great. Hope this helps others.
Now, just for the hell of it, I'd trying to find how to use the windvd skin. I tried changing the names to video_player#### but no go, it messed up everything.
"Imagination is more important than knowledge." -AE
bambam is offline   Reply With Quote
Old 06-14-2008, 11:26 AM   #1345
The Curator
Blue ZX3's Avatar
I have replaced the newest version with the first posting, so try it again.
@stonestatue
If you still have issues, you can attach your dfx exectbl.ini file and I'll check whats the hang up.
@HuntingKnightSM
That is no longer needed in the second version, as I took out that requirement.
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 06-14-2008, 04:20 PM   #1346
Where is the link for the program?
Old 06-14-2008, 04:28 PM   #1347
cameronlazzari is an unknown quantity at this point
EDIT:
Use Winamp..just select the exe file for external apps
cameronlazzari is offline   Reply With Quote
Old 06-14-2008, 06:12 PM   #1348
The Curator
Blue ZX3's Avatar
For the time being... I added it to my sig
See below...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 06-14-2008, 06:54 PM   #1349
Alright, it works now. Thanks.
Old 06-15-2008, 10:06 AM   #1350
LinuxRacr's Avatar
LinuxRacr
Quote: Originally Posted by mnickolson View Post
One Question. How to make the clock on the main pages above the logo larger?
Anyone ever answer this question? I'm now wondering the same thing.
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Current build! Here
Completion Progress Bar: [*********99%]
LinuxRacr is offline   Reply With Quote
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
