06-17-2008, 10:32 PM
#1366
I'm using winamp 5.13
Updated to latest official release of RR and still experiencing...
-'up dir' goes to root rather than back up one level. Am I supposed to set my winamp or RR config in a certain way for this to work properly? Or have a specific plugin installed?
- Searching using 'ABC' function while in albums doesn't work. Just keeps jumping to the same album - again do I have to set specific parameters or have a plugin to make this work properly?
- Also still unable to create, modify, save or load playlists. I have the path set in RR.Config
350z Roadster,
Lilliput 7" touch, Opus 250w, 160gb, AMD3500+, 1gb ddr400, geforce 6500 pcie, SiRF Star 3, Wireless G, Sprint CDMA, Bluetooth, Creative iCam Pro, RR, iG 4, Digital FX 4.0
06-18-2008, 11:20 AM
#1367
Can someone help with playlists and star rating
I've used the star rating for about 30 songs. I want them to play when I click on the 4 star rating playlist button but nothing happens.
I click the 4 star playlist button and nothing loads so I have to revert back to loading all songs.
Not sure if something needs to be done to get this to work.
Is it necessary to have a certain version of winamp? I'm using 2.95.
Some help would be appreciated. Thanks.
VoomPC, VIA C7 1.5 Ghz, 7" Newision LCD, 80 Gig WD 5400 RPM Laptop Drive, M2-ATX, RoadRunner, iGuidance, Freedom 2.0, AT&T Natural Voice Hot Babe Audrey. All wrapped up in a piece of crap Suzuki Grand Vitara.
06-18-2008, 11:28 AM
#1368
I have some more details on these issues...
'up dir' works when browsing through folder view, but not when browsing through meta-built lists (artist, album, genre) is that supposed to be that way?
Still no joy searching by letter in album view, do my tags have to be scanned in a specific way for this to work?
Tried searching the playlist issue but no joy. I have a single playlist in c:\program files\RoadRunner\playlists\ and I have that path chosen in RRConfig for playlists but nothing shows up in the 'Manage Playlists' window? Also can you set a default playlist?
350z Roadster,
06-18-2008, 11:35 AM
#1369
treetop777, the equalizer settings worked great for me this morning. Thx!!
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Current build! Here
Completion Progress Bar: [*********99%]
06-18-2008, 11:43 AM
#1370
Raw Wave
add m3u to your audio file types in rrconfig; playlist should then show.
06-18-2008, 12:39 PM
#1371
Thanks, just did that and I can see them now great!!!
350z Roadster,
06-18-2008, 01:36 PM
#1372
Did you set the playlist path in RRconfig?
If you cant DODGE em, RAM em.
06-18-2008, 02:56 PM
#1373
I've been searching through this thread, and all I can find is info on XM Favorites.
Is there a provision for Sirius Favorites? I see that the "sirius.skin" file points to the file "XM_Favorites.skin" for favorites... Do we just modify the XM_Favorites.skin to use with Sirius? The only issue I see with that is the *.png files that are being sourced for the buttons (XM_Favorites_Off.png and XM_Favorites_On.png). Are there any Sirius counterparts to be used?
Current build! Here
06-18-2008, 03:03 PM
#1374
No there isn't and provision for Sirius Favorites, I made my own a while back. It's a a pain in the rear to say the least.
06-18-2008, 03:05 PM
#1375
I'm guessing the developer of this skin doesn't use Sirius, but XM?
Machinehead, does your sirius favorites work with this release of DFX?
Current build! Here
06-18-2008, 03:11 PM
#1376
Actually he doesn't have Satellite radio at all.
They did work, if I can fine the files when I get home tonight, I'll try to remember to post them.
06-18-2008, 03:21 PM
#1377
Thx.
Current build! Here
06-18-2008, 06:11 PM
#1378
Raw Wave
Try installing Winamp 5.13 and activewinamp (included in the download), it should work then.
06-19-2008, 09:21 AM
#1379
1. search the thread. I asked about this in probably the first 10 pages or so. BlueZX3 has the answer for that. They have been disabled for the moment in anticipation of the database feature implemented in the next release
2. If you want the star ratings now. Make sure your playlist path is configured in RRConfig. might even go ahead and create 1star.m3u 2star.m3u 3star.m3u, etc to make it work properly. find the post earlier in the thread Blue gave the answer to in uncommenting some lines to have it working properly once again
06-19-2008, 03:42 PM
#1380
Change "MAINBUTTON"
Okay so where is the deal, my XM and HD radio are on the same input, and the XM is louder then the HD Radio, so when I change between the different audio signals the volume level makes my eyeballs shake. I found some script " &...||SETVOL;Line In;90& " So I would like to make it so that when I click the HD Radio button, or the XM button on the menu screen it loads the skin, and sets the line in volume to a predetermined amount.
THANKS FOR THE HELP GUYS!!
2001 Camaro SS #2070
| Thread Tools |
| Display Modes |
Linear Mode
