Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 07-03-2008, 09:22 PM   #1411
NIKFCSM is an unknown quantity at this point
Quote: Originally Posted by Blue ZX3 View Post
For the weather, you need the newest RR. The milage&trip screens were not finished b/c John couldn't get the mileage plugin working as the documentation for it wasn't updated when Festy updated the plugin, so its kinda hard to figure out what are the correct button & label codes to use.
RR-last version
Thx, but on my home PC i see "Weather" :/
NIKFCSM is offline   Reply With Quote
Old 07-04-2008, 03:02 AM   #1412
lewcamino is on a distinguished road
I am using iGuidance UMPC 4.0, RR 11-2-07 (but I downloaded the new .exe 670 KB), and DigitalFX 3.0 (of course)
When I click save location I get the dialog box (Current Location) with the info on where I am at and the save button. When I click save the window goes away. When I go through the same proccess in iGuidance (stand alone UMPC) after I click save in the "Current Location" dialog box a second dialog box (Add to Favorites) comes up and I am able to Edit the name of the location or simply click OK to save.
So long story short, I cant get it to work in RR.
I search around a bit for this and had a look at the .skin file myself but I dont see why this is not working.
Thanx, Lew
I am the stig's cousin.
lewcamino is offline   Reply With Quote
Old 07-04-2008, 03:39 AM   #1413
Alright. I have hacked around with this for a few minutes and found a "work around".
I commented out this line like so
Code:
/B,1,450,75,72,"SENDKEY;c",
and added this line
Code:
B,1,450,75,72,"SENDKEY;%{f}{l}"
This will go straight to savign the location (not bring up the current location info)
This works okay, but it would be nice if it worked properly the other way. ex. Bring up the info and then click save and bring up the dialog to edit the name and/or just save it.
Edit:
I have settle on this:
Code:
B,1,450,75,72,"SENDKEY;%{f}{l}",@SENDKEY;c@
If you press "save location" it will just bring up the "Add to favorites" and you can do so (it works). If you press and hold "save location" it will bring up the current location dialog (selecting save still does nothing).
It works, Lew
Old 07-04-2008, 10:02 AM   #1414
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Good info. Thanks.
treetop777 is offline   Reply With Quote
Old 07-04-2008, 10:53 AM   #1415
nasa is an unknown quantity at this point
Hi gang,
I'm trying to get my SN working and have some questions:
1. when I enter a onskinstart command line in rrconfig, DFX menus button's don't get text and don't switch to their respective functions. I noted that there's a exectbl file within the DFX skin folder, does this file have to have the additional onskinstart command listed in it? Or must I somehow append the command to the one already listed.
2. Similarly, if I want to have the SN send commands (to say, switch to a different screen) where do I place those?
nasa is offline   Reply With Quote
Old 07-04-2008, 11:23 AM   #1416
Raw Wave
treetop777's Avatar
What in the world is a "SN" - Snot Nose?
But yeah, you can't have onskinstart in two places; add your new command to the back of DFX's.
Old 07-04-2008, 11:25 AM   #1417
Thanks treetop,
SN = Space Navigator.....
Old 07-04-2008, 12:17 PM   #1418
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
best idea is keep everything in the DFX exectbl, look for the onskinstart line in there, and add your bit to the end of it divided by ||.
remove any lines you have addd to another exectbl and just use John's 1 inside his skin folder.
as for any cmds you want to add , add to the same file, would be best on a separate line.
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 07-04-2008, 01:46 PM   #1419
Is there a listing of commands the RR / DFX would respond too?
ie: if I send a command named "Audio" would RR/DFX translate that into loading the Audio screen?
Old 07-04-2008, 01:57 PM   #1420
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Skincommands.txt in the RR folder.
Machinehead is offline   Reply With Quote
Old 07-04-2008, 02:25 PM   #1421
THE EXPERIMENTER
carputer1's Avatar
sorry this is not a flame , but 300 post's and you have just descovered skin cmd's
lol.... sorry don't mean to put you down , just made me giggle, and remeber what i was like when i started out.
again this is not a flame
Links
Old 07-04-2008, 03:09 PM   #1422
Carputer,
I have no issue with your statement, all it says is I can be a little slow (comes with old age).... Plus, I don't get to work on this as much as I would like. That said,
I followed your suggestion and changed the line to look like this:
"OnSkinStart","ExtraPrograms||SetTempBackground||S etApps||SetCommandLabels01||SetAppLabels||SetIcons ||PresetLoader||IGSettingLoader||SetLottoBlank||SE NDMSG;SpaceNavigatorDriver;HID;SpaceNavigator;Led on"
This leds to both RR and the SN drivers crashing... Did I misunderstand your suggestion?
Old 07-04-2008, 03:11 PM   #1423
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
This is a test of the national weather alert...again...this is only a test....
Sorry, but as soon as I read that post, that is what came to mind...
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 07-04-2008, 03:30 PM   #1424
THE EXPERIMENTER
carputer1's Avatar
like i said i was not to be taken as a flame, after posting i did think mmmm ,as there are alot of people who don't know nothing on how rr works, just use it, and others that have a bloody good try at it, and then the experts.
i'm in the bloody good try section i think.
if i'm wrong in anyway ,others will point my mistakes out on this
remove the sn stuff from that line and put snavi
now on a clear line put "snavi","xxxxxxxxxxxx"
the xxx's being your cmd line you had in onskinstart in your post.
Links
Old 07-04-2008, 05:34 PM   #1425
I'm in the same boat.
I just answer questions, it's not worth the effort to get snarky anymore. Although I do understand the frustration of answering the same basic questions over and over.
Help! Need RR and DFX 4.0 advice schwazche Road Runner 2 10-15-2008 02:25 PM
ProScan 4.0 Released ProScan Engine Management, OBD-II, Engine Diagnostics, etc. 16 05-26-2008 11:46 PM
Digimoto 4.0 available for download digimotojoel Engine Management, OBD-II, Engine Diagnostics, etc. 5 08-29-2005 04:36 AM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
