Quote: Originally Posted by
skuller
I have a problem with media copy, just like few others people here (after a quick search)
The media copy thing in the skin is pretty buggy. I wrote it a long time ago, and it needs a serious overhaul to really make it useful. After I get this version of the skin out, it is something I absolutely intend on updating.
This is the new GPS Stats screen. It has a lot of info and some neat little tricks that I cooked up
The bar on the right is centered when the vehicle is in steady motion. If you brake, the ball will move down, if you accelerate, it will move up. How much it moves is dependent on how fast you accelerate or brake
More eye candy than anything, as I needed something on the right hand side of the screen to square off the skin
Believe it or not, the turn signals on the "dashboard" actually work
If you are going in one direction, they will stay off, if you are on a curve, or turning the car, one of them will light up, to indicate the way the vehicle is turning... More eye candy, and absolutely useless in a real sense hahah! But I had the space, and figured what the hell... hahahah.
Neither of these require any special hardware, as they are based on information from GPS. If you have RR set up with an active GPS com port, they will work.
The rest of the stuff on the screen is pretty standard, the bar on the left will scroll up and down to indicate your altitude. The compass at the top spins left and right to show the direction you are heading, and the heading degrees right below that. As there was no space for song title and artist info at the top, it is on the bottom, in the "Odometer area" on this skin. Let me know what you guys think of the new look for this screen.
