Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 03-31-2008, 03:59 PM   #16
rinkk is an unknown quantity at this point
Quote: Originally Posted by dan32500 View Post
I think it's because of the different default instalation of Road Runner... used to be a space in the name, eg. "Program Files\Road Runner" now I see the latest install is "Program Files\RoadRunner" ...
So if you can't see the background open up the skin.ini file (iGoBMW skin folder) and remove the space from the name.
Thanks, that worked.
rinkk is offline   Reply With Quote
Old 04-12-2008, 08:35 PM   #17
jonessc's Avatar
jonessc is an unknown quantity at this point
Very nice, will get around to downloading it and trying it in the car...
Glad to see your utilizing the ibus functions in the skin
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 04-13-2008, 02:10 AM   #18
Been using this for a little while and this is an awesome skin. Any further developments?
Old 04-13-2008, 05:08 PM   #19
dan32500 is an unknown quantity at this point
I've done since the release:
1. the obc screen with analog gauges and info from the mileage plugin..
2. ilists (a bit buggy - list goes blank after resume)
2. visualizer in audio player
will release an update maybe this week...
dan32500 is offline   Reply With Quote
Old 04-14-2008, 12:03 AM   #20
WaRFiElD is on a distinguished road
This is an awesome skin. I've been using it for a few days and it's now my main skin! Thanks for the credits for iBusRR. It's been a while since I updated it but now my car is out of storage w/ a brand new carpc installed so i'll be looking for some new functions to add.
Is there a way you could add a transparent visualisation (low opacity) on the menu skin that would replace the background?
WaRFiElD is offline   Reply With Quote
Old 04-14-2008, 12:40 AM   #21
kelmk's Avatar
kelmk is an unknown quantity at this point
I had no idea you could limit the speed with the ibus. Where did you find these codes?
kelmk is offline   Reply With Quote
Old 04-14-2008, 12:55 PM   #22
The speed limit codes are for the factory navigation unit if I remember right. It sets a beeper after a certain speed. Don't worry it won't apply your brakes on the highway until you're down to 50kmh
Old 04-14-2008, 01:35 PM   #23
jonessc's Avatar
Sorry to thread jack (It is kinda relevant o your skin tho ), but WaRFiElD you ibusRR is based on the original ibus comm that supports both keyboard & RR commands, i see in your version keyboard is removed from the ini. I have got the phone button to send a key command instead of sending a RR command
This is the comparison I mean
IbusRR ini=
Code:
;Steering Wheel PHONE Press [ID:STW_PHONE_PRES] MsgTemplate="5004C83B8027" KeyboardMap="MUTE"
IbusCOMM.ini
Code:
[ID:STW_PHONE_PRES] MsgTemplate="5004C83B8027" Label="S.Wheel PHONE Press" Parse=True KeyboardMap="{F2}" ;RRCommand=""
Your version will still work after hibernation as the ibuscomm version has to be restarted after hibernate otherwise it doesnt work. If i replace the ini is it still compatible?
CarPuter Progress:
Old 04-14-2008, 02:11 PM   #24
I don't think so, I know I can have a trasparent vis but that will be on top of all layers not under like a background.
Old 04-26-2008, 10:11 PM   #25
Fmstrat is on a distinguished road
I use iGuidance and was thinking of using this skin. However, when I start up the GPS, it doesn't launch the App. Other skins work fine. Any ideas why? Thanks.
Fmstrat is offline   Reply With Quote
Old 04-29-2008, 11:31 AM   #26
@dan32500: is it possible to release the iList version of your skin? I'm working on a new version of iBusRR with scroll support from the steering wheel on the audio player/browser skin and I'd like to see if it works well on an iList.
thank you!
Old 04-29-2008, 11:35 AM   #27
@jonessc: The current version of iBusRR only support sending COM commands to RR. However, if RR supports sending keystrokes (which I don't know) you could probably bind a command to a keystroke in ExecTBL.ini
Old 04-30-2008, 04:01 PM   #28
Open skin's ExecTBL.ini and comment out the "GPS" line. (add a slash '/' in front).
UPDATE:
I released a more complete version with OBC and SETTINGS screens done... see first post for download link.
@WaRFiElD: IbusRR stoppend workin for some time in my car.. need to check, could be the cable connection.
Old 05-01-2008, 01:59 AM   #29
jonessc's Avatar
the v1.89 ibus comm i have sourse for supports both keyboard and rr commands, pm if you want a copy
CarPuter Progress:
Old 05-01-2008, 06:25 AM   #30
Tried that one aswell but I dont think u can send Ibus commands with it like u can with IbusRR - can only read Ibus commands.
Digital FX 2.0 Transparent Released JohnWPB RR Skins No Longer Supported 3759 03-07-2008 01:23 PM
Need help. transparent _EMPTY files and invisible buttons austin683 RR Skins 5 01-06-2008 10:36 PM
transparent tutorial? davidp RR Skins 3 08-28-2007 10:24 PM
Winamp transparent visualization issues TSur Road Runner 1 06-12-2007 06:54 PM
Transparent skins possible??? Supergong FreeDrive 4 01-13-2006 03:25 PM
