Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 05-01-2008, 09:55 AM   #31
dan32500 is an unknown quantity at this point
I found some new codes on a german site and Im working on a redesign of the BMW screen. Here they are if anyone else is interested:
Quote:
E46 IBUS codes
All codes tested on a E46 318ti
00 05 BF 7d 00 30 f7 - sun roof öffnen and if necessary unlock
00 05 BF 7d 00 20 chk - sun roof öffnen and lock
00 05 BF 7d 00 70 BF - sun roof close and if necessary unlock
00 05 BF 7d 00 60 chk - sun roof close and lock
00 05 BF 7d 00 00 chk - sun roof lock
00 05 BF 7d 00 10 chk - sun roof unlock
3f 05 00 0c 7e 01 chk - sun roof a piece open
3f 05 00 0c 7f 01 chk - sun roof a piece close
3f 05 00 0c 52 01 chk - windows in front driver's side a piece open
3f 05 00 0c 53 01 chk - windows driver's side a piece close in front
3f 05 00 0c 54 01 chk - windows in front front seat passenger side a piece open
3f 05 00 0c 55 01 chk - windows front seat passenger side a piece close in front
3f 05 00 0c 41 01 chk - windows in the back driver's side a piece open
3f 05 00 0c 42 01 chk - windows in the back driver's side a piece schlissen
3f 05 00 0c 44 01 chk - windows in the back front seat passenger side a piece open
3f 05 00 0c 43 01 chk - windows in the back front seat passenger side a piece schlissen
80 04 BF 11 00 2a - Innenraumbel. abdimmen
3f 05 00 0c 01 01 chk - Innenraumbel. switch off
3f 05 00 0c 30 01 chk -??? + Innenraumbel. abdimmen
3f 05 00 0c 60 01 chk - Innenraumbel. für 3 sec. turn on (no Fade)
3f 05 00 0c 68 01 chk - Innenraumbel. out and again andimmen
3f 05 00 0c 03 01 chk - doors unlock (pressed like Knopf@Innenraum)
3f 05 00 0c 34 01 chk - doors lock (pressed as with key)
3f 05 00 0c 46 01 chk - doors + gas cap hard LOCK, trunk openly
3f 05 00 0c 47 01 chk - driver's door lock (door handle lässt itself heavily pull)
3f 05 00 0c 4f 01 chk - all doors except driver's door verschlssen
3f 05 00 0c 97 01 chk - doors lock (hard LOCK)
3f 05 00 0c 02 01 chk - trunk open
3f 05 00 0c 05 01 chk - trunk open (again)
3f 05 00 0c 95 01 chk - trunk open (again)
3f 05 00 0c of 49 01 chk - windshield wipers in front
3f 05 00 0c 62 01 chk - disk wiping water in front spray
00 04 BF 76 0x chk - flashing: 2 = warnblinker, 4 = headlight low beam, 8 = high beam
3f 05 00 0c 70 01 chk - warnblinker (IKE + LCM) + Innenraumbel. andimmen
3f 05 00 0c of 75 01 chk - warnblinker (LCM) für 3 seconds
3f 0b BF 0c 00 00 00 00 00 00 of 01 06 chk - fog headlights
3f 0b BF 0c 00 00 00 00 00 40 00 06 chk - taillight left (+A)
3f 0b BF 0c 00 00 00 00 00 00 08 0c chk - taillight right (+A)
3f 0b BF 0c 00 00 00 00 01 00 00 06 chk - stop light above
3f 0b BF 0c 00 00 00 00 08 00 00 06 chk - stop light left (+A)
3f 0b BF 0c 00 00 00 00 10 00 00 06 chk - stop light right (+A)
3f 0b BF 0c 00 00 00 00 00 02 00 06 chk - headlight low beam in front right
3f 0b BF 0c 00 00 00 00 00 04 00 06 chk - headlight low beam in front left
3f 0b BF 0c 10 00 00 00 00 00 00 06 chk - headlight low beam in front + in the back retards
3f 0b BF 0c 00 00 00 00 00 10 00 06 chk - high beam left + headlight low beam reciprocally
3f 0b BF 0c 00 00 00 00 00 20 00 06 chk - high beam right + headlight low beam reciprocally
3f 0b BF 0c 00 00 80 00 00 00 00 06 chk - headlight low beam + with Ignition high beam (IKE+LCM)
3f 0b BF 0c 00 00 00 00 00 00 20 06 chk - turn signal shines at the rear left durably (+A)
3f 0b BF 0c 00 00 00 00 00 00 80 06 chk - turn signal in the back right shines durably (+A)
3f 0b BF 0c 00 00 00 00 20 00 00 06 chk - turn signal in front left shines durably (+A)
3f 0b BF 0c 00 00 00 00 40 00 00 06 chk - turn signal in front right shines durably (+A)
3f 0b BF 0c 00 00 00 40 00 00 00 06 chk - side marker light left
3f 0b BF 0c 00 00 00 80 00 00 00 06 chk - side marker light right
3f 0b BF 0c 20 00 00 00 00 00 00 of 06 chk - warnblinker
3b 05 80 41 0a 10 chk - average speed delete
BF 03 80 16 2a - requirement odometer reading
3b 06 80 40 09 00 xx chk - speed limits set (audio signal with exceeding)
3b 05 80 41 09 20 chk - speed limits on current speed set
3b 05 80 41 09 08 chk - deactivate adjusted speed limit
Received codes:
44 05 BF 74 04 xx chk - key xx put in
44 05 BF 74 00 FF chk - keys taken
00 04 BF 72 16 df - latch button pressed on remote maintenance
00 04 BF 72 26 ef - opening button pressed on remote maintenance
00 04 BF 72 06 cf - button on remote maintenance released
80 05 BF 18 xx yy chk - xx = Geschwindigkeit/2, yy = Drehzahl/100, message every 2 sec..
All codes of the sending address 3f are only few seconds active. Meant that for example the window not completely on, but only a piece goes far.
dan32500 is offline   Reply With Quote
Old 05-01-2008, 01:09 PM   #32
jonessc's Avatar
jonessc is an unknown quantity at this point
Quote: Originally Posted by dan32500 View Post
Tried that one aswell but I dont think u can send Ibus commands with it like u can with IbusRR - can only read Ibus commands.
Sends and recieves, im using it with a few mods to the ini file....
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 05-01-2008, 05:07 PM   #33
jonessc's Avatar
For the guys using IGo GPS software, is it designed to run on the pc? (ie not a ppc emulator etc) and do you happen to know if it has uk maps?
Cheers
CarPuter Progress:
Old 05-02-2008, 06:17 AM   #34
Cheers
There is a leaked PC version but officially there is only a PDA/PNA version released. It has UK maps also.
Old 05-13-2008, 08:37 AM   #35
nitr8 is an unknown quantity at this point
hi all,
im trying to to add coverflow http://www.mp3car.com/vbulletin/rr-p...11-8-07-a.html
i do not know what the hell i am doing i tried to follow there instructions with no luck. anyone willing to shed the light how i can get this done with this skin.
nitr8 is offline   Reply With Quote
Old 05-14-2008, 07:45 AM   #36
Small update... BMW screen 1/2 using latest iBusRR plugin.
Old 05-14-2008, 03:10 PM   #37
A landy bg for those of you who want it.
Old 05-18-2008, 05:16 AM   #38
jarro_25 is an unknown quantity at this point
This is with ibus or with obd?
is this skin for 800x480 or 800x600?
This screen is very good.
jarro_25 is offline   Reply With Quote
Old 05-18-2008, 06:48 AM   #39
Just IBUS
Skin is for 800x600... only the BMW background is made to strech on a wide screen.
Old 05-18-2008, 06:13 PM   #40
WaRFiElD is on a distinguished road
this is for use with ibus but your cas also has to be equipped with an on-board computer! I forgot that some bimmers didn't come factory equipped with one (i.e. I think it's an option on the 320i)
@dan32500: is it possible to make the gauges the same ratio as the BMW logo? They look stretched on my lilliput 7" 800x600. Or maybe I have something not configured properly?
WaRFiElD is offline   Reply With Quote
Old 05-19-2008, 05:34 AM   #41
Another progress update.. BMW screen 2/2 for lights:
I'll make the gauges the same ratio as the BMW logo aswell.
Old 05-19-2008, 05:49 AM   #42
chrislamb's Avatar
chrislamb is an unknown quantity at this point
Any chance of a MINI background?
Pretty please!
MINI COOPER S PRO
chrislamb is offline   Reply With Quote
Old 05-19-2008, 08:08 AM   #43
PNG menu template:
Old 05-19-2008, 09:20 AM   #44
chrislamb's Avatar
MANY MANY thanks!!!
SMART!
MINI COOPER S PRO
Old 05-20-2008, 10:14 AM   #45
Just a heads up on the update iBusRR Rules!
Digital FX 2.0 Transparent Released JohnWPB RR Skins No Longer Supported 3759 03-07-2008 01:23 PM
Need help. transparent _EMPTY files and invisible buttons austin683 RR Skins 5 01-06-2008 10:36 PM
transparent tutorial? davidp RR Skins 3 08-28-2007 10:24 PM
Winamp transparent visualization issues TSur Road Runner 1 06-12-2007 06:54 PM
Transparent skins possible??? Supergong FreeDrive 4 01-13-2006 03:25 PM
