Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 06-13-2008, 07:29 AM   #76
LazyFox is an unknown quantity at this point
thanks!
LazyFox is offline   Reply With Quote
Old 06-15-2008, 04:29 PM   #77
the_big_1 is an unknown quantity at this point
Hi Dan,
first of all must say, I am Newbie but this is a fab skin! Going to put it on my first carpc for my E46.
Couple of questions, no doubt asked before but I have to learn some how.
When I open the skin in the skin edito, it doesnt show the back ground image, any ideas?
Also, what gps software did you use? I have just got Navigator 6 but for some reason, it wont start with the skin but will with the BVM2 one?
Have you any thoughts on adding mobile?
the_big_1 is offline   Reply With Quote
Old 06-16-2008, 04:50 PM   #78
InfinitiPC's Avatar
InfinitiPC is an unknown quantity at this point
I can't get the background either. It is just gray and I can't see any of the buttons until I click them.
fastmode=-1
background=C:\Program Files\Road Runner\Backrounds\
bgfile=C:\Program Files\Road Runner\Backrounds\Lines_red.jpg
also tried:
RR exe is 12/13/07
Backgrounds work fine in DFX30
-InfinitiPC
InfinitiPC is offline   Reply With Quote
Old 06-16-2008, 04:52 PM   #79
Not sure but seems to be because they are PNG files not JPEG, I think
Old 06-16-2008, 05:10 PM   #80
MGD
MGD's Avatar
MGD is on a distinguished road
Did you guys register the GDIPlusWrapper.dll ?
MGD is offline   Reply With Quote
Old 06-16-2008, 05:11 PM   #81
Hi,
not sure, where/how?
Old 06-16-2008, 05:15 PM   #82
InfinitiPC's Avatar
Added: backgroundpath=C:\Program Files\Road Runner\backgrounds\
(in addition to the standard background= that RRConfig sets)
Registered GDIPlusWrapper.dll with RegSvr32
Tried a PNG instead of a JPG.
Still no good.
-InfinitiPC
Old 06-16-2008, 05:15 PM   #83
MGD
MGD's Avatar
Should be in the Road Runner Folder. If you don't have it, it is attached.
Go to Start>>Run and type in
regsvr32 "C:\Program Files\Road Runner\GdiPlusWrapper.dll" and hit enter.
Old 06-16-2008, 05:18 PM   #84
MGD
MGD's Avatar
Still no good.
If a skin folder has a SKIN.ini file in it, it will override the RR.ini file.
Look in the skin folder for the skin.ini file and change your background path there..
Old 06-16-2008, 05:23 PM   #85
MGD
MGD's Avatar
Here is another hint. Run RRConfig.exe and select your backgrounpath there.
Old 06-16-2008, 06:07 PM   #86
Hi,
Done all that in the editor, still all grey with just white boxes where the buttons are
Old 06-17-2008, 01:02 PM   #87
dan32500 is an unknown quantity at this point
Quote: Originally Posted by the_big_1 View Post
Hi Dan,
The skin editor uses its own background.jpg file. Replace that with one of the backgrounds of my skin if you want to see it.
For NAV; I use Igo8 with a custom 800x544 skin.
For mobile/phone screen; I haven't looked into yet as I don't see it working that well to be worth making.
As an example:
skin.ini should have:
background=C:\Program Files\Road Runner\Backgrounds\Lines_red.jpg
rr.ini should have:
dan32500 is offline   Reply With Quote
Old 06-17-2008, 02:59 PM   #88
Hi,
Do you have your background as a jpeg as all the ones in the zip are png.
Cheers!
Old 06-17-2008, 03:13 PM   #89
MGD
MGD's Avatar
Do you have the new Skin Editor ?
If not here it is.
http://myspotontheweb.no-ip.org/Down...ditor_v.71.zip
As for a background, you can use any *.jpg file you want, in the format 800x600 and copy it in the skin Editor Folder.
for your convenience, here is one. Right click annd save as, then save it in the skin editor folder.
Old 06-17-2008, 03:39 PM   #90
InfinitiPC's Avatar
I figured it out. Had taken a screen-shot of RR + inifiles + bgdir, uploaded it to this post, then studied it one last time before posting... noticed the bgdir was named "backrounds" rather than "backgrounds". lol
-InfinitiPC
Digital FX 2.0 Transparent Released JohnWPB RR Skins No Longer Supported 3759 03-07-2008 01:23 PM
Need help. transparent _EMPTY files and invisible buttons austin683 RR Skins 5 01-06-2008 10:36 PM
transparent tutorial? davidp RR Skins 3 08-28-2007 10:24 PM
Winamp transparent visualization issues TSur Road Runner 1 06-12-2007 06:54 PM
Transparent skins possible??? Supergong FreeDrive 4 01-13-2006 03:25 PM
