09-10-2008, 07:35 PM
#91
Raw Wave
Question..
What's the name of the overlay used for the BG change screen? Also, it looks like gpsol_down and gpsol_off are the same - are they?
Trying to resize those overlays to make the skin usable.
09-10-2008, 07:47 PM
#92
Quote: Originally Posted by monkeyracer
fixed. report back when possible, thanx.
09-10-2008, 10:03 PM
#93
Wants to make it harder
still leaks memory... cpu usage hovers between 2% and 8% though.
09-10-2008, 10:34 PM
#94
Or... just download this:
Temporary 800x600 Support
and copy the files over into the skin's folder.
Let me know if those work.
09-10-2008, 10:37 PM
#95
k, try this please
09-10-2008, 10:44 PM
#96
That seems to work. It still eats memory with every button press, but it's not a constant leak like before. Each time the overlay is closed, it clears that out anyway.
09-10-2008, 10:49 PM
#97
cool, hope you guys enjoy it. good luck.
09-11-2008, 03:42 PM
#98
Raw Wave
Yep, works perfect. Thanks you.
09-12-2008, 11:01 AM
#99
V3.01 is available, and now correctly shows "Down" image. Also included the new 1.25 ElcosMenu.exe.
Those using 800x600 will need to extract the update, and then copy the temporary 800x600 support files back over into the skin folder.
09-12-2008, 05:58 PM
#100
Raw Wave
IN 3.01 the GMPC overlay don't start (GMPC does); switch to 3.0 and it work fine.
09-12-2008, 07:39 PM
#101
I wonder if it has anything to do with the new version of ElcosMenu (1.25) I will have to look at that when I get to the laptop...
09-13-2008, 09:16 AM
#102
I noticed that the empty image was messing up the overlays, so I fixed that in the 3.02 update, but you should be able to copy your 800x600 temporary support files back over and it should work again.
09-13-2008, 11:13 AM
#103
Raw Wave
Fixed!
Now if could only find the 800x600 GMPC overlay, every thing would be fine!
09-13-2008, 11:35 AM
#104
09-13-2008, 12:59 PM
#105
Raw Wave
aha! The GMPC overlay isn't included in the temp support but now that you mentioned it, it dawned on me it's in your standalone GMPC OSK release. Thanks
| Thread Tools |
| Display Modes |
Linear Mode
