12-11-2008, 06:48 AM
#31
One Sharp Cheddar
Quote: Originally Posted by Kosti
Thanks, keen to test it..so we have to setup the OSK for garmin at this stage right?
No the OSK is pretty much plug and play. You will have to go in to the skin folder and open up the skin.ini file and change the garmin path to what ever the path is to your garmin folder.
But that is it.
12-11-2008, 06:38 PM
#32
Raw Wave
Read the readme but i didn't see how do you get to the audio browser?
Hugh buttons - nice!
Is the slider on the main menu only eye candy?
Easy to set BG - a rarety now a days.
Looks good.
12-11-2008, 09:20 PM
#33
One Sharp Cheddar
To get to the playlist editor you must press and hold the music button. Currently the music screen only shows the playlist.
The slider on the bottom indicates that the speed limit and speedzone monitor is running.
The slider remains inactive when it is not running.
12-11-2008, 10:01 PM
#34
This looks really nice.
Am I correct when I assume that the slider at the bottom is not for fast forwarding through music?
And does this support XM?
-- Ok I apologize but I am a total noob. I read the readme, but I have no idea how to "install" this skin.
I downloaded it, and now I have a bunch of files and folders on my pc - but no idea what to do with them. I did I miss a readme on this?
Sorry for all you skin trying/testing pros out there, but I am lost.
12-12-2008, 07:06 AM
#35
One Sharp Cheddar
After you unzip it, move the nav2 folder and all of it's contents to your RR/skins folder
Then using RRCONFIG select the skin NAV2 as you day and night skin.
The open up the README FIRST folder and there should be a text file in there for you to follow instruction.
12-12-2008, 01:03 PM
#36
Thanks.
So just to clairfy, the slider on the bottom is not for fast forwarding through music?
12-12-2008, 04:30 PM
#37
One Sharp Cheddar
Thanks.
Nope the slider indicates that the speed monitor is working
12-12-2008, 04:33 PM
#38
Ok, thanks!
12-14-2008, 09:58 PM
#39
One Sharp Cheddar
Carnetix PSUMONITOR pluggin now included with download
12-16-2008, 03:39 AM
#40
no plug in for dsatx
12-16-2008, 06:31 PM
#41
One Sharp Cheddar
Sorry dont have a DSATX. But if you have a program that displays the info I can probably whip up a pluggin for that as well.
12-17-2008, 08:57 PM
#42
Very nice. Any plans to incorporate XM support?
12-18-2008, 06:30 PM
#43
One Sharp Cheddar
Truthfully, I dont think XM is worth it. I had it and I got to tell you HD radio blow it away. So the answer to that question would be nope, sorry, no change, I DONT THINK SO
12-18-2008, 06:36 PM
#44
One Sharp Cheddar
Quote: Originally Posted by genie4x4
Thanks for your reply i havent been on in a while, pc didnt remind me of new postings from forum.
Have installed your skin but get a few errors, buttons come up yellow and background isnt black, two script icons come up down by clock on task bar, and car netix box comes up, close the program and i get two error boxes up with: Autolt error line-1: Error: the requested action with this object has failed.
(1) Yeah, you can't close the carnetix interface it will cause an autoit error with the PSU monitor. ( for now just press on the RR screen and the PSU monitor will go to the background. It should minimize auotmatically though) It will not cause any problems with RR or the rest of the skin though. I will probably be adding an option for the PSU monitor before the next release.
(2) The script icons are the programs that monitor the PSU software and the speed limit monitor.
(3) You need to set a background image through the background selection screen after first setting your default background directory in RRCONFIG
12-18-2008, 06:47 PM
#45
One Sharp Cheddar
-OK found a bug with the carnetix command I using to open the carnetix screen.
Problem solved.
-Also had some problems with the speed zone plugin not reporting your current speed zone. FIX
-Added 10 more speed zones and also detects speed zones according to the direction you are driving.
Uploading the next now and hopefully bug free release
| Thread Tools |
| Display Modes |
Linear Mode
