02-15-2009, 07:23 PM
#136
Quote: Originally Posted by mrpee1881
When I hit the iGuidance button the application loads with no problems and the controls work perfectly. However, is the top and bottom portion of the iguidance window suppose to site above the skin? Should this app at this time be truly embedded? I checked rrconfig and chose that option. Somone enlighten me please. Thanks
This is the embedding command used in the GPS configuration in RRConfig's "Gps Window Name" ... .iGuidance, Make sure you have entered the program name.
If you cant DODGE em, RAM em.
02-15-2009, 09:39 PM
#137
Did anyone use CarwingDynamic with Street&Trips?.
03-01-2009, 08:24 PM
#138
som one asked for Road Camera HD integration... my V1 does not support commands so if you wanna do that you need to alow buttons to be pressed.
03-02-2009, 01:15 AM
#139
I'm having trouble getting my Garmin to load.
I already long clicked the button and switched it over to Garmin. I also have my GPS set to External and the proper path selected to point to the Que.exe for Garmin in RR Config. When I use the button as IGuidance, it loads Garmin fine but with the left hand IG overlay. When I long click and change the button over to Garmin, Que.exe never loads. The overlay loads and it just sits there on the "One moment please" screen, never loading Garmin.
Edit: Just found something out. When I have Garmin already running (Que.exe) before loading RR, then it works just fine. Curious...
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
03-17-2009, 12:48 AM
#140
So how can I get rid of that iglnks that block's the menu button in Iguidance? I'm more comfortable with the menu button, sorry if it's something painfully obvious, but after some minor checking in skin files, and with the editors I just found out what the app it's called, but not how to stop it from being called up. Yes I'm a noob in this whole skinning thing.
03-18-2009, 12:43 AM
#141
Great skin, but how do you get rid of the left menu overlay? When I am running IG4 it's better to use the native menu options. Thanks.
03-18-2009, 05:03 PM
#142
Raw Wave
In ExecTBL.ini find this: "RUN;$skinpath$CWiG.exe||GPS"
Change it to this: "GPS"
03-19-2009, 08:11 PM
#143
ronjon228 I'm having the same issues. Did you ever get it fixed?
03-19-2009, 11:12 PM
#144
Did you add garminpath to your RR.ini file?
Open rr.ini in notepad and add the path to your Garmin path.
Mine looks like this...
garminpath=C:\Program Files\Garmin\Garminmobilepc\que.exe
Add it to the bottom of the page under extras
03-21-2009, 08:28 AM
#145
I added your line and everything is working. Thanks
03-22-2009, 06:50 PM
#146
Just erase that whole thing, and put "GPS" in it's place? That didn't work for me.
03-22-2009, 08:44 PM
#147
Raw Wave
Maybe it wasn't clear, the whole line looks like this:
"MyApp14","RUN;$skinpath$CWiG.exe||GPS"
What you want it to look like in the end:
"MyApp14","GPS"
03-22-2009, 09:19 PM
#148
"MyApp14","GPS"
Got it working now. Thanks for clearing that up!
03-26-2009, 09:31 AM
#149
I'm loving this skin. I've got an ADS InstantFM USB fm receiver, but can't get it to work with Riderunner. It works fine withe the ADS Config app. I've got the rr.ini set with radiomode=7 and selected Silabs in RRConfig, but I get no audio at all.
Anyone got any ideas?
Any help would be great.
Cheers.
Greg
04-03-2009, 05:35 AM
#150
I have the same problem.
My SILABS(RDing PCear) radio is not working.
With previous roadrunner+carwings skin it was working fine!
| Thread Tools |
| Display Modes |
Linear Mode
