Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 04-05-2009, 03:05 PM   #151
moreause is an unknown quantity at this point
Is it possible to change button name ??
i embeded logworks and modified Gas Prices to start it
how do i change the gaz prices Label ??
moreause is offline   Reply With Quote
Old 04-05-2009, 05:11 PM   #152
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
In exectbl.ini find the work "gas prices" and change it to whatever you want to show.
treetop777 is offline   Reply With Quote
Old 04-05-2009, 05:34 PM   #153
ha ha tanks
i was playing in the right file
but was not seeing the place to change button names thanks
Old 04-06-2009, 12:15 AM   #154
Megamuzzy is an unknown quantity at this point
Quote: Originally Posted by Megamuzzy View Post
I have the same problem.
My SILABS(RDing PCear) radio is not working.
With previous roadrunner+carwings skin it was working fine!
Now works fine. Chenged usbradio.dll to version USBRadio-1.7-beta5
from here http://code.google.com/p/silabsradiodll/downloads/list
Megamuzzy is offline   Reply With Quote
Old 04-06-2009, 10:55 AM   #155
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
That's interesting. I am using the latest DLL (USBRadio Experimental DualTunerDS 0.8.zip) which is much improved over the above. Its one of the few DLLs that has to be in the RRPATH directory, but works well.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 04-08-2009, 01:14 AM   #156
Will it work with SINGLE silabs? I have only one.
I'll give it a try today!
Thanks!
Old 04-08-2009, 10:39 AM   #157
GizmoQ's Avatar
Thanks!
Yes, thats all I have.
Old 04-08-2009, 03:08 PM   #158
Question
So, i tried USBRadio Experimental DualTunerDS 0.8 version and it doesn' work with my radio. Also i have tried some other versions and the results are:
- USBRadio-1.7-beta5 -> works
- USBRadio Experimental DualTunerEON x.x -> works
- USBRadio Experimental DualTunerDS x.x -> DOESN'T work
Then i downloaded GraphEdit program and created new filter.grf that contains: RDing PCear FM Radio -> Default DirectSound Device
And now TestSilabsDLL.exe plays radio fine using DualTunerDS 0.8 version!
BUT if i put usbradio.dll+filter.grf into RR folder - i have no sound from radio in RR!!!
So the question is: how to make usbradio.dll to use filter.grf in RR folder?
Old 04-09-2009, 12:01 AM   #159
ffjwhite is an unknown quantity at this point
Is it at all possible to turn off the sound it makes when pushing a button, it is really loud on and annyoing. If there is a way to disable it that would be great. Thanks
ffjwhite is offline   Reply With Quote
Old 04-09-2009, 09:45 PM   #160
fixerofallthing's Avatar
fixerofallthing is on a distinguished road
open exectbl.ini in the carwings_dynamic folder in notepad and comment out (put a "/" without the quotes, in front of the these 2 lines).
"ONBTNPRESS","PlaySound;$SKINPATH$Sounds\button1.w av"
"ONBTNHOLD","PlaySound;$SKINPATH$Sounds\button2.wa v"
so they should look like this...
/"ONBTNPRESS","PlaySound;$SKINPATH$Sounds\button1.w av"
/"ONBTNHOLD","PlaySound;$SKINPATH$Sounds\button2.wa v"
you could change the sounds to something you like also. put the wav files in the carwings folder and change the reference above to your file name.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Old 04-10-2009, 02:26 AM   #161
moranl is an unknown quantity at this point
freefone integration in carwings
very elegant skin. I really like it!
I'm using freefone with it and was wondering about a bunch of things:
- Why the 'bluetooth' indicator is not lit when freefone connected my phone?
- When someone calls I just see an 'in call' label displayed over freefone instead of seeing their picture from the 'phonepics' folder and the fonecall.skin.
- Is it possible to get RR to automatically switch into phone mode when an incoming call occurs?
Also, I am using a GPS software called Destinator because it has local maps for my country. Take a look at this screenshot:
- Any idea how to get it to be under the top and bottom bars instead of covering them and disable the left menu?
- Do you plan to change the label from iGUIDANCE to GPS for those of us who are using external apps?
Thank you for a great skin!
moranl is offline   Reply With Quote
Old 04-10-2009, 04:48 PM   #162
Destinator GPS App integration
Regarding the GPS issues, I read back and found how to disable the left menu bar which is some progress... Still having problems with nicely integrating the Destinator program into the skin though.
Here the program is running standalone in map mode (res: 800x575):
This is how it looks when called from Carwings (skin res at 800x600):
As you can see there are some missing parts which instead show the part of the previous picture... Is it possible to shrink the Destinator window so that it would fit nicely into the skin?
Old 04-10-2009, 05:04 PM   #163
In RRConfig select external and set the window name to "destinator" without the quotes and it should embed fine. I just set mine that way and it worked.
You can change the label on the button in exectbl.ini or use the DFX button editor.
here is a screen shot of what mine looks like.
Old 04-11-2009, 01:02 AM   #164
The screenshots were taken with RR set for "destinator"
Any idea why this happens?
Also, can you relate to my freefone qeustions in the previous post?
Old 04-11-2009, 08:05 AM   #165
I do not use freefone so I will have to look at it this weekend.
Native Reminder Function Beta Thread Sonicxtacy02 Road Runner 97 09-25-2008 01:44 PM
Blades Edge - Beta 1 Release ThunderStick RR Skins 75 09-11-2008 09:57 PM
**NEW BETA Software release for XP & Vista** 2k1Toaster FB Software 28 11-07-2007 04:35 PM
Beta Release Black Vinyl on Aluminium kpjuk RR Skins 10 07-31-2006 10:34 AM
any news on beta release for the front end? bertybassett V.O.I.C.E.S 14 05-20-2004 04:17 AM
