Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 10-15-2008, 12:50 PM   #31
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
Quote: Originally Posted by fixerofallthing View Post
I just did a "clean" install from the new installer and added this skin and you are right it does not work unless you have
backgroundpath=C:\Program Files\Road Runner\skins\Carwings_V2_Transparent\backgrounds
in your rr.ini
background is specified but not backgroundpath is not. This skin uses the backgroundpath command. I believe DFX uses the background command though, so they can be set to different directories without any problem. After I added that to my rr.ini the image preview worked fine. Thanks for pointing it out and I will add it to the instructions in the first post.
Same issue here. My backgrounds are in C:\Documents and Settings\USER\My Documents\My Pictures\Backgrounds. And without going into the .skin and exectbl.ini files, it can't be used in Carwings. My RR.ini points backgroundpath to it but Carwings isn't using it.
Also I looked all through my RR.ini and all paths listed end in a "\", however, when I did modify the .skin file to use backgroundpath, I found that the skin.ini had one slash too many before the picturefilename, i.e., "...backgrounds\\sunset.jpg"
For your next update, can you remove the "backgroundfolder" variable and remove the added slash from the background variable,
they're not needed.
EDIT: This skin looks great with the full transparency, just my 2 cents.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is online now   Reply With Quote
Old 10-15-2008, 01:05 PM   #32
brandensin is an unknown quantity at this point
gizmoq,
i followed fixero's suggestion, it works..
just add,
backgroundpath=C:\Program Files\Road Runner\skins\Carwings_V2_Transparent\backgrounds\
to ur rr.ini
brandensin is offline   Reply With Quote
Old 10-15-2008, 02:43 PM   #33
GizmoQ's Avatar
Quote: Originally Posted by brandensin View Post
gizmoq,
just add,
to ur rr.ini
That's not the point. RR has a setting for where you as an end user want to keep your background pictures. I have over 300. I know most skinners want their skins to work right out of the box, but for those of us that use multiple skins and want to keep from duplicating files (if I left all the backgrounds for all the skins I use with their respective skins I'd have thousands of duplicates all over the place - WHY!) Same goes for add-ins and plugins, especially in those skins with installer programs.
I realize skinners want to get betas out fast, but documentation is part of programming (the worst part I know) and it seems all the threads on standardization are for not. I haven't released any of my skins for just this reason (and I probably couldn't stand the criticism or keep up with the change requests). I usually just sit back and if I like a skin I mod it to my liking without comment. But lately all this catering to the Newbies and programming in a vacuum just got to me and I apologize. I remember the debacle we had with two or three sources doing different things and I don't blame Guino for never releasing the source again, but now we face skins that don't play well with others and that's just as bad. Here's a perfect example: every skin installer that registers coverflow breaks every other skins ability to use it (and I know that's a coverflow issue, but the skinner did it to us).
:RANT MODE OFF:
I'll just shut up and mod the skin to my liking.
Old 10-15-2008, 03:10 PM   #34
fixerofallthing's Avatar
fixerofallthing is on a distinguished road
:RANT MODE OFF:
I totally understand and I think RR should use a default location for background images. I have no problem changing to a "standard" location if we can decide on one. The path I used is inside the skin folder because the new installer does not come with background images and I did not want to do an instaler so I just made it drop in and play. Maybe I will do an installer and get a consensus of where we want our images to reside and problem solved.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Old 10-15-2008, 03:32 PM   #35
GizmoQ's Avatar
I hope you didn't take my rant the wrong way. I'm not telling you or anyone else how to skin for RR. Its just that standards are being agreed upon by some and maybe they're not distributed or explained to the masses (Stickyed or FAQ). And if they were known, skinners would have to add documentation, for example, that says "there is a directory of backgrounds as a sub directory of this skin that should be copied to your backgroundpath directory, if you don't have one already step1,step2,step3,... is how to create one". Maybe the standards should have boilerplate for skinners to add to their documentation. I don't know. I think I start a new thread on this and try not to get banned.
:Back to your regularly scheduled programming:
Old 10-15-2008, 03:35 PM   #36
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Well Itried to make a Standardisation of plugins but got pi5sed with a certain element not bothering to take that into consideration so I have given up.
I have long been an advocate for a standard place for backgrounds folder in the root of RoadRunner as opposed to individual skins.
Also for plugins as well.
But hey, why bother?
Enforcer is online now   Reply With Quote
Old 10-15-2008, 03:45 PM   #37
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
Quote: Originally Posted by Enforcer View Post
I have long been an advocate for a standard place for backgrounds folder in the root of RoadRunner as opposed to individual skins.Also for plugins as well.
agreed
AGREED
EL CAMINO is offline   Reply With Quote
Old 10-15-2008, 03:49 PM   #38
Valheru's Avatar
Valheru is an unknown quantity at this point
I'll second that motion ... or in this case third that motion ...
an alternative solution is to implement something like TEKNIK T/3 does (shameless plug) ... On skin start it will load a default BG pic if not exists AND you can change the path for your BG folder from inside the actual skin ... not setting INI variable by hand ... so you just browse to your BG folder.
The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0
Valheru is offline   Reply With Quote
Old 10-15-2008, 03:52 PM   #39
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
Eveyone knows that a global variable can be declared in rr.ini that maps the background directory, right!?
As long as the skinners follow suit all skins will have a common background share, thats how my system is setup anyway. Guino implimented this back when the first GDI+ RR was released.
blk02si is offline   Reply With Quote
Old 10-15-2008, 04:00 PM   #40
MGD
MGD's Avatar
MGD is on a distinguished road
If all skinners would use the $BACKGROUNDPATH$ in theire skin, you can have your backgrounds where ever you want. All you have to do is to specify it in rr.ini.
backgroundpath=where ever
MGD is offline   Reply With Quote
Old 10-15-2008, 04:17 PM   #41
Valheru's Avatar
but that's it you use the BACKGROUNDPATH method ofr BG's. Personally I have never got that method to consistantly display EVERY image in my BG's folder .. the PICSVIEWER skin does ...
edit : all my BG images are std 800x600 jpg files.
Old 10-15-2008, 04:47 PM   #42
MGD
MGD's Avatar
You might want to check the image attributes. It is impossible to show one and not the other unless it is hidden.
Old 10-15-2008, 05:08 PM   #43
I did not take it the wrong way. I AGREE! We just need to al get on the same page.
Old 10-15-2008, 05:12 PM   #44
I agree this is the best way to handle it. That is why I did mine this way. Maybe we can add the creation of a backgroung folder in the RR installer and put a default image there so all will work out of the box. It would not add too much to the installer size.
Am I wrong or is RRconfig not handling backgroundpath correctly. I see where background is eet but not the former. Maybe it is my version but I did an install with the latest official version and I had to manually add it.
Old 10-15-2008, 06:46 PM   #45
GizmoQ's Avatar
Keep in mind also that the way the skinner codes the save routine also needs to account for "backgroundpath" definitions that may not necessarily be in the skinpath or rrpath. I had to edit both the background.skin and exectbl.ini cause the SD,,,,, and SAVETOSKIN commands thinks my backgrounds are in the skinpath.
Native Reminder Function Beta Thread Sonicxtacy02 Road Runner 97 09-25-2008 01:44 PM
Blades Edge - Beta 1 Release ThunderStick RR Skins 75 09-11-2008 09:57 PM
**NEW BETA Software release for XP & Vista** 2k1Toaster FB Software 28 11-07-2007 04:35 PM
Beta Release Black Vinyl on Aluminium kpjuk RR Skins 10 07-31-2006 10:34 AM
any news on beta release for the front end? bertybassett V.O.I.C.E.S 14 05-20-2004 04:17 AM
