No I did not get that. I just added it where it seemed like it belonged. What did you use to launch that. I did not want to do all the art over but I guess I could and add that to the bottom bar.
Here are all the graphics files, commands, skins and such for the dimmer.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
Place a video button on the main menu; pressing it goes to the video player; press video browser - nothing!
Thanks for finding that. Here is a fix and will upload new installer later.
Rename extension to .skin and drop in skin folder (I know you know how but in case others read this later)
If anybody want coverart to show in the video browser just drop this file in the skin folder (change .txt to .skin). Of-course, you must already have the coverart jpgs.
Nice addition. I do not use it so I did not think to add it. I will add it to the next release. Thanks.
Installed last night, and I like it! Need to install the exit menu, but otherwise it is nice. Any way to darken the time/date, it's hard to read in the daytime, white on gray.
Instructions are included to enable exit menu if you need help LMK. You can edit the skin files directly to change color to all black. It is set up with white text and black shadow effect. If you installed RR withthe latest installer then you have the skin editor and you can open the skin and select those fields and change to any color you want.
I like the original dimmer menu better, not too sure I like the click and hold to exit the dimmer, but hey it works. Other than that, very good! Installed it yesterday and still have not found any bugs, keep up the great work fixer!
