Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 02-28-2009, 03:13 AM   #31
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
this skin dos'nt have a minimize button , you can add 1 yourself vai skin editor
carputer1 is offline   Reply With Quote
Old 02-28-2009, 12:03 PM   #32
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Or notepad
Enforcer is offline   Reply With Quote
Old 02-28-2009, 12:05 PM   #33
THE EXPERIMENTER
carputer1's Avatar
oh yes and Enforcers well know Notepad lol...
Old 03-01-2009, 10:22 AM   #34
Valheru's Avatar
Valheru is an unknown quantity at this point
The skin doesn't have a minimise button ,but as carputer1 mentioned it's easy to add one yourself ...
When working on the design I wanted the TEK skins to be easy to use in-car, and things like minimise didn't really fall into the easy to do in the car ...
one very easy to do this is to edit the "topmenu.inc" file with notepad and replace the line
B03,683,01,115,56,"LOAD;mixer.skin","" with this line
B03,683,01,115,56,"LOAD;mixer.skin",@MINIMIZE@
Doing it this way will add a hidden minimize button to the volume button on most screens ... press and hold the volume to minimise the skin.
The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0
Valheru is offline   Reply With Quote
Old 03-01-2009, 11:30 AM   #35
ronjon228's Avatar
ronjon228 is on a distinguished road
I like the look and all the integration of this skin.
However, I'm having a couple of issues.
First off, I hate having to click on the volume button every time I want to adjust volume. I'm thinking it would be better off to have vol+ and vol- keys some where on all screens.
Also, when using Garmin Mobile PC (external) the GMPC window takes up the entire screen. In order to get out of Garmin and back to RR I have to close GMPC (via the x). This is pretty much a deal breaker for me. I would like to be able to switch back and forth from Garmin to RR and have volume and track controls while Garmin is open. Having to close it every time means I have to wait for it to load again each time I want to check my route.
Thanks!
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
ronjon228 is offline   Reply With Quote
Old 03-01-2009, 03:26 PM   #36
Valheru's Avatar
hi ronjon228 ...
firstly, for the volume it wold require a complete redesign of the skin to add vol controls to all screens ...
as for the Garmin, TEK4 was designed to fully handle integrated GMPC software. For it to work you need to do the following ...
... In RRConfig, go to GPS screen, and set the "GPS Path" to the exe for Garmin.
... Set the GPS Window Name to "Garmin"
... Set the GPS Mode to "Menu"
and then inside TEK4 on the GPS Menu select Garmin ... this will load Garmin Mobile with an overlay that allows switching between Garmin and RR ...
Old 03-02-2009, 12:25 AM   #37
ronjon228's Avatar
Awesome, thanks Val.
The volume thing may be a deal breaker for me, but I'll give the skin a shot.
Thanks!
CarPC:
Sound System:
Old 03-05-2009, 07:01 AM   #38
Schma is an unknown quantity at this point
Get yourself a Griffin powermate for volume control.Works great with that one.
I use turning for volume, pressing for mute and long press for hibernation.
Schma is offline   Reply With Quote
Old 03-05-2009, 09:44 AM   #39
Confusion Master
Enforcer's Avatar
Thanks!
What is it with the 'Deal breaker' phrase people keep using with skins and front ends, especially free ones.
Where is the deal if the software is free? use it or don't use but don't say something is a 'deal breaker' [/RANT]
NB this is not a dig specific to you ronjon228 as I see this phrase used quite often on this board by other as well.
Old 03-05-2009, 01:37 PM   #40
ronjon228's Avatar
No worries bud, I completely understand. Trust me, I'm the first to praise all you guys for your hard work. I've stuck with free front ends this long and am really hoping I can find a skin (other than carwings) that gives me everything I'm looking for. At this point it's either RR or CF and I don't want to pay for a front end.
The only reason I used that term is because it's true. I don't have any external volume control and am constantly adjusting the volume. In my case I can't live without a readily "pushable" volume control at my disposal.
This by no means knocks your skin. It's a beautiful skin for sure. Hopefully you understand now. Keep up the good work man.
CarPC:
Sound System:
Old 03-05-2009, 05:06 PM   #41
Valheru's Avatar
hey guys ..
Firstly, this skin is not Enforcers ... it's by me - Valheru.
Secondly, if you need to continually adjust your volume, perhaps try "normalising" your mp3 collection with something like "MP3Gain", which can standardise the volume of all your MP3's so you don't need to manually adjust your vol so often while listening to music.
Finally, I'm inclined to agree with Enforcer on this one, ok so TEK4 doesnt have an vol control on every screen, but to be honest it's not a big deal. If you like the skin then by all means use it away to your hearts content - if it doesnt suit your needs then by all means use a different skin that does meet your needs ... it really doesn't matter one way or another. I designed this skin for me .. and if it fit's other peoples requirements then excellent - and if not well then thats grand too ...
and like enforcer said - this is not a dig at you ronjon, just a general observation.
btw: ronjon28, I have looked at what is needed to add the vol controls to every screen of this skin, and to be honest I would nearly have to redesign the entire skin to accomodate that type of change ...
Old 03-05-2009, 05:43 PM   #42
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
The commands could be added on either side of the date, it would just be hidden.
treetop777 is offline   Reply With Quote
Old 03-05-2009, 05:48 PM   #43
ronjon228's Avatar
I just figured it would be nice to get some user input for what people would like to see. Didn't mean to cause any animosity. If I did I apologize. I just figured it would be a common concern from the average user. I'm over it.
Carry on gentlemen.
CarPC:
Sound System:
Old 03-05-2009, 06:00 PM   #44
Confusion Master
Enforcer's Avatar
Adding those commands to the topmenu inc would probably do it for most of the screens.
Old 03-05-2009, 06:24 PM   #45
Raw Wave
treetop777's Avatar
Agree and you can use the skineditor to possition the buttons just right - WAIT! the skineditor don't support INC yet!
Virtual Earth cache builder? Or even gps simulator to make it cache? thepunkerguy DigitalMods (Scripts / API) 183 08-28-2008 09:58 PM
How To: Get your new skin out to the masses. monkeyracer RR FAQ 10 07-19-2008 08:59 AM
Digital FX 2.0 Transparent Released JohnWPB RR Skins No Longer Supported 3759 03-07-2008 01:23 PM
Mauri RR skin mauri RR Skins 122 12-06-2007 10:50 AM
IG3 Will not stay inside of the SKIN - opens in itsown Window..... dtragic GPS 4 11-29-2006 02:57 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
