Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 03-05-2009, 06:39 PM   #46
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Quote: Originally Posted by treetop777 View Post
Agree and you can use the skineditor to possition the buttons just right - WAIT! the skineditor don't support INC yet!
HA!
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 03-05-2009, 06:55 PM   #47
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Notepad does
Enforcer is offline   Reply With Quote
Old 03-05-2009, 10:41 PM   #48
monte_q is an unknown quantity at this point
Great skin i love your work
All versions of your skin just great nice setup i was wondering if i could get some help setting the date my computer date is correct but the date in the skin is off thank up.
monte_q is offline   Reply With Quote
Old 03-06-2009, 01:26 AM   #49
ronjon228's Avatar
ronjon228 is on a distinguished road
I had the same problem with my GPS receiver. It was setting the wrong time because it wasn't compensating for daylight savings time. Try adjusting your daylight savings time (if you have it), or turn off your auto update on your time. Might help.
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
ronjon228 is offline   Reply With Quote
Old 03-06-2009, 03:55 AM   #50
Confusion Master
Enforcer's Avatar
What do you mean off?
The date will be what the date is on the computer.
However the format may be changed in RRConfig.
Old 03-06-2009, 10:59 AM   #51
Valheru's Avatar
Valheru is an unknown quantity at this point
Can you explain this one a bit more please ?
The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0
Valheru is offline   Reply With Quote
Old 03-06-2009, 11:31 PM   #52
tangkas_baru is an unknown quantity at this point
nice skin. i like it.
i not use radio. how to change radio to camera function?
thanks
tangkas_baru
tangkas_baru is offline   Reply With Quote
Old 03-07-2009, 03:22 PM   #53
Valheru's Avatar
camera function ... this is currently not available yet in TEK4 ... but may be soon ...
do you mean reversing camera ?
Old 03-08-2009, 01:47 AM   #54
date
I dont have a gps connected to my computer but i cant seem to get the date on the skin to match my system date the time is correct but not the date its stuck on the 23 feb
Old 03-08-2009, 04:08 AM   #55
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
i see the same the date is not being produced, i'm stuck on 21st feb 2009.
which RR are you useing, also open tek skin folder go to support Rateings folder and double click the rateings.exe the date will change , the rate script is not getting launched on skin start thats all.
carputer1 is online now   Reply With Quote
Old 03-08-2009, 07:30 AM   #56
Valheru's Avatar
the issue is that the "ONSONGSTART" in not being executed on your system for some reason. This command calls the AI script to read the songs rating, but also does one or two other thing, like set the custom date variable.
Is it possible that you may have another "ONSONGSTART" running somewhere .. like in the RR Exectbl.ini file ???
Do you have activewinamp installed and the media library configured on your system .. this is "needed" for the ratings to work .. and also for the "rate.exe" to run properly ...
Old 03-08-2009, 10:38 PM   #57
Ok i hadnt done the ratings in the support folder yet i have just install the latest ride runner i will try that tonight and keep u guys posted thanks for pointing me in the right direction
Old 03-09-2009, 05:58 AM   #58
Valheru's Avatar
The ratings do not depend on the version of RR ... you need to install and configure Active-Winamp which is included with the TEKNIK4 skin, it's in the "Help Files -> Ratings" sub folder. If this app is not installed on your system then the date (as well as your ratings, and playlist position saving for the multichanger) will not work at all.
Oh BTW, this skin also required Winamp 5.13 - as Active Winamp does not function correctly with v2.95.
Old 03-09-2009, 03:19 PM   #59
fixed
Ok thanks guys i installed it and it all works now you guys are great thanks for taking the time to help me
Old 03-17-2009, 02:58 PM   #60
miatacarpc is an unknown quantity at this point
GMPC issues
Great skin - best I've found so far. Couple of issues though -
  1. System just flashes and disappears
  2. GMPC screen sometimes results in Autoit error "Varialbe used before initialization" or something like that
Any ideas?
EPIA NX15000G, OCZ 128GB 2.5" SSD, 1Gb RAM, 7" anti-reflective, transflective touchscreen, M1-ATX, HD-Radio, Bluetooth, GPS, WiFi, USB DVD+-RW.
miatacarpc is offline   Reply With Quote
Virtual Earth cache builder? Or even gps simulator to make it cache? thepunkerguy DigitalMods (Scripts / API) 183 08-28-2008 09:58 PM
How To: Get your new skin out to the masses. monkeyracer RR FAQ 10 07-19-2008 08:59 AM
Digital FX 2.0 Transparent Released JohnWPB RR Skins No Longer Supported 3759 03-07-2008 01:23 PM
Mauri RR skin mauri RR Skins 122 12-06-2007 10:50 AM
IG3 Will not stay inside of the SKIN - opens in itsown Window..... dtragic GPS 4 11-29-2006 02:57 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
