04-11-2009, 01:29 PM
#76
Raw Wave
Quote: Originally Posted by Valheru
i've seen a lot of comments about screens transitions and to be honest unless your car pc is really powerful i'd leave transitions off ... especially with GMPC.
..or you can exclude transitions in that particular screen by copying this to the .skin (courtesy of BlueZX3):
Code:
/EFFECTIN=-1
/EFFECTOUT=-1
/FORCEEFFECTS=TRUE
In this skin, i don't know i it would go in garmin.skin or external_gps.skin - would need to be tested.
04-13-2009, 04:13 AM
#77
thats a really usefull little trick - thanks for sharing treetop ...
07-02-2009, 03:43 PM
#78
Hey guys,
Can anyone suggest how i can get freefone to work with teknik 4?
Cheers
Ray
07-02-2009, 05:46 PM
#79
THE EXPERIMENTER
this will be the buttoncmd to launch freefone
LOAD;freefone.skin;FreeFone;$skinpath$\FreeFone.EX E;FreeFone
attached is a skin file with freefone already setup, just drop it into your tek folder and add the button cmd above and drop the freefone.swf into tek folder as well,the labels at the bottom saying freefone is your EXIT skin button,
should be good to go
07-02-2009, 07:03 PM
#80
cheers carputer...appreciate it
Ray
07-04-2009, 09:38 AM
#81
Happy independence day to all
and thanks for the great looking skin
07-05-2009, 08:30 PM
#82
I keep getting a trojan warning from Avast when trying to download this skin. I'm going to assume it's a false positive, but if someone else could check the link and confirm everything is cool, I'd appreciate it.
Dan from Minneapolis
07-06-2009, 08:50 AM
#83
I've just downloaded the RAR file here and scanned it with McAfee Enterprise 8.7i and it's scanning clean ...
07-25-2009, 09:14 PM
#84
If anyone still uses the Teknic V2 like me, Ive added these V4 menu icons to Teknic V2 menus.
08-27-2009, 05:36 AM
#85
I like Teknik v4.0 skin. I have 2 problem:
- I see the same the date is not being produced, i'm stuck on 21st feb 2009. How to fix?
- How to change logo Skoda to Honda?
tangkas_baru
my car pc: http://www.flickr.com/photos/tangkas_baru
08-27-2009, 03:54 PM
#86
hi tangkas_baru ..
the date is generated as part of the song rating script (rate.exe). have you ratings enabled on your system - as per the instructions included with the skin ?
without sounding too obvious, I'm guessing you are trying to chaange the logo from the logo selection screen (mainmenu 3 -> system -> logos). If this is not changing the logo for you then try editing the exectbl.ini and look for the line starting "CHANGELOGO" ... On this line is a "wait" command set to 0.2, change the 0.2 to be 0.5 or large. This is the delay in secs to wait before calling the external script to rebuild the splash screen (containing the logo).
valheru ..
08-28-2009, 05:25 PM
#87
first problem have been succeeding.
changes logo still have not can.
thanks valheru
tangkas_baru
08-29-2009, 01:07 AM
#88
THE EXPERIMENTER
dumb question , where is you logos folder , on your system ,for tek 2 it should be in the skin folder, do you get the list populated , do you use skintool if so open it to live debug log ,clear it then try to change logo and tell us what skintool says when done ,
08-31-2009, 07:15 AM
#89
I don't find logo problem in Teknik2.
I fail to change logo in Teknik4.
No problem... i like this skin.
tangkas_baru
09-02-2009, 07:35 AM
#90
Hi Valheru...
I have successfully changes logo after editing contents of "general.ini" like this:
OriginalWidth=800
OriginalHeight=600
ShowWidth=800
ShowHeight=600 --> ShowHeight=480
Thank you for your attention
tangkas_baru
| Thread Tools |
| Display Modes |
Linear Mode
