06-18-2006, 03:43 PM
#136
Update 6-18-06
Added my automatic player
Not only will it cycle thru the 4 players now but also it will cycle thru my presets in each player.
You can just have one player activated and it will just cycle thru the presets you select.
I intergraded an auto button in all my players to just cycle thru presets and read out runtime on the button. Also if you hold the button it will take you to the settings skin.
The cycle will automatically stop if you go to anther player
I forgot to put the add to rr.ini file down load at bottom of this first post
06-18-2006, 07:55 PM
#137
I cannot believe how complicated and advanced your skin is. Much props to you Chuck for the constant upgrading and hardwork you've put into this skin.
06-19-2006, 07:33 PM
#138
Update 6-1-06
Changed some stuff in the automatic player
Took out last screen setting works by itself now
Added hold and resume
Works with GPS mode in players now
Fixed lockup when you start with no players selected
Down load update.zip file at bottom of post 1
06-22-2006, 08:32 PM
#139
Update 6-21-06
Well I like this automatic player so much I decided to add all my presets.
Added manual mode set timer to 0
Added next and previous selection just use next and previous in all my skin at bottom right when automatic is running
Changed some stuff
Fixed a lot of stuff
Update file at bottom of post 1
06-25-2006, 10:18 AM
#140
Update 6-25-06
Automatic player changes
Added a little help scroll
Added indicator in bottom buttons so you know Which player is activated
Changed auto button in all players – white for single player mode red for switch player’s mode
Fixed xm last screen not working right
Update at bottom of post 1
06-27-2006, 07:10 PM
#141
Update 6-27-06
Did more stuff with automatic player
Fixed typeo-bug in xm not showing active xm
Added wait for end of song in audio player part
Changed timer 0 5 10 15 20 30 45
Added countdown for end of song
Added underline indicators to see whats going on with presets
06-28-2006, 02:34 PM
#142
Update 6-28-06
fixed audio not changing when radio is off
07-09-2006, 04:13 PM
#143
UPDATE 7-9-06
Added pic viewer with slide show
Multi player stuff
New quick menu
Now with auto mute so you dont hear all that junk wile the channels and play list are changing.
Wait for end of song now works XM and Sirius too. thx guino
Faster saves and restore thx guino
With this skin your better off not running an ExecTBL.ini in the RR directory just rename it
http://mywebpages.comcast.net/charlesrichards/ChucksSKINII.zip
07-09-2006, 08:15 PM
#144
Hey chuck how do u make your skin center with 800 by 600 its always going somewhere else on the screen
07-10-2006, 12:27 PM
#145
I do not understand what somewhere else on the screen is.
That space at the top is so you can see IG and copilot directions all the time when you hit the Nav-IG button a second time.
Then you can hit the bottom bar to get IG full screen.
Look at post #31
But you can change it in the general.ini file
07-10-2006, 12:35 PM
#146
Update 7-10-06
Had a bug in the ExecTBL.ini file with Sirius file at bottom of post 1
07-11-2006, 08:39 AM
#147
What I mean is i am using 800 X 600 but when i turn your skin on, you skin is not center. Its half off on the screen and I can still see the desktop. i tried to change your skin in the general.ini to 800X600 but then your skin looked funny
07-11-2006, 12:50 PM
#148
You need to turn Clear Type on and then it should look just as good as 1024x768
Control panel
Display
Appearance
Effects
Use the following method to smooth edges of screen fonts:
Clear Type
Then ok and apply
The setting in the General.ini file
OriginalWidth=1024
OriginalHeight=683
ShowWidth=800
ShowHeight=534
XPosition=0
YPosition=66
if you do not what the space at the top
OriginalWidth=1024
OriginalHeight=683
ShowWidth=800
ShowHeight=600
XPosition=0
YPosition=0
08-11-2006, 05:53 PM
#149
Why
Quote: Originally Posted by Chuck
why my skin doesn't look like this even after the update, can you help??
HOnda Accord '94
08-12-2006, 07:16 PM
#150
What does it look like?
Try removing these from the ExecTBL.ini From the Road Runner directory not the from the chucks directory
"ONFILECLICK",""
"ONDIRCLICK",""
"ONPLCLICK",""
"ONDLCLICK",""
"ONPBCLICK",""
"ONPLSELCLICK",""
"ONDLSELCLICK",""
"ONSONGSTART",""
"ONSKINSTART",""
and let me know
| Thread Tools |
| Display Modes |
Linear Mode
