08-15-2006, 02:09 AM
#151
Quote: Originally Posted by Chuck
What does it look like?
Try removing these from the ExecTBL.ini From the Road Runner directory – not the from the chucks directory
"ONFILECLICK",""
"ONDIRCLICK",""
"ONPLCLICK",""
"ONDLCLICK",""
"ONPBCLICK",""
"ONPLSELCLICK",""
"ONDLSELCLICK",""
"ONSONGSTART",""
"ONSKINSTART",""
and let me know
i thought you said to rename the whole file????
HOnda Accord '94
08-15-2006, 05:01 PM
#152
Renaming the file is ok but only the one in the Road Runner directory – not the from the chucks directory
Did you copy and paste the stuff from the -ADD TO rr.ini- to -rr.ini- file?
08-16-2006, 02:37 AM
#153
copy paste, and regarding the ExecTBL.ini i renamed the one in RR
HOnda Accord '94
08-17-2006, 08:10 PM
#154
UPDATE 8-17-06
Improved auto player
Added winamp library skin
Added some simple touch screen games
Added auto skin return to active player
Added all apps or action skin – second press of tools
Added DVD skin
Added a little help for all apps in setup skin
http://mywebpages.comcast.net/charlesrichards/ChucksSKINII.zip
With this skin your better off not running an ExecTBL.ini in the RR directory – just rename it
08-18-2006, 01:29 PM
#155
Quote: Originally Posted by DVLRCR
UPDATE 8-17-06
Added DVD skin
my out button doesn't do anything when i click on it!
when i click on connect it freez the whole thing
pictuer viewer too is not working
any help
HOnda Accord '94
Reason: forgot
08-18-2006, 02:48 PM
#156
1:What out button?
2:add phone=0 to the rr.ini
3:set path in rr.ini to your pic folder –sample >>> picspath=E:\Camera\6-18-99 Zoo
Sounds like you did not copy the new ADD TO rr.ini to the rr.ini file
08-19-2006, 02:43 AM
#157
1:What out button?
i mean the auto button sorry it was a type...
i did all this but still nothing , now all my buttons show "-MP3's-" as a lable
HOnda Accord '94
08-19-2006, 06:56 AM
#158
Do me a favor and zip up your rr.ini and ExecTBL.ini and post here for me
08-19-2006, 12:44 PM
#159
info you requested
here is the ExecTbl.ini "notice the name end with "_" this is the ExecTbl from RR dir.
rr.ini
HOnda Accord '94
08-19-2006, 01:51 PM
#160
let get past this step first
ok this as changed some how but you need to go to setup as soon as open RR and set the buttons the way you want them and save the prsets.
so try to change button presets and save then quit RR and restart and see if the setting you saved work and let me know.
this what i had in the rr.ini
BUTTONSET=0<<2<<35<<1<<3<<16<<5<<7<<8
BUTTONSET1=0<<2<<35<<1<<3<<16<<5<<7<<8
BUTTONSET2=7<<20<<6<<19<<9<<24<<10<<49<<43
BUTTONSET3=26<<28<<27<<33<<47<<46<<21<<34<<48
08-20-2006, 03:13 AM
#161
nope i tryed to change the buttons in the setup and saved them, and when i quit and run RR again it didn't work
HOnda Accord '94
08-20-2006, 07:18 AM
#162
I just cannot figure out what is going on with your setup so the only thing I can think of is start over.
Ok make sure you have at least 7-8-06 version of RR.exe
Rename your Chucks folder - ChucksOld
Down load CkucksSKINIIII.zip and unzip and make sure everything is new – just redid it today
Then open RR and select Chucks Skin then quit RR and restart RR to make sure Chucks skin starts as soon as RR starts.
Go to setup and try to change button preset 1 and save preset 1 then quit RR and restart and see if the setting you saved work and let me know.
08-24-2006, 02:07 PM
#163
idea
hey i will do what you told me, but i ve been busy latelly,. listen man i was driving the other day and i thought of an idea and i want to ask you if its doable with your skin:
on the Audio_Player skin, the slide bar on the right is it possable that when someone hit the down or up arrow , it'll display like a page number, for e.g. on my screen it fits 7 songs every page, so say i iknow there is a song on page "7", then i will scrol down untill i see "7" on the slide bar.??!!!
HOnda Accord '94
08-24-2006, 02:26 PM
#164
Not that I can think of right now
Just use skip to or in my skin its called goto
Or search – the magnifying glass
08-31-2006, 06:20 PM
#165
Update 8-31-06
--------- YOU MUST INSTALL CHUCKSRR FONT AND REINSTAL ALL CHUCKS FOLDER -----------------------
NEED TO ADD THE -ADD TO RR.INI FILE TO RR.INI FILE
Added song reminder – just touch bottom left to add song
All players use the same set of skin.jpg’s now
All buttons use text graphics instead of graphics on .jpg’s
Changed main menu – simplified it and add bass and treble back in
Changed xm and Sirius – now with preset menu
And the list goes on
| Thread Tools |
| Display Modes |
Linear Mode
