Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 11-10-2005, 06:49 PM   #46
zryder is on a distinguished road
Ok, so i played around with that file, and looked at others, got it resized, and it is awesome. Chuck, you are my hero! one more question though, how do you tell the skin what your gps info is, so it can display the embedded gps info. roadrunner knows what the com port is, but the skin doesnt seem to.
Thanks guys
zryder is offline   Reply With Quote
Old 11-10-2005, 07:26 PM   #47
Chuck's Avatar
Chuck is on a distinguished road
You need a second GPS receiver or a com port emulator one for RR and one for map
If you are using IG you can hit the music, fm, xm, button a second time and the map will show up in that skin. Once it is in that mode you can switch between then and GPS and never miss the map. Also if you are in that mode (say xm) and you go to GPS just hit the GPS button a second time and you go back to XM.
When you are not in that mode and you hit the GPS a second time it will go full screen and put IC info above the skin with RR in front that way you always see next turn. And if you need to see full screen just hit the bottom bar.
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 11-10-2005, 07:45 PM   #48
Chuck's Avatar
main menu update
you can click on clock to exit
2001 S10 ZR2
Old 11-10-2005, 07:56 PM   #49
ok, so do you suggest a good serial emulator? i have a BU-353 usb gps, that is reporting as com5. as for the rest of what you said, i really have no idea what you are talking about.. but you are still my hero! one more thing, you have the multicolor satalite signal level meters, how did you tell it you want thoes?
Old 11-10-2005, 08:11 PM   #50
Chuck's Avatar
I use DeLorme com port emulator and it splits up the com port but I think there is a compass and splitter or some thing like that, try a search
2001 S10 ZR2
Old 11-10-2005, 08:40 PM   #51
Chuck's Avatar
http://www.delorme.com/support/gps/lt20001.asp
2001 S10 ZR2
Old 11-11-2005, 01:01 PM   #52
markbuts3 is on a distinguished road
http://curioustech.home.insightbb.com/xport.html
Com port splitter ^^^^
Old setup
Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
markbuts3 is offline   Reply With Quote
Old 11-14-2005, 05:06 PM   #53
Chuck's Avatar
Update 11-14-05 (post #1)
Add volume amount to mute button
And push the Road Runner button over the clock and see what happens !!!!!!!!!! (post #3)
to exit push the clock
2001 S10 ZR2
Old 11-21-2005, 04:40 PM   #54
Chuck's Avatar
Update 11-21-05
Changed the alarm clock
Added a calendar
Added volume slider indicator over mute button in all skins
Fixed some bugs in gps skins
2001 S10 ZR2
Old 11-21-2005, 04:45 PM   #55
Chuck's Avatar
Alarm clock/calendar
2001 S10 ZR2
Old 11-22-2005, 03:27 PM   #56
Chuck's Avatar
I guess no one has pushed the Road Runner button in my skin yet.
Anyone?
2001 S10 ZR2
Old 11-23-2005, 02:38 AM   #57
Voyager_MP is on a distinguished road
Hi, Chuck, it really sucks,, no, just kidding..
I have a problem, gps dosen´t seem to load anything, no matter what I setup in roadrunner ini.
Strange, since this only accours with this skin. Any thing ?
Michel
Voyager_MP is offline   Reply With Quote
Old 11-23-2005, 12:55 PM   #58
Chuck's Avatar
What GPS program are you trying to load?
Just uploaded and it should put all files in the right place now , sorry
2001 S10 ZR2
Old 11-23-2005, 02:03 PM   #59
I tryed Map Monkey as well as Freedrive.
Noting happens, wenn I push the gps botton, your gps window comes up, but it dosen´t even tries to load any gps software.
What do I do with the Folders (program files) in your zip file, they are alle emty.
By the way, did I mention that I´m very now to this subject ?
Old 11-23-2005, 03:47 PM   #60
Chuck's Avatar
Maybe because I do not have any MM or FD skins
I was using DeLorm USA and now I use iGuidance along with CoPilot
Ok I redid the zip file again
2001 S10 ZR2
I'm dating a deaf chick Grayscale Off Topic 114 02-22-2006 05:47 PM
1994 ford explorer recessed lilliput lots of pics! xdjxklusivex Fabrication 13 01-06-2006 10:20 PM
Fusion of Zaurus and '00 Accord (lots o' pics) Xumbi Show off your project 18 07-12-2005 11:47 PM
1997 Chevy Trukputer - DONE! Lot's O' Pics! WHOOO HOOOO! voidunknown Show off your project 20 02-07-2005 10:58 AM
Can't create a post with lots of pics?? tbird2340 Mp3car Forum Suggestions/Comments 2 09-09-2004 02:43 PM
