05-07-2006, 01:11 PM
#106
Quote: Originally Posted by Chuck
Did you down load the 5-3-06 skin in post #1?
do you use XM?
is your Flash updated?
yes down loader post#1
no i do not use xm
HOnda Accord '94
05-07-2006, 02:09 PM
#107
take all the XMMUTE code out of the ExecTBL.ini File and see if that works.
/,-------------------------Mute Button-----------------------------
"MASTERMUTE","BYVAR;MUTEPRESET;MUTEALL<<HIGHLOW<<M UTEWAVEXM<<WAVEHIGHLOW"
"HIGHLOW","BYVAR;HIGHLOW;VOLLOW<<VOLHIGH"
"VOLLOW","SETVOL;master;10||XMMUTE||SETVAR;HIGHLOW ;1"
"VOLHIGH","SETVOL;master;79||XMMUTE||SETVAR;HIGHLO W;0"
"MUTEWAVEXM","MUTE;Wave||xmmute"
"MUTEALL","NEWMUTE||xmmute"
"NEWMUTE","MASTERMUTE"
"WAVEHIGHLOW","BYVAR;WAVEHIGHLOW2;WAVEVOLLOW<<WAVE VOLHIGH"
"WAVEVOLLOW","SETVOL;WAVE;10||XMMUTE||SETVAR;WAVEH IGHLOW2;1"
"WAVEVOLHIGH","SETVOL;WAVE;79||XMMUTE||SETVAR;WAVE HIGHLOW2;0"
Like this
"VOLLOW","SETVOL;master;10||SETVAR;HIGHLOW;1"
"VOLHIGH","SETVOL;master;79||SETVAR;HIGHLOW;0"
"MUTEWAVEXM","MUTE;Wave"
"MUTEALL","NEWMUTE"
"WAVEVOLLOW","SETVOL;WAVE;10||SETVAR;WAVEHIGHLOW2; 1"
"WAVEVOLHIGH","SETVOL;WAVE;79||SETVAR;WAVEHIGHLOW2 ;0"
05-07-2006, 02:40 PM
#108
no i do not use xm
Your pm is full
I think it is a flash problem because both the calendar and the radar use it.
Try updating your flash
http://www.adobe.com/shockwave/downl...ShockwaveFlash
05-08-2006, 03:29 PM
#109
double post
05-08-2006, 03:30 PM
#110
Chuck your da man  . Your skin is the only reason im using RR. However i am having a problem. Im having a hard time getting Streets and trips 2005 to work. Not only will not load but im wanting it in with the skin. is there something i can change or do to get it going?
i have  also
thanks
05-08-2006, 03:56 PM
#111
You need to change this line in the ExecTBL.ini file in your skin directory
"STREETGPS","LOAD;EXTERNAL_GPS.skin;Navigation;C:\ Program Files\Street Atlas USA 2004+\SA2004+.exe;DeLorme Street Atlas USA® 2004 Plus"
maybe to this
"STREETGPS","LOAD;EXTERNAL_GPS.skin;Navigation;C:\ Program Files\Street Atlas USA 2005\SA2005.exe;DeLorme Street"
05-08-2006, 03:58 PM
#112
is that a space before Program Files? watch out
CarPC #3: 99% CompletePentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more! old carPC
05-08-2006, 04:03 PM
#113
For some reason this board does that – adds spaces
05-08-2006, 05:18 PM
#114
No voice no problem
hmmm thats not nice, but o well bye bye voice then  and welcome chuck skin. more question.
is there is any way i can fix this. it doesn't wanna fit the screen.
HOnda Accord '94
05-08-2006, 06:14 PM
#115
That space at the top is so you can see IG and copilot directions all the time when you hit the NAV button a second time.
but you can change it in the general.ini file
05-08-2006, 07:34 PM
#116
You know you can go to the setup menu and add Vol- and Vol+ to the bottom buttons.
05-09-2006, 02:10 PM
#117
Audio not working
Anyone has a problem when click on audio button.
for some reason when i click on radio button, i get no response from anything, i'll have to go to taskbar and right click on RR then choose close?
HOnda Accord '94
05-09-2006, 02:38 PM
#118
Update 2-4-06 you need to change all form1 to MoonPhase in the ExecTBL.ini – I missed some
Chuck when i did that the moon phase will not be aligned at all, pluse when i close RR the "flash""form1" file will still be on the taskbar waitting for me to close it !!! any suggestion
thanks in advance
HOnda Accord '94
05-10-2006, 01:13 PM
#119
thanks in advance
That was for the older one not this one
05-10-2006, 01:18 PM
#120
does weather have to be xm? could you make a path for pulling it off of weather.com (or other)automatically when your in range/have www connnectivity?
| Thread Tools |
| Display Modes |
Linear Mode
