Quote: Originally Posted by 2000Jeep
Did not know that and cant figure out how get it to show. Is it in the main RR set up?
From the main menu or tool menu – the first one that comes up when you start RR
Press the setup button on the left and pick the bottom button you want to use for VOL- then pick the VOL- from the menu. You should see VOL- on the button you selected and save preset 1.
For this to work you need to pick NAV-USA from my setup menu – note the end of the command line and this ( /,) in front of the command line will just ignore the hole command.
"STREETGPS","LOAD;EXTERNAL_GPS.skin;Navigation ;C: \Program Files\Microsoft Streets and Trips\Streets.exe;Map File 1"
Should look like this
