Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 08-05-2005, 05:41 PM   #1
Chuck's Avatar
Chuck is on a distinguished road
Chuck's Skins lots of pics Update 7-16-07
Well I tried to make this skin more universal
UPDATE 7-16-07
fixed stuff
UPDATE 4-22-07
added input setup
added gasnav with some mods
added Sonicxtacy02 Current location stuff
added Sonicxtacy02 auto weather city
added pause play indicator to audio button
Inatall setup will add localdatacaptureinterval=1, voice=true, fastmode=-1 to the rr.ini
and lots of tweeks
http://mysite.verizon.net/charles.ri...sSkinXVIII.zip
UPDATE 4-7-07
Changer will change presets in x amount of time instead of switching players, will also keep changing even if you go to different players.
Fixed auto day night skin changes so you will not get the gray box when coming out of hibernation.
Option to turn on and off music mute on voice say. – thx guino
Install setup will now install font
Install setup will now install GDI+ stuff
UPDATE 3-31-07
Added 5 stage dimmer +1, 0, -1, -2, -3 and these can be set for auto day night skin change.
Improved auto weather and traffic update.
UPDATE 3-25-06
Added Auto day night skin changes.
Changed the skin setup to use the actual audio player.jpg’s files so if you mod a skin it will show up – loads slower.
Improved the auto update stuff.
Fixed some bugs
Update 3-17-07
Well this auto update thing is working excellent.
There different modes
Auto WiFi, Auto Cell phone and both together.
In auto WiFi you set the intervals to start hunting for a connection and when it finds one it checks to make sure your not going over the max speed you have set and downloads then starts the timer over.
In Auto Cell phone you set the intervals to start the dial-up and downloads at intervals set.
If auto WiFi and Auto Cell phone are selected it will start hunting for a WiFi connection at intervals set and if no connections are found it will start the cell timer and if no connections are found then start the dial-up and downloads
Update 3-11-07
I think I have the Net detect and auto update perfected now.
This Net detect senses RR and if RR closes then Net detect will close itself also will close itself if BYVAR;NETDETECT;0.
This Net detect will only down load if, set interval, ping and vehicle speed has been met.
This net detect has settings for update intervals, vehicle speed, ping intervals, ping timeout, site to ping, auto weather, auto traffic and a auto custom and every thing can be set from the skin on the fly.
Also added auto custom so you can have the netdetect update or run anything RR will do at update time. – hold the custom button to set.
The weather and traffic .exe’s have been refined to integrate with RR and fail safe the files they are downloading so if a file failed they restore the old file till the next download.
The weather updater will check to see if weather.com is present before running “RELOADWEATHER” command. – how many times have you had RR hang because of this.
These files are for this skin so good luck trying to use them in your skin.
Update 3-7-07
I did so much junk that I don’t even remembers what I did.
UPDATE 2-19-07
Totally changed all the setup stuff - Will not have to hunt for them.
Added Traffic Map Plugin--by moahdib.
Added display memory so it will remember the last display color in each skin.
Will need to do a full install and clean out old chucks stuff in rr.ini.
And Lots more.
UPDATE 2-4-07
Added skin picker for the 6 skins.
Added option for day night skin settings - Just hold the skin in the skin picker.
Added option for IG v2 or v3 - just change IGVERSION=2 or IGVERSION=3 in the skin.ini file.
Display color change will now also change sliders and compass colors.
UPDATE 1-27-07
Added Left Top display menu with options for net detect, and display change
Added Net Detect with setup menu
Added auto update weather
Added 5 Skins and no switching folders
changed volume menu button setting - mute/menu = mute on press, menu on hold - menu/mute = menu on press, mute on hold - Set ATT low by holding ATT button at low volume sttting
changed bottom bar to do last screen on hold
Changed voice to work with any SAPI 4 or 5
Lots of tweaks
UPDATE 1-7-07
Added Recorder
option to record in alarm - timer
option for voice on song change - need SAPI 4 text-to-speech engine
Redid changer to just switch players in x amount of time – no more presets
Update 12-14-06
Changed old XM Sirius weather, news, sports skin to settable presets including page name.
Pic viewer with settable path now
Update 12-10-06
Added Radio preset labels - stations
Changed XM and Sirius presets - no more menu - replaces playlist - no more typeing in name or channel - just tune channel and hold preset button
In xm,Sirius preset mode – always remembers last preset played
no more xm,Sirius art - Tired of updating and they just did not go with this skin
More efficient skin switches
Update 11-27-06
all new look
auto gps
alarm clock - timer
IG v2 Next turn mode
better help
Update 10-19-06
Fixed standard mute
Update for vol at bottom of this post
Update 10-18-06
Changed volume slide out stuff only
Added separate high low
Made slider vol work
Will exit after 45 sec if just opened
If muted it will stay open
If mute turned off it will close immediately
If you hit high or low wile muted it will close immediately
If you hit vol+, vol-, high, low it will close 8 sec after last press
UPDATE 10-16-06 PM
Added volume slide out so you can get vol from any skin with one button press – must set option in setup menu – Volume slide
UPDATE 10-16-06
Added gas log
Added first run setup screen
Redid Maintenance and added save to file
Redid song reminder and added save to file
Fixed mp3 preset button 10 not saving
Added Readme file
And some other stuff
UPDATE 4-5-06
Added XM, Sirius direct tune – no need to add to list or hunt list just put in number and hit enter.
Fixed top being black on start - sometimes.
Fixed timer diapering in player gps mode
UPDATE 10-4-06
Added a split top to fill the screen – I think this is a big +
Added weather presets – need RR beta
Color change also changes timer and top – thx kembond
Fixed mp3 preset remembering wrong track numbers after restart of RR
UPDATE 9-28-06
Added TrafficDetails with 50 city presets – Thanks Sonicxtacy02
Fixed a lot of bugs
Changed pics below
Update 9-16-06
Need to do a complete install
Need to reinstall font
Need to add my rr.ini to rr.ini
Added a power button to stops whatever player is running and turns off the display also cuts cpu almost down to nothing
Hit any button and display comes back on and the music playing in whatever player was going
Added gas. – hit any gas station and the address will to go track name in gas and gps skin
Changed the moon phase to a big clock – top left
Change top display color on the fly. – three colors
Audio preset buttons that remembers track numbers in each preset.
Smoother skin switches.
Added a trip meter. – thanks to festy
All indicators and buttons use text graphics for easier mods. – thanks guino
Moved control and MP3 Preset folders in chucks folder
Chopped this thing way down and now there is only 33 skin.jpg to edit the whole skin. - 14 of those are menus
I changed just about everything
Update 8-31-06
--------- YOU MUST INSTALL CHUCKSRR FONT AND REINSTAL ALL CHUCKS FOLDER -----------------------
NEED TO ADD THE -ADD TO RR.INI FILE TO RR.INI FILE
Added song reminder – just touch bottom left to add song
All players use the same set of skin.jpg’s now
All buttons use text graphics instead of graphics on .jpg’s
Changed main menu – simplified it and add bass and treble back in
Changed xm and Sirius – now with preset menu
And the list goes on
With this skin your better off not running an ExecTBL.ini in the RR directory – just rename it
UPDATE 8-17-06
Improved auto player
Added winamp library skin
Added some simple touch screen games
Added auto skin return to active player
Added all apps or action skin – second press of tools
Added DVD skin
Added a little help for all apps in setup skin
Update 7-10-06
Had a bug in the ExecTBL.ini file with Sirius – file at bottom of post 1
UPDATE 7-9-06
Added pic viewer with slide show
Multi player stuff
New quick menu
Now with auto mute so you don’t hear all that junk wile the channels and play list are changing.
Wait for end of song now works XM and Sirius too. – thx guino
Faster saves and restore – thx guino
Update 6-28-06
fixed audio not changing when radio is off
Update at bottom of post 1
Update 6-27-06
Did more stuff with automatic player
Fixed typeo-bug in xm – not showing active xm
Added wait for end of song in audio player part
Changed timer 0 5 10 15 20 30 45
Added countdown for end of song
Added underline indicators to see what’s going on with presets
Chuck is offline   Reply With Quote
Old 08-05-2005, 05:43 PM   #2
Chuck's Avatar
Setup
2001 S10 ZR2
Chucks Skin - to old
Old 08-05-2005, 05:47 PM   #3
Chuck's Avatar
main - tools
2001 S10 ZR2
Old 08-05-2005, 05:52 PM   #4
Chuck's Avatar
Audio player
2001 S10 ZR2
Old 08-05-2005, 05:54 PM   #5
Chuck's Avatar
audio browser
2001 S10 ZR2
Old 08-05-2005, 05:57 PM   #6
Chuck's Avatar
Changer
2001 S10 ZR2
Old 08-05-2005, 06:02 PM   #7
Chuck's Avatar
Changer setup
2001 S10 ZR2
Old 08-05-2005, 06:13 PM   #8
Chuck's Avatar
Traffic with 50 preset citys
2001 S10 ZR2
Old 08-05-2005, 06:17 PM   #9
Chuck's Avatar
iGuidance
2001 S10 ZR2
Old 08-05-2005, 06:20 PM   #10
Chuck's Avatar
Radar
2001 S10 ZR2
Old 08-05-2005, 06:22 PM   #11
Chuck's Avatar
Song Reminder
2001 S10 ZR2
Old 08-05-2005, 06:28 PM   #12
Chuck's Avatar
Maintenance
2001 S10 ZR2
Old 08-05-2005, 11:08 PM   #13
d_sellers1's Avatar
d_sellers1 is on a distinguished road
Looks really good but my only question is where can I download it or is it only available for personal use?
Derek
EDIT: Wow. This is an old post from when Chuck only posted screenshots and wouldn't release the skin.... ahhh.. memories...
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Old 08-06-2005, 01:13 AM   #14
pimpmode's Avatar
pimpmode is on a distinguished road
yeah that looks really clean...would you mind sharing???
97 Pontiac Grand Prix GTP
P4 2.4
Freetech MoBo
DSATX 220W
512 MB ram
200 GB Maxtor harddrive
Road Runner
Iguidance 2.1
EZSync 1.94
pimpmode is offline   Reply With Quote
Old 08-06-2005, 01:25 AM   #15
wariow is on a distinguished road
this for Road RUnner?
wariow is offline   Reply With Quote
I'm dating a deaf chick Grayscale Off Topic 114 02-22-2006 05:47 PM
1994 ford explorer recessed lilliput lots of pics! xdjxklusivex Fabrication 13 01-06-2006 10:20 PM
Fusion of Zaurus and '00 Accord (lots o' pics) Xumbi Show off your project 18 07-12-2005 11:47 PM
1997 Chevy Trukputer - DONE! Lot's O' Pics! WHOOO HOOOO! voidunknown Show off your project 20 02-07-2005 10:58 AM
Can't create a post with lots of pics?? tbird2340 Mp3car Forum Suggestions/Comments 2 09-09-2004 02:43 PM
