Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 10-06-2006, 03:11 PM   #286
sparkyssb is on a distinguished road
Post
Oh wow... I didn't know that it was that easy! Great..thank you. I will play with it very shortly.
sparkyssb is offline   Reply With Quote
Old 10-06-2006, 05:33 PM   #287
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Sirius Skin
When you are done, if you can, post the Sirius Skin text file here in the thread. That way others can use it as well. You do not need to include the .jpg's, as they are the same for both skins.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 10-10-2006, 04:35 AM   #288
aal2000 is on a distinguished road
I have integrated AverTV 6.0 in Simplistique skin. Everything works great except just one thing. From menu.skin I launch avertv application and also I send the stop command in order to stop music player avoiding that music and TV sound overlay.
"LOAD;AVerTV.skin;AVerTV;C:\AVerTV\AVerTV.exe;!AVe rTV_Video!AverTV - Video||STOP"
The problem is that STOP command does not work so I need to do the stop manually. Any help on that?
aal2000 is offline   Reply With Quote
Old 10-10-2006, 08:47 AM   #289
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Put the stop before the load command.
ie.
"STOP||LOAD;AVerTV.skin;AVerTV;C:\AVerTV\AVerTV.ex e;!AVe rTV_Video!AverTV - Video"
Enforcer is offline   Reply With Quote
Old 10-11-2006, 11:55 AM   #290
Thanks. I will try
Old 10-13-2006, 06:37 AM   #291
Fix it. Thanks
Old 10-13-2006, 04:10 PM   #293
ncholm is an unknown quantity at this point
Can anyone tell me how to intergrate/embed WinAmp TV (Cinergy 600)
instead of the AVerTV one ??
And LLOYDY thanks for a cool skin.
Thansk in advance
ncholm is offline   Reply With Quote
Old 10-14-2006, 07:24 AM   #295
Hey Enforcer
Thanks, but i ment embed Cinergy600 using WinAmpTV in the "Simplistique" skin ...
Don't i need to change something in the menu.skin and/or in the AVerTV.skin file ??
Old 10-14-2006, 08:10 AM   #296
Confusion Master
Enforcer's Avatar
if it's just for the TV/video side then if the winampTV thing will work in the skin then setting up the winamp Tv module for whatever TV/Video/Camera you have should allow it to work kin the skin. (assuming you have the skin parts that allow aal2000 to use his averTV.
Unless I am misunderstanding something (always possible)
Old 10-17-2006, 12:45 AM   #297
Sirius Skin
Here is a skin for Sirius support in Simplistique. It uses the same JPEG's as JohnWPB but the txt file includes the Sirius commands. Hope this can be use for somebody!
You can either create a file called SIRIUS.skin with the below text and download JohnWPB's zip for XM support and rename the JPEG's as SIRIUS_ON.jpg, SIRIUS_OFF.jpg, and SIRIUS_DOWN.jpg
OR here is the whole zip file that includes everything you need...just download and copy into the Simplistique directory.
Code:
MEDIACAR Skin MEDIACAR "radioplayer" Skin SIRIUS_OFF.jpg,SIRIUS_OFF.jpg,SIRIUS_ON.jpg,SIRIUS_DOWN.jpg /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B05,1,305,117,94,"SRNEWLIST", B08,126,303,134,93,"SRDELLIST", B09,-1,207,119,88,"SRADD1", B11,114,400,119,89,"NEXT", B12,122,210,130,84,"SRMINUS1", B14,2,405,111,81,"Prev", B15,737,318,60,54,"PGDOWN","Page down" B16,739,381,56,56,"DOWN","Down" B17,737,161,059,54,"UP","Up" B18,737,224,60,56,"PGUP","Page up" B21,1,500,110,98,"EXIT","Exit" B06,540,495,88,95,"VOL-","Volume-" B07,631,504,87,98,"VOL+","Volume+" B08,124,503,102,94,"MIXER","Mixer" /, I, x, y, w, h, Code;INDICATORCODES I06,715,502,91,95,"MASTERMUTE" /, Y, Back Slider file path Y01,"\volume_slider\volume_*.jpg" /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip S01,209,88,88,26,209,69,215,26,H,01,"",013,"SRTER","Ter Signal" S02,54,89,83,25,54,69,215,25,H,01,"",013,"SRSAT","Sat Signal" S03,303,520,215,46,303,520,True,46,H,01,"",013,"MASTER","Master" /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT L01,562,89,232,34,255,255,0,18,"DotMatrix:B","SRSTATION","CENTER" L02,7,44,34,29,255,255,0,18,"Arial:B","TRACKNUMBER", /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B,-10,113,350,83,"SRFAV", /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT L03,48,47,451,31,255,102,0,18,"Digital Readout Thick Upright:B","/ ||TAGARTIST||= - ||TAGTITLE||=","SCROLLLEFT" /, J, x, y, w, h J,653,5,78,77 /, I, x, y, w, h, Code;INDICATORCODES I06,740,395,55,34,"BOTTOMPL" I06,740,172,55,32,"TOPPL" /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name S01,377,164,344,270,255,255,255,57,57,57,192,192,192,255,102,0,255,255,255,TRUE,14,"Arial Narrow:B" END
That's it for now. Thanks JohnWPB for the JPEG's.
Old 10-26-2006, 04:11 PM   #298
BavarianBuilt's Avatar
BavarianBuilt is an unknown quantity at this point
Has anyone had any luck with powerdvd 6 in this skin? I've tried both powerdvd 6 and powerdvd 7, both with no success. If you are successfully running powerdvd 6, what are your settings? TIA!
BavarianBuilt is offline   Reply With Quote
Old 11-02-2006, 08:59 AM   #299
proph's Avatar
proph is on a distinguished road
Hey JohnWPB,
Are you up for building a CDRip Skin for Simplistique?
Setup:
Dynaudio 240GT
PPI PC4100, PPI PC2350
Zapco DSP6
ADS DAC
Testing new board (Albatron KI690-AM2)
"I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
proph is offline   Reply With Quote
Old 11-07-2006, 07:59 PM   #300
john94587's Avatar
john94587 is on a distinguished road
Quote: Originally Posted by JohnWPB View Post
Well Tissy just emailed me a couple variations of the clock with difffrent colors to better fit my color altered Simplistique skin. WoW! MUCH better! Many thanks to Tissy for taking the time to do that for me! Donation on it's way!!!! It really tie's it all in and makes it look very clean!
Here is a screen capture of the skin with the clock in all it's glory!
Hey John, Think I can get a copy of the this skin in that color?? It matches my car perfectly. Thanks.
john94587 is offline   Reply With Quote
MMI eXtnd proTONEd FP Skins 77 04-17-2008 06:26 AM
Headunit (Linux/Windows CarPC frontend) + initial screenshots NoPistonPC Other Cool Front Ends 321 08-24-2007 03:57 PM
mac style skin release... btbe RR Skins 42 08-14-2007 10:07 AM
RR Holistic v2.2 Beta skin is ready for download holistic RR Skins 44 02-05-2007 10:21 AM
iGmod Beta 2 release PURDooM Other Cool Stuff 625 05-12-2006 03:52 PM
