Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 03-30-2008, 12:36 AM   #436
lloydy is on a distinguished road
I have recently got myself a USB DAB radio receiver and car indoor car antenna, and created a very crude skin for Simplistique for it. Performance (reception) is very good (much better than my FM). Works very well in Cardiff and London - though not very good on the motorway in between. The software is awful too.
In case anyone else was after decent DAB radio in the UK here's what I've got:
- MTech A1 USB DAB (http://www.mtech.com.tw/productsconsumer_udr.htm)
- DAB only internal glass mounted aerial with amplifier (as seen here: http://www.bluespot.co.uk/dab.asp)
- homemade connector to fit the two together
I'm looking to update my car PC soon with a fresh new look for Simplistique and hopefully a solid state solution (my HD sometimes causes the PC to crash so I think its on its way out). SSDs are a bit pricey at the moment so mite look into sticking windows on a flash drive. Also need to update GPS and TV card hardware/software.
PLAN:
- New GPS mapping software and mods to fit in with the new skin
- New FM software hacks to fit in with the new skin
- Stick Windows on a flash/SSD drive
- New digiTV hardware
- Add phone functionality and properly integrate it to skin
- Add new skin features such as easy music transfer from USB stick and Google mapping etc
- New hardware for permanent connection to internet for car PC (3G USB datacard)
When I get all this done I'll post the skins here for download.
Sorry this is brief but I'm VERY busy with uni work at the moment.
@EVERYONE
Skin modifications I've seen are excellent (some are a bit busy taking away the simplistic-ness of Simplistique but very nice nonetheless). Keep up the good work. I will do my best to make the new revamped skin as feature-packed as possible and incorporate all these added features.
LLOYDY
lloydy is offline   Reply With Quote
Old 03-30-2008, 07:20 AM   #437
CookieMonster is an unknown quantity at this point
Great to see you back LLoyydy, cant wait to see the new skins your making.
I bought a Silabs USB radio from Azzuri @ azzuri.com I think enforcer or another user has tried it and made a skin for it, I only received mine yesterday so haven't looked at integrating it yet or checking out available skins, its a nice simple .exe that runs from anywhere, might be worth a look.
I used FreeFone to integrate my mobile into my carPC, works well but I have my mobile on O2 so I get free internet access, I use the blue tooth to get internet access but this then blocks FreeFone from accessing the phone using the bluetooth port (still looking at this one, may try xport).
I removed the TV icon and replaced it with a 0 lux webcam, this then opens the Philips capture software, I was planning to have this record a small video & audio file and email it should the wrong access code be entered more than twice. Main reason for this was I couldn't get any TV reception using a pinnacle USB TV/Radio tuner and gave up after a short time.
I removed the DVD icon and replaced it with a WiFi button which then opens NetStumbler for plotting access points using the GPS. I didn't plan on a DVD drive in my install so no need for the button.
I did add the petrol skin to the radio button only to find that there's not plugin for the UK available at present, so the plan is to "switch" the skin back to the radio skin now I have my silabs USB radio.
GPS, well I'm having mixed success with MapMonkey, I have the latest UK maps and surprisingly my house is on it (normally it doesn't show up as its only been built 5 years) but other addresses which have been around longer than me don't show? I'm now looking at iGuidance to see if it's more reliable, I'm used to good old TomTom who's never really done wrong by me, if iGuidance fails I may look at using the free emulator from Microsoft to get TomTom running on PC.
I really like the idea of using SD card to run the OS, I've lost 2 100GB 2.5" drives in my 1st CarPC I assume due to vibration, both drives were mounted on rubber feet to reduce the effects of the car moving but still they didn't last long and my latest PC seems to be going the same way. I might move the OS to a 4GB flash drive and have the media on a removable 2.5" HDD in a mini caddy.
This is my 2nd real CarPC install and TBH, your skin gives the whole CarPC install an OEM "professional" look to it, many thanks to you for starting the project and a big thanks to everyone who contributed to it in this thread, many of the things I wanted to implement some one else had already done the work, making my install a lot easier.
I would post my work on the skin but its mainly slight variations on whats already available in this thread.
Looking forward to the new skin (try not to make us wait too long ) and GL with your Uni stuff.
PS: Just a thought! do you think with the new skin you could also provide a "blank" skin with no icons or text for the buttons so we can map the buttons add text and icons as needed for our builds?
CookieMonster is offline   Reply With Quote
Old 04-12-2008, 03:10 PM   #438
Jon-G's Avatar
Jon-G is on a distinguished road
Iv created this skin for the VAG-COM main form and another I am working on for the Auto-Scan form which I plan to load under the Solitaire skin to fit with the modified simplistique theme Im using (blues and reds for VW).
I have skinbedder launching and grabbing VAG-COM however the buttons dont seem to work. Can anyone give me any advise? Heres my skinbedder VAG-COM folder:
Does anyone have any idea where Im going wrong? Want get this finished and shared up!
Jon
Jon-G is offline   Reply With Quote
Old 04-12-2008, 03:30 PM   #439
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by CookieMonster View Post
I bought a Silabs USB radio from Azzuri @ azzuri.com I think enforcer or another user has tried it and made a skin for it ?
Not me
Enforcer is offline   Reply With Quote
Old 04-28-2008, 11:12 AM   #440
Jon-G's Avatar
Jon
Anyone any ideas? Info on skinbedder is like hens teeth!
Old 05-05-2008, 04:04 AM   #441
dragaox is an unknown quantity at this point
Smile
I was wounderin about the picture icons of the different music. None show up for me other then that it works fine do u know why? maybe cause it's in a different format or because i got these where i shouldn't of got these and thats why they aren't displaying proper? Hopefuly u know what i mean
dragaox is offline   Reply With Quote
Old 05-05-2008, 08:53 AM   #442
Jon-G's Avatar
Are you talking about the Mixer skin presets for Winamp? If so you need to edit the .pst files in the RR root directory to set up the sliders as you want. By default all mine muted the audio so I have just set them all up like the Jazz one for the time being until I fine tune each of the sliders.
Hope this helps or Im way off the mark! If not you need to include some more info as to your specific problem if you want help from the guys off here []
Old 05-05-2008, 12:11 PM   #443
In these 2 pictures from the first post you can see they have picture icons for every catergory. This is what i'm havin trouble with. No picture displays for me
Old 05-05-2008, 06:30 PM   #444
Jon-G's Avatar
make sure there is a file called folder.jpg in each artist/album folder. If you have copied the folders as created by media player etc, you will need to remove the hidden attribute from the folder.jpg file, and should delete all the other jpgs that you do not want displayed...
hope this helps
Old 05-06-2008, 07:27 AM   #445
easy is an unknown quantity at this point
Quote: Originally Posted by Tissy View Post
FreeFone skin for the excellent in-car phone application developed by CdRsKuLl (www.freedrive.co.uk)
Download - http://www.wrx-carpc.co.uk/downloads/freefone.zip
How do I skin freefone with this?
easy is offline   Reply With Quote
Old 05-06-2008, 08:15 AM   #446
Confusion Master
Enforcer's Avatar
It does change the actaul freefone image, just the screens that it embeds into for simplistique.
Just download, unzip and drop into you simplitique skins folder.
You will then need to create a button in one of the menu screens to load the freefone.skin.
Old 05-06-2008, 10:04 AM   #447
Did that,
When I click on Telephone in the simplistique screen nothing happens...
Does not even show the phone skin?
How do I create a button in one of the menu screens to load the freefone.skin?
Old 05-06-2008, 10:38 AM   #448
MGD
MGD's Avatar
MGD is on a distinguished road
Ok now, we know freefone is an external app. What are we doing with an external app?
We call it.
"LOAD;Freefone.skin||RUN;$SKINPATH$Freefone.ex e"
Make sure freefone.exe is in you skin folder.
MGD is offline   Reply With Quote
Old 05-06-2008, 10:39 AM   #449
Confusion Master
Enforcer's Avatar
Have a look on the simplistique skin folder, edit menu2.skin with notepad, locate the following line
B02,0,212,270,80,"",""
replace with
Code:
. . B02,0,212,270,80,"LOAD;freefone.skin;FreeFone;$skinpath$FreeFone.EXE;FreeFone","" . .
or
add the following to ExecTBL.ini
Code:
. . "FREEFONE","LOAD;freefone.skin;FreeFone;$skinpath$FreeFone.EXE;FreeFone" . .
and change the
to
B02,0,212,270,80,"FREEFONE",""
Old 07-08-2008, 02:19 PM   #450
qbunnie is an unknown quantity at this point
Windows Mobile Phone skin
I made a simple skin to use with MyMobiler, a free, easy, and awesome program that puts the windows mobile phone interface on your desktop.
You can find it at http://www.mtux.com/
Just have a button launch this skin
"LOAD;Phone.skin;Phone;C:\PUT MYMOBILER.EXE PATH HERE\MyMobiler.exe -open;!My Mobiler"
Please note, by default My Mobiler doesn't install onto Program Files. If that is what you want, then make sure to move it there.
Also please note that the latest version of My Mobiler is skinnable. I'm using the default example skin, but it does not look too difficult to make it much more vehicle friendly.
Here are some screens:
qbunnie is offline   Reply With Quote
MMI eXtnd proTONEd FP Skins 77 04-17-2008 06:26 AM
Headunit (Linux/Windows CarPC frontend) + initial screenshots NoPistonPC Other Cool Front Ends 321 08-24-2007 03:57 PM
mac style skin release... btbe RR Skins 42 08-14-2007 10:07 AM
RR Holistic v2.2 Beta skin is ready for download holistic RR Skins 44 02-05-2007 10:21 AM
iGmod Beta 2 release PURDooM Other Cool Stuff 625 05-12-2006 03:52 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
