07-04-2006, 12:02 PM
#31
Quote: Originally Posted by CBDZ
okpleae don't call me stupid, but i have downloaded the "rar" file. what do i do with it??
Well, extract all files with Winrar, copy the BMW E36 directory to the skins directory under RoadRunner then open the directory named "Fonts to be installed" and copy the two files in "C:\WINDOWS\Fonts".
There is also a directory named "FreeDrive", if you use this program as GPS navigator, you must copy the file "sdk.ini" in your FreeDrive installation directory.
Good luck!
07-04-2006, 12:49 PM
#32
Quote: Originally Posted by jaba
è davvero bella la tua skin.volevo utilizzarla però non sono riuscito a mettere in freedrive extra poi e quindi sto usando garonav anche se trovo freedrive migliore.puoi spiegarmi come modificare la skin per usare garonav e far apparire la via e le indicazioni in main page come fa adesso con freedrive.oppure magari se si può inserire extra poi in freedrive puoi spiegarmi come fare?grazie.
se vuoi contattarmi sono su msn: eipicchi@tin.it
ciaooooooooooooo
Controlla i tuoi messaggi privati...
Check yours private messages...
07-04-2006, 01:08 PM
#33
Quote: Originally Posted by Griff1
As your the resident Phoco Master i was hoping you could give me some skinning advice??
I've been looking through your skin for pointers but i'm getting a bit lost (its too complete) there's more to skinning phoco than i thought.
Anyway, i'm looking for a way to show the calls options in different screens,
for example 1 sub menu with IN,OUT,MISSED,DIALLED and pressing any 1 of these buttons loads a fresh screen with the selected info, Can this be done??
Currently they only work in the skin they are called from,is there a way round this with maybe an ONSKIN Launch EVENT??
Thanks Robby,SORRY for the off topic Q's.
Not sure if it is possible, but try this:
Create your sub menu with all the buttons you need then put on each button a comand like:
"EXIT||LOAD;<your screen>.skin||SHOWMISSEDCALLS"
where <your screen> is the name of the screen you want to load to show the selected info.
Don't forget to put a P area in the screen you load to show the call list.
Let me know if it works...
07-06-2006, 03:31 PM
#34
Stank Cheese
Does this skin include XM or will I have to modify it? Im at work or Id test it unstead of asking. Sorry for acting like a noob.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
07-07-2006, 10:59 AM
#35
Ottima versione....anche se non ho capito bene la parte del mixer...???
Solo un appunto (per altro già fatto): potresti nelle prossime versioni mettere il logo modificabile??? io ho una ford e il logo BMW non sta tanto bene (ho dovuto cancellarlo sulle 3 parti con psp.....).
Ciao e di nuovo ottimo lavoro!!!!!!!
Alex
07-07-2006, 11:50 AM
#36
I'm sorry but in Europe the SAT radio isn't available so no XM support in this skin.
07-07-2006, 11:57 AM
#37
Alex
Ho incluso i sorgenti in PSD esattamente per questo motivo, chiunque voglia personalizzare la skin (cambio del logo incluso) è libero di farlo.
I've included the PSD sources exactly for this reason, anyone that wants to customize the skin (including the change of the logo) is free to make it.
07-09-2006, 10:07 AM
#38
Unfortunately,it didn't work Robby.
07-09-2006, 10:08 AM
#39
I also wanted to ask you if there is anything special i need to add to get the SMSRECEIVED icon to work?
But i'm guessing its phone support based.
07-09-2006, 11:01 AM
#40
In fact it does work but if you have no missed calls you can't tell.
How does Phoco get its calls info?,is there anyway to get RR or Phoco to store the last 20 MISSED,20 RECIEVED and so on.
At the moment it seems either RR or Phoco dumps the info between restarts,it would be nice to if you could stop that from happening.
There is another thing bugging me and its that you can only display the contacts number in ContactDetails.skin,
Is there any way you could change that? I'd like to be able to scroll down the contacts list and display each contacts number at the same time (1 name and its number,scroll down to next name and its number and so on)
07-09-2006, 11:20 AM
#41
Terminal flasher
i agree on the contact screen issue. It should switch to a phone number when the name is highlighted.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
07-09-2006, 11:27 AM
#42
Not sure about switching.i was hoping to display the name in 1 box and the number in another but yeah switching would be cool aswell
07-09-2006, 12:15 PM
#43
Raw Wave
Nice!
You got a good OEM look to the buttons too.
Can you share the PSD's so we can change the highlight colours?
07-10-2006, 09:25 AM
#44
Sorry, I have forgotten to tell you that the screens on which is posible to show the calls list can be only "phoco.skin" or "calls.skin".
07-10-2006, 09:27 AM
#45
Nothing special, you can place the "SMS_ARRIVED_PHOCO" indicator on whichever screen.
| Thread Tools |
| Display Modes |
Linear Mode
