Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 07-10-2006, 09:48 AM   #46
Robby BMW's Avatar
Robby BMW is on a distinguished road
Quote: Originally Posted by Griff1
In fact it does work but if you have no missed calls you can't tell.
How does Phoco get its calls info?,is there anyway to get RR or Phoco to store the last 20 MISSED,20 RECIEVED and so on.
At the moment it seems either RR or Phoco dumps the info between restarts,it would be nice to if you could stop that from happening.)
RR get all the calls list (missed, recived, sent) from the phone through PhoCo every time it is started and it stores the list in a file.
There are some options in RRconfig, under the phone section, like "Store up to xx numbers in the call lists" and "Phone lists path", that allow to handle this.
There is another thing bugging me and its that you can only display the contacts number in ContactDetails.skin,
Is there any way you could change that? I'd like to be able to scroll down the contacts list and display each contacts number at the same time (1 name and its number,scroll down to next name and its number and so on)
Sure, you can add these five labels in your "contacts.skin":
"NUMBER_MOBIL_PHOCO"
"NUMBER_HOME_PHOCO"
"NUMBER_WORK_PHOCO"
"NUMBER_FAX_PHOCO"
"NUMBER_OTHER_PHOCO"
so, when you scroll up and down your contacts list, all the contact's numbers will be shown.
Robby BMW is offline   Reply With Quote
Old 07-10-2006, 09:50 AM   #47
Robby BMW's Avatar
Quote: Originally Posted by ShawJohn
Nice!
You got a good OEM look to the buttons too.
Can you share the PSD's so we can change the highlight colours?
Look at the 1# post... there is a link to the PSD sources too.
Old 07-10-2006, 10:49 AM   #48
Griff1's Avatar
Griff1 is on a distinguished road
Thanks for the Info Robby,its a big help mate.
Griff1 is offline   Reply With Quote
Old 07-12-2006, 11:07 AM   #49
Custommx3's Avatar
Custommx3
On the capture skin. Does this embed? Mine doesnt seem to...
For those needing XM...
I created a new Skin file that allows me to choose radio or XM , much like the popup for choosing a GPS program, and linked it to the radio button the the menu skin. I copied the XM files and a renamed slider folder from the original brushed metal skin to this skins directory, and changed the slider link the Xm skin. I use the new radio pop-up skin and linked them to the radio skin and the XM skin. Worked like a champ. Keep in mind im @ work so no XM is connected to this machine.
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Old 07-12-2006, 12:17 PM   #50
Robby BMW's Avatar
Edit the "ExecTBL.ini" file in the skin directory (not the one in rr directory) and check if you need to change something on the line
"CAMERA","LOAD;CAPTURE.skin;;C:\Programs file\Capture!\Capture!.exe;Capture!"
in order to get it embedded, then edit the file "config.ini" in the Capture! instalation directory and set the option "WindowStateOnLoad" to "CES" and the option "HideButtons" to "1".
Remember! don't change the default key shortcut in Capture! configuration.
Let me know...
Old 07-13-2006, 10:20 AM   #51
Custommx3's Avatar
Custommx3
Worked! Thanks man.
2007 Mazdaspeed 6
Old 07-18-2006, 07:10 AM   #52
ShadOLurk is an unknown quantity at this point
GPS Com port question
Is the ComPort for the built-in compass configrable ? Or does it just use the one in RR.ini? I ask because the compass doesn't work when i use iGuidance in the background. I know that they both can't use the same port at the same time, but i have 3 virtual Com outputs.
Com10 = iGuidance
Com11 = NetStumbler
Com12 = *spare* < want to use this for the built-in skin compass.
Shad.
ShadOLurk is offline   Reply With Quote
Old 07-18-2006, 08:13 AM   #53
Ok... I've just discovered the answer... the RR.ini com setting is for RR only & doesn't influence the port iGuid uses.
Old 07-18-2006, 10:42 AM   #54
Robby BMW's Avatar
Old 07-18-2006, 11:42 AM   #55
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
Robby, I like this skin! Is it possible to replace the BMW logo with the logo of our choice (ie. Ford)?
Thanks!
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 07-19-2006, 12:56 PM   #56
CBDZ is on a distinguished road
I can't seem to get to the playlist menu for creating and selecting which playlist to play.
CBDZ is offline   Reply With Quote
Old 07-21-2006, 11:26 AM   #57
Raw Wave
tbird2340's Avatar
Hey Robby.. Do visualizations work in this skin? I think it's starting the vis but putting it behind the program..
Old 07-21-2006, 11:37 PM   #58
Ti-ejtsch is on a distinguished road
Hello,
how could I set the confirm.skin to a position I want? In your skin the position is in the middle of the screen. I want to have the confirm.skin at:
x=225
y=205
Ti-ejtsch
Ti-ejtsch is offline   Reply With Quote
Old 07-23-2006, 09:07 AM   #59
Robby BMW's Avatar
Thanks!
Sure. You can download the PDS sources files and modify all you desire.
Old 07-23-2006, 09:13 AM   #60
Robby BMW's Avatar
There is a button in the audio player skin for opening the audio browser, please double check.
Kuo Skin Release kuo RR Skins 284 12-04-2008 03:46 PM
(AUS) BMW E36 Extensive Customisation CAA Show off your project 34 06-13-2008 04:44 PM
mac style skin release... btbe RR Skins 42 08-14-2007 10:07 AM
1992 BMW 318IS (E36) Carputer Digital318is Show off your project 7 03-09-2007 08:42 PM
New Skin - Spaced_Out for FrodoPlayer 1.08 WeeZyFellA FrodoPlayer 24 10-17-2004 10:50 PM
