Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 10-30-2007, 07:25 PM   #1486
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
not all skins have the video preview feature, which runs 2 instance of mpc. if you dont care about the preview thing, just edit the skin to use the video browser without the preview.
did you delete the buttons from rr.ini?
EL CAMINO is offline   Reply With Quote
Old 10-30-2007, 07:49 PM   #1487
GTO
GTO's Avatar
GTO is an unknown quantity at this point
Quote: Originally Posted by liquid_smoke View Post
try setting your setting for your radio in rr.ini by hand, if RRConfig is putting both values in the settings this is likely the issue u are having. If you still have the old RRConfig , use that.
Thanks for the reply LS but no luck. My RR.ini always shows radiomode=7 so no need to change that.
My workround is to load the standard RR skin and set the Silabs up in that, then switch back to 3.0
GTO is offline   Reply With Quote
Old 10-30-2007, 08:28 PM   #1488
d0tech is on a distinguished road
Can someone guide me as to how do I go about setting traffic for my area? I keep getting traffic feeds for Chicago
d0tech is offline   Reply With Quote
Old 10-30-2007, 09:05 PM   #1489
greatwhite's Avatar
greatwhite is an unknown quantity at this point
Did both, no joy.
Getting frustrated...............
Time to put it down again for awhile I think.
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 10-30-2007, 10:24 PM   #1490
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
Quote: Originally Posted by kbreeden View Post
I didn't look for any instructions once LS told me where the commands are. I just opened exectbl.ini in the skin folder, found a button on the menu screen that I wouldn't be using, in this case "Sirius," and changed the command from Sirius to:
"LOAD;businav_full.skin;Businav;C:\Program Files\Road Runner\BusiNav\businav.exe;Busi Nav"
Now the plugin loads whenever I hit the Sirius button. The only problem is that the button still says Sirius, which I don't think can be changed. As long as I have the functionality I can live with the mislabeled button.
you can also change the name of the text, look for a really long line of code that goes something like this
AUDIO>>VIDEO>>.NET>>NAVI>>
find where it says SIRUS and change it
there is also another section that has names in it too for the name of the buttons you see when you choose the command from the command screen (click hold).
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 10-30-2007, 10:25 PM   #1491
SMKFree
do you have gps enabled? The traffic i believe (have to double check) gets your location from your GPS
mp3car live search
Old 10-30-2007, 10:28 PM   #1492
SMKFree
Quote: Originally Posted by greatwhite View Post
I opened mpc from the rr root directory, dragged the videos.m3u into it and the movie started to play.
Seems it will play just fine everywhere except when imbedded in 3.0, even when embedded in other skins.
I'm pretty sure it's not rr and something is messed up in 3.0 itself, just have to find it.............no small task considering how big 3.0 is.
I'm pulling down the newest mpc and codec pack now. Might as well give it a try.
LS, any ideas?
Cheers
not really sure what the issue your having is (video related) i have to dig through some of these threads.
But one thing to note, because of the new video preview feature, you should set RR to use the internal player in rrconfig.
mp3car live search
Old 10-30-2007, 10:29 PM   #1493
SMKFree
@LS did you see my post about the DriveLetters script?
no
mp3car live search
Old 10-30-2007, 10:30 PM   #1494
greatwhite's Avatar
new info on my video issue.
The steps:
OPen video with skin button, no mpc visable in the taskbar, no video, screen flashes back and forth between fs and controls, select file browser, select preview video, mpc opens in the taskbar, video plays in preveiw window.
Go back to main screen, mpc closes in the taskbar, no video, no mpc in the task bar. It appeared winamp tried to open on one occasion but hasn't repeat this behavior.
LS, which files in the skin should I look at to see if there is something wrong with the mpc start path? It has to be in the skn somewhere, mpc works wthout a hitch in other skins and in stand alone mode...........
I have config set to internal player also.
Actually, it seems like MPC is not opening when the main screen comes up. It opens in the task bar when preview is selected, closes when stop preveiw is selected. when I go back to the main screen, mpc doesn't open in the task bar then either. Is it possible I'm missing a bit of code (or crrupt download maybe) to open mpc on video start?
The more I think about it, and the more I watch it do it's thing, the more I'm beginning to think that 3.0 is just not opening mpc in the main video window. I just don't know what code to check........
Oh well, time to put it all aside, bedy-bye time (long past it actually)
Cheers
Leonardo Da Vinci
Old 10-30-2007, 10:45 PM   #1495
SMKFree
i found some bug's, fixed them up, now i have no lock up's no more.
1.- the big issue for this is the Driveletters.exe script i compiled a new script and is all good.
2.- the video browser has the old video_preview script. which has some big nasty bug's
i have a new script which works flawlessly in my skin. i made a script specially for the Void skin. and is been working nicely in my test's.
3.- i think we need a "browser", and "back" buttons in the setmediapath_1, 2, 3, etc. skins, i tried to use those skins and when trying to select a folder that has audio files those files go to the audio player, and the skin exits the browser. (when double clicking in folder). i set my paths manually and works fine.
4.- in the setmedia_3.skin(videopath) the "APPLY" button is missing.
dont get me wrong LS, i just want this skin to be what most of us believe,perfect as is meant to be.
hope this helps the people with lock up's
been waiting for this release for a long time, LS great work man.Thanks Again.
1. what was ur issue with this? One thing i do know is you cant have any non standard objects in your MyComputer folder, most users will not, but i had an issue a very long time ago when i had a program installed that let me put shortcuts to files and other directories in the MyComputer list.
2. i havnt checked the thread for that plugin in a while, so ill check it out again and see whats new. The version included in the skin has been edited though.
3. Turn on "Show ...." in RRConfig, its pretty much a requirement as there are other areas that do not have a back button (most do) due to space. Also, when selecting a path, you want to select the root folder you want to use as a path, not go into the directory as then you will be selecting the contents of that directory as the path and not the directory itself.
4. Not for me, looking at the skin in the editor now and there definitely is a button there. Unless your talking about some other screen. The only screen i have that is close to what you typed is SETMEDIAPATH_3.skin (there is no setmedia_3.skin) so i assume u mean this screen.
also, ( i think it was you that posted this) i dont see any issues with the new skineditor screwing up the skin if you edit it with it with popup screens etc. I used the new editor heavily and its been working fine for me.
mp3car live search
Old 10-30-2007, 11:32 PM   #1496
EL CAMINO's Avatar
the driveletters script sets "DISK1" to the first drive that is found, in my laptop i have a floppy drive, which is A:, so when i try to set the paths using the skin, i had the lock up issue, there was no floppy disk present, so i modded the script to set DISK1 to the main drive. that fixed the issue.
i build a video preview script just for the void based in my new script, and is been working good so far. i haven't uploaded the new version, which is way different than the original, and works like a charm in my skin.
all the other things are my bad. sorry.!!
Old 10-31-2007, 12:38 AM   #1497
SMKFree
wow, i havent seen a floppy drive in a long time
you can prob get pass that issue by using tweakui (for windows) and set the floppy drive to not show up in my computer. Ill prob add some more error checking to ignore floppy drives.
id like to take a look at your new version of the video preview.
mp3car live search
Old 10-31-2007, 01:00 AM   #1498
hari-bhari can only hope to improve
whenever resuming from standby, the playlist in the audio screen does not show. it does however show what track number i am on, and the total number of tracks in the playlist. on the main screen, the playlist is still there, so i know its not a winamp problem. and if i click library, the iList still works for browsing through my folders, so i know its not an iList problem. if i reload the skin by changing the vis or gps options, for example, then go back to audio, the playlist displays fine. can anyone confirm on this?
hari-bhari is offline   Reply With Quote
Old 10-31-2007, 01:11 AM   #1499
slvrsol's Avatar
slvrsol is an unknown quantity at this point
It is an iList problem.. there's a thread in the main board.
slvrsol is offline   Reply With Quote
Old 10-31-2007, 04:54 AM   #1500
beuz is on a distinguished road
Hello,
Great work as usual LS....worth waiting for.
Just a small problem: I m running a foreign Win xp (French), for some screens, instead of having regular Icon (especially Play, Rewind, Forward), I have either figures (4,8) or ponctuation (, appearing. I tried both Fr and En win xp and no problem in the En version. However, I really got to use my French version cause of major BT issues. Any idea how on to solve that pls?
I was also wondering if there was a comprehensive guide to LSXVOID. So many customizable items and so many posts about it (between the 3 threads)
beuz is offline   Reply With Quote
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
