Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 11-06-2007, 09:27 AM   #1591
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
Quote: Originally Posted by GuMiSZu View Post
Ok i downloaded the 2.02Ver.
I have an Font problem. The winding/webdings font isn't work in RR. I can use these fonts in word,notepad etc. but in RR not.
I found some post about this problem, but i can't find the solution.
could anybody help me?
Others have fixed this by setting there OS to English.
I highly do not recommend downloading and using 2.x if you are a new user to the skin and your waiting for 3.x to comeback online. It will only increase your chance of not being able to install 3.0 correctly as you have to completely remove 2.x before you install 3.x. And as we know, not many actually read the read me files or follow directions properly. Dont become one of those people
oh, where did u download 2.x from?
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 11-06-2007, 10:07 AM   #1592
GuMiSZu's Avatar
GuMiSZu is an unknown quantity at this point
thx
i have an English xp
i downloaded it from andgear's webpage
ok i wait for the new version..
Englishlessness :(
GuMiSZu is offline   Reply With Quote
Old 11-06-2007, 06:25 PM   #1593
greatwhite's Avatar
greatwhite is an unknown quantity at this point
AHHAHAHAHAHAHHAHAHAHA!!!!!!!!!!!!!!!!!!
I finally got it working properly!!!!!!!!!!!!!!!!!!!!!!!
Audio, Video, DVD and all!
I did a clean install from the ground up on the carpc (formated hard disc, xp, drivers, latest rr and then void 3.0) and everything works after the usual config workup. The only thing that is still a littel funny is it will only play a dvd from the drive and not when ripped to a folder on the hard drive. But I can sort that out later and if I can't, I can live with it.
Not sure what fixed it overall, but good ol' windows fresh install is all I can figure.
Still not workng on my laptop where I do the developement stuff, but who cares? It works on the carpc. That's all that matters..........
Now I can finally get on with installing the hardware into the car properly.
*Sigh*
Relief. Now I can finally go to bed and sleep. It's only been a week!
<falls face down>
(thanks for putting up with the crap 'till I got it sorted LS)
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 11-08-2007, 01:03 AM   #1594
SMKFree
Quote: Originally Posted by sviyer View Post
HI LS, I made a copy of LS 3.0 in the skin folder and renamed it as LS 3.0 Day.
and i chose a white background for the day version.
Now I have both day and night version of your skin. :-)
Thanks again for the the wonderfull skin.
this was something i tested doing but ultimately couldnt decide if that was good enough as shortly after my carputer died and its still mia. If you want i can post a txt file that you can copy to the skin folder you are using for daytime that will change all the font colors to have better contrast. Actually ill just post it here.
Just copy the attached file into the skin folder.
This file is not to be used with the night version.
mp3car live search
Old 11-08-2007, 01:27 AM   #1595
hari-bhari can only hope to improve
so just use a light/white background and that font colors skin and all should be fine? would it be ok to just make a second lsx folder called lsx_day and copy paste the whole skin into their, copy the new color text file, and then just point to a different background?
hari-bhari is offline   Reply With Quote
Old 11-08-2007, 01:42 AM   #1596
ok after much more subsequent testing, reinstalling dx, and updating all my video drivers, and upgrading to RR 11-2, I am pleased to announce that 1) the previous issues of the ilist not appearing after resume has been solved, 2) the issue with the ilist not reappearing after the album art automatically shows up is solved 3) the issue with the visu not appearing until clicking on the main screen after switching to another screen and back has been mostly solved (it seems to be fine after going through a couple on/off cycles, although the very first time i goto to the audio screen and back, it mimicks the on/off setting from the main screen rather than remembering its own), and 4) unfortunately, the issue with google earth screwing up is not resolved but i have been able to shed some new light on it that may help in diagnosing.
i have noticed that when using the GE plugin, everything functions fine as long as i only go to screens that i have previously visited. for example, if i have also loaded up the audio library screens, and then load up the GE plugin, i can navigate to those screens without any problem and revisit the GE screen whenever i want. however, as soon as i visit a screen that i had not loaded previous to starting GE, i get this weird issue.
the best way i can explain it is that it seems that GE is getting confused somehow and several screens popup simultaneously. as soon as i switch to a previously unvisited screen in RR, the GE window pops into the main view, the sidebar shows up, and several toolboxes appear layered on top of one another, however they all only appear with a gray background and no material inside (text or buttons). rr then takes main focus back and the GE window becomes hidden after 2-3 seconds. if i click the GE button in RR, the GE window is no longer embedded in the frame.
if i exit RR, it can be seen that GE is still running. the foremost window has to do with gps settings, which gives me an error box stating that 'this feature is only available in GE plus'. when i hit ok, there are still several toolboxes behind such as ruler, but i can click the file menu and hit exit to quit GE completely. through all of this, the window has no title bar (as if it is embedded) and the main screen shows no imagery. in fact, none of the toolboxes or the sidebar show any buttons or text, just gray backgrounds. so my guess is that this either has to do with a gps port issue (maybe switching to a new screen steals the port temporarily, how does RRearth manage the port? i have xport running, but i dont think i ever specified one for RRearth to use), OR this could be a dx issue.
maybe guino has some ideas about this? i would just embed GE myself and run goops in the background for mapping, but the GE window won't embed (presumably because the splash screen appears then disappears so RR loses it). whew, sorry for the long post, but i hope it makes sense!
p.s. on another note, can you post the exe for the little iguidance menubar that you used in 2.0. i actually need the zoom + and - buttons that were included in there rather than the left and right arrows in this new release (not sure what they do), because i got rid of my zoom buttons with reshack
Old 11-08-2007, 02:55 PM   #1597
beuz is on a distinguished road
Hello,
I am having some issue with the audio player.
When I open the audio button, the list is like this:
-Albums-
-Artists-
-Genre-
Albums1
Albums2
This list of albums takes IDtags differently than in the -Album- view above..don t know why
1. One of the genre has more than 300 songs in it and when I click Append Selected, I got a RR error message and RR closes:
Details:
Error: Appname: RR.exe ModName: ntdll.dll; Offset: 0006112b; modver 5.1.2600.1217
Doesn t seem to do it on Genre with less songs in it.
2. When I Browse DIR \/ -Albums-, select an album and click Append Selected, it doesn t add in the playlist. However,
If i click on the same button, but from the first screen I described above, it does append the album in the playlist?
Thx
beuz is offline   Reply With Quote
Old 11-08-2007, 03:32 PM   #1598
HJC
HJC is an unknown quantity at this point
I'm using 2.02 right now and it's pretty much perfect. I would like to get 3.0 to work on my carPC however cuz I love the iList feature along with other improvements.
If I just rename my C:\Program Files\Road Runner directory to soemthing else and in the mean time reinstall RR, does anyone see any problems if I just rename it back after testing and things dont work out?
HJC is offline   Reply With Quote
Old 11-09-2007, 06:04 AM   #1599
Iceman_jkh is on a distinguished road
Just bumping that fact that I really really want the download turned back on
Iceman_jkh is offline   Reply With Quote
Old 11-09-2007, 11:25 AM   #1600
greatwhite's Avatar
read the release notes on the first page.
Previous versions of void must be removed.
Just save your ini files when you remove void if you want to go back to 2.02, but i don't think you will want to after trying 3.0......
Leonardo Da Vinci
Old 11-09-2007, 12:12 PM   #1601
kyds3k is an unknown quantity at this point
hear ye, hear ye! i don't even have my carPC put together yet and i wanna try this . . . i'm just running RR on my desktop!!!
kyds3k is offline   Reply With Quote
Old 11-09-2007, 12:36 PM   #1602
ok, i tried changing the background and got the greyed-out problem . . . and i did add the lines to the rr.ini as the installer told me to. what gives?
Old 11-09-2007, 09:55 PM   #1603
SMKFree
yes, that would be fine.
ill look around and see if i have that file, but i do belive it is still included in 3.0. By default the skin is set to you IG3/4 and the menu bar you speak of actually has about 6-8 different versions of that bar that will run depending on what version of IG you have the "NAVI" button set to. Since the default "NAVI" button will probably still load IG2 and embed it correctly, its using the IG3/4 version of the menu bar.
Click and hold the "NAVI" button until the command list pops up, click MORE then choose IG2. You should now have the old menu bar used before.
as for the GE issue, this is a known issue, and i believe it is an issue with either RR or the RREarth plugin. I dont think any work has been done to the code for the plugin in a long time, so I think there are some compatibility issues with RREarth and later versions of Google Earth. Ill bring this issue up to guino and let him know. As for the gps port, RREarth gets your loaction sent from Road Runner, so all you have to setup for it to work is for RR to have a port set in rr.ini
Quote: Originally Posted by beuz View Post
Hello,
-Albums-
-Artists-
-Genre-
Albums1
Albums2
Details:
Thx
This is an issue with RoadRunner, nothing i can do about it nor any setting i can tell you to set that will fix it. Ill bring it to guino's attention.
Thats fine, you shouldn't have any problems.
What is the greyed out problem?
You should NOT add anything to rr.ini. You should REMOVE any settings from rr.ini that are related to any previous version of the skin. This is stated on the first post, the installer and a few other places.
OTHER NEWS:
just got a root canal done this morning, so im back to normal, no pain, whohoo!
The download for the skin should be back online shortly. Most if not all of the issues have been resolved. The only real issues that are open that people havnt been able to resolve by changing a setting or fixing something with RR or the OS are:
ratings plugin path issues: fixed (plugin rewritten)
video issues ( not skin related, should be fixed in latest RR, for good measure the preview video feature has been temp removed)
driveletters.exe (there was an issue with this if you had a floppy drive installed on your machine: fixed)
History mode in the audio player (disabled temp, i dont think there are any issues here, but i want to step through the code one more time just to make sure. Some people reported it not working as they expect. The option will be re-enabled in a future update). Preset mode will still be enabled. If you are not having any issues with the History mode and you still want to use it after the update, it can be manually re-enabled in skin.ini. Ill post the line to edit when the skin is re-released.
That should be all the issues that i know of. If anyone has any other issues that I am missing, that is not a bug in Road Runner please post them so i dont miss to fix them before the download becomes active again.
Also, there are a few small new features, or enhancements to existing features that will be in the update.
Under .NET, the maps button is crap, this will be resolved. There is a preview image of Gmaps below. Over the next few weeks a lot of attention will put in this area. In the long term (not sure how long) there will be a version of Gmaps that is built from the ground up specifically for 7in touch screens, and it will track your location by default
Some other minor things, but i cant think of them right now.
more later.
mp3car live search
Old 11-09-2007, 10:04 PM   #1604
Got my new Carpc running today.
Perfect timing if you re-release Void3.0 today !!
(Glad to hear you are back with us - and not in pain!)
Old 11-09-2007, 10:05 PM   #1605
SMKFree
it wont be today. Sunday's are the only day anything will ever be released.
mp3car live search
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
