11-12-2007, 04:36 PM
#1636
Quote: Originally Posted by kyds3k
disabled while people are working the kinks out. believe me, i check it every day too!
might as well only check on Sunday's because it won't be posted any other day.
11-12-2007, 09:33 PM
#1637
I see dead kittens
LS can you edit your first post stating the file is not available temporarily. This way every other post is not asking about the dl link.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
11-12-2007, 10:50 PM
#1638
Confusion Master
maybe johnwpb could do it for him
11-13-2007, 01:03 AM
#1639
SMKFree
Quote: Originally Posted by hari-bhari
Actually I prefer the main window not to have an ilist because the ilist causes the visualization to run a lot choppier in the audio screen (at least I assume its because of the ilist), so i usually leave mine in my main screen where the visualization runs way smoother. If you are intending on making the main screen have ilists, is there going to be an option for this, or will it be automatic? Just a thought...
For the same reason as above, I like each window to remember its on/off status. Right now, I have it working that way (I think its only working because of a bug), but I
1) turn my vis on in the main window
2) go to audio where it's now on and turn it off
3) go back to the main screen where it is now off and turn it back on.
This basically enables the vis to stay active on the main screen and not in the audio window where it runs very choppy and obscured my ilist. On ocassion when I switch back to the main screen the vis doesn't show up until I touch the screen, but in about 90% of the cases it does show back up.
In regards to the top of the first line in the playlist being cutoff on the main screen, I am having that issue as well. I just thought it was intended...but I guess that wouldn't make a whole lot of sense.
In regards to the video issue mentioned earlier where the playlist is not updating with the newly selected files, I did check my RR version and it is 11-2. I will try fully uninstalling and reinstalling the skin now that my path is set up correctly, and I am assuming it access the new files just fine. I'll update when I test it out.
*New Question*: Sometimes when I open up the navi screen and then close it, and switch to several different screens in between, the navigation screen seems to have been closed out. So when I click navi again, it loads up the screen from scratch as well as iguidance. Normally this is no problem, except when navigating where it could be a problem if you were waiting on the next turn and didn't know iguidance had shut down. Is there any way to make sure the navi screen and iguidance remain loaded? Maybe it's something I overlooked, but I would assume that once navi is started up, it should remain active in the background.
Other than the above issues with the video and navi screens, the skin is working great. I went on a long roadtrip this weekend, about 10 hours total, and had no lockups or freezes. On occasion RR crashed when I tried to load an entire genre, so I went through each of the albums in there and noticed one of them is having trouble being read (no track list in RR), so I'll look into that. I also had difficulty clicking items in the ilist and oftentimes I had to click 2-3 times on an item before it was selected, but I will post that issue in the RR release thread. Thanks again!
ilist on main menu:
actually, it already IS an option, 14 options. There are a few main menu that dont have the playlist. There will be a new main menu option to replace the last 2 that are in the list that are duplicates, so i guess one of them can be a version with a standard list. All the other list are already converted to ilist.
The top of the list being cut off is a bug in RR, not really anything i can do about it.
But this doesn't happen with the ilist, so really wont be an issue in the future except for the one standard list mentioned above.
Navi:
When you load navi and it loads IG. If you close the screen and immediately go back, does it relaunch IG? Or only after you go to several different screens? Have you tried to increase the number of screens RR will hold in memory, in rr.ini (screenlimit=12). Also, what version of IG?
11-13-2007, 01:06 AM
#1640
SMKFree
For some reason i though i did that already, but i guess i didnt. Lotta things going on at the moment. Ill edit it now while im thinking about it.
why would i need that?
11-13-2007, 02:16 AM
#1641
Quote: Originally Posted by liquid_smoke
ilist on main menu:
Navi:
If I visit the screen and immediately go back, it does not relaunch. It only seems to do so after a while and after I've visited several other screens. I'll try the screenlimit thing but there is no way I visit more than 12 (I only use main, audio, library, mixer eq, and mixer volume). It could be a bug with ignative, I found a post in the bugs section so I'll read more in depth and get back to you. Also regarding the video issue, I think guino confirmed it was a bug in 11-2, so I'll update to 11-4 and report back.
EDIT: Also noticed that when switching to the navi screen I get a little flicker where a white background shows up before iguidance redisplays. Is this just the way iguidance embeds into RR? I have ignative set to true, and I read that i am supposed to edit out some clip area, but I don't know if your skin does it automatically.
11-13-2007, 05:18 PM
#1642
where i can download it?
11-13-2007, 05:30 PM
#1643
Check the first post.
Car PC Progress
(>>>>>>>>>>>>---) 90%
"Don't speak about it, be about it"
11-13-2007, 05:44 PM
#1644
ilist on main menu:
LS,
I'm not sure I follow. I tried all vis/menu options and none of them had the ilist on the main menu.
I also was checking out the different directories in your skin folder...do you have coverflow installed in 3.0? If so, where is it at? I checked BBAA no such luck.
Thanks in advance,
Griz
Jeeputer Project
- Design <<< 100% >>>
- Construction <<< 99.5% >>>
11-13-2007, 05:51 PM
#1645
in the first post...the link doesn't work
11-13-2007, 06:21 PM
#1646
Alright then, let me expand on Carlos's response:
READ the first post.
Cheers
Leonardo Da Vinci
11-13-2007, 07:32 PM
#1647
The video issue is resolved by updating to 11-4 - files are loading properly using the built in player.
The lockup with pressing the 'fn' button on the radio is resolved by downloading the patch.
I am having the same issue as GTO with my silabs radio selection being switched back, so I'll manually edit the rr.ini and see if that helps. I don't know if this is related, but my presets for radio stations disappear once I close RR. Also the 'scan' function doesn't work, it just stays stuck on 87.5. I have tried it with 'enable all frequencies' both enabled and disabled in rrconfig.
Also noticed that in Xplorrer, browsing C and D worked for me, but E and F do not load anythingt even though I do have a E (CD) and F (jumpdrive) drive. Is this plugin fully functional yet, or is there some path lists that need to be set. I also tried the copy and paste buttons, didn't really do anything. I assume the copy2music and copy2video,etc. fucntions work off the rr.ini paths.
Thats all for now, thank you as always and keep up the good work!
#1648
Confusion Master
Because you can't be trusted to do it in such away to prevent the following
Cheers
11-14-2007, 12:46 AM
#1649
SMKFree
Quote: Originally Posted by TxAxZxZ
LS,
Thanks in advance,
Griz
when i say already converted i mean on my end, when the download is active again the new version will have all the list for the main menu's (that have list) to ilist except for one.
no cover flow is not installed in the skin, i was hoping that it would become useable at some point but its just far to slow. The files are in place incase one day its actually useable i can easily enable it.
dont waste your time with it though, its horribly slow even on fast machines.
11-14-2007, 12:59 AM
#1650
SMKFree
not sure about the radio issue, i dont have the hardware to test it. Can you try to do the same thing with a different skin and let me know if any of the same problems exist.
If the CD drive is empty it wont load anything. F should work though.
Check skin.ini and you'll see where the drive letters get saved. They get updated everytime you load RR and everytime you browse to the file browser so manually editing them wont do much. If the drive is active and has files, it should show up. There is an updated version of the tool that scans for your drives in the update, but it mostly just fixes an issue that only happens if you have a floppy drive connected to your system.
If the drive letter is showing up in RR, then the tool properly scanned your drive and can see it fine. So that makes me think there is an issue somewhere else. Not sure where since you are able to browse C and D fine.
Copy2 X works by copying the selected item in the list to your music/video/pics paths set in rr.ini. Copy and Paste works similar but u can choose where to paste to. There is some status text, its kind of small. If you can test it more and let me know what happens or dosnt happen.
| Thread Tools |
| Display Modes |
Linear Mode
