Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 12-03-2007, 04:05 AM   #1711
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
Links Posted: Same Requirements As Before.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 12-03-2007, 05:12 AM   #1712
MrTrunks's Avatar
MrTrunks is an unknown quantity at this point
Found small bug in the Notes. If you are using Notes in Draw mode and you close the Notes then go back into it, the text up top shows "Show Text". When you click it, it then displays "Show Draw". When you click it again, it finally goes into draw mode.
I also noticed if the song ends during Notes, when you close Notes, it will start the song off where it was before entering Notes.
This make sense?
Overall, looks great Will install in my truck tomorrow.
Thanks for you hard work!
Edit: song picks up where left off with when returning from a different screen when song is over and repeat is turned off.
MrTrunks is offline   Reply With Quote
Old 12-03-2007, 07:33 AM   #1713
krustywon is an unknown quantity at this point
So much for "I'm tired and I'll post it tomorrow"...lol...thanks a lot, L.S., for ALL the work you (and semingly everyone else on this board) put in for the community. Hope you're having a good sleep. Can't wait to give this a try.
krustywon is offline   Reply With Quote
Old 12-03-2007, 10:44 AM   #1714
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
[picky]Title on web page says LSX VOID 2.0[/picky]
Enforcer is offline   Reply With Quote
Old 12-03-2007, 10:57 AM   #1715
GiODi will become famous soon enough
That's hilarious... i was about to say the same thing!
GiODi is offline   Reply With Quote
Old 12-03-2007, 11:34 AM   #1716
Asskick is on a distinguished road
Thanks.. ill try it out today and give my feedback on how it went
My current project
Jetta 2000 MKIV
SP13000/Xenarc 7"
100GB / 512 RAM / GPS / Wi-Fi
Asskick is offline   Reply With Quote
Old 12-03-2007, 11:59 AM   #1717
shouryuken's Avatar
shouryuken is an unknown quantity at this point
LSX 3.2 problems :(
Firstly need to say GREAT x10000 on the skin.
Im been using an old version for ages, but recently cleared my HD and did a fresh install.
And ive been waiting and Refreshing the Download page for 3.2 for at least a week
I just installed it........ I LOVE IT!!!!!!!!!!!!!!!!! ...... RR would be NOTHING without it! (j/k)
But theres a few problems i have....
(Ive Searched everywhere and know a fair bit but cant fix it)
My Main Problem is a black box around the tracks in the Main Menu screen:
I updated Flash and did as much as i could but still cant fix it.....
Also When i do random things such as looking through my pictures, sometimes try add a album to the 1-5 playlist and browse through the option menu, RR will stall and i get this error when i reload RR:
"Error: 438, Object doesn't support this property or method"
I then have to reinstall LSXVOID_3.0 to correct this/load RR again
Btw, i have no other problems with any other skin or older versions (did a fresh install) and have newest version of RR
(If this is not the place to post errors can someone direct me to where)
I love your work and hate to be posting these errors
shouryuken is offline   Reply With Quote
Old 12-03-2007, 12:46 PM   #1718
hari-bhari can only hope to improve
i think part of these errors are having to do with the new implementation of ilists in rr, which uses directx. ive been reading around a bit and there are some dx errors. i am thinking your issue with the black box around the list is probably related too, but its purely a guess. do you get the black box on the audio screen as well? also try to select a main menu config that does not use ilists (ls said there should be one) and see what happens. ive been using 3.0 and have not had this issue, but the main menu lists were not ilists. did you try and other skins with ilists to see what happens?
also, i would personally stick with xp instead of vista...i dont know the opinion of everyone else, but rr works great with xp so i see no reason to upgrade (if you can even call it that) to vista.
hari-bhari is offline   Reply With Quote
Old 12-03-2007, 04:52 PM   #1719
Thanks for the kickass release
Im having an issue that cant play videos.. i did a clean install of latest RR, then the skin.. i tried using the internal player, and without selected (having the mplayerc.exe in the rr folder, and being specified on the rr.ini). If i try to play a video outside RR it plays fine (so i can discard codec probs). Any other thing i might be missing???
Other than that.. i just had 1 error while clicking on the 'next folder' on the playlist.. clicked ok.. after that.. no other errors showed so far on my carpc (still didnt cliked thru all the options)
My current project
Jetta 2000 MKIV
SP13000/Xenarc 7"
Old 12-03-2007, 05:12 PM   #1720
damn, i just got this error too. and i never got it with the 3.0 release. time to start digging.
Old 12-03-2007, 05:20 PM   #1721
BReMFoX's Avatar
BReMFoX is an unknown quantity at this point
Same here.
Also the Error 438.
Found something, maybe is has to do something with it?
Quote:
Run-time Error 438
Background
Program generates a "Run-time Error 438" error message.
Cause
A file is not registered.
Solution
Manually register the file.
BTW, really nice Skin!
Had it working for a while untill this error appeared.....
| Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
BReMFoX is offline   Reply With Quote
Old 12-03-2007, 05:21 PM   #1722
im sure ls will know, i guess we'll just sit tight til then.
Old 12-03-2007, 05:26 PM   #1723
Has anyone else had trouble with the color picker? RR just hangs on me when I selct it.
Old 12-03-2007, 05:39 PM   #1724
taylorgauss's Avatar
taylorgauss is an unknown quantity at this point
Me too.
taylorgauss is offline   Reply With Quote
Old 12-03-2007, 05:50 PM   #1725
greatwhite's Avatar
greatwhite is an unknown quantity at this point
Nope, working fine here.
Nice work overall LS!
Still playing with it, no issues yet............
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
