Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 12-04-2007, 02:07 AM   #1741
bobbykokinos is on a distinguished road
I havent encountered an Error 438.. But, I did get a "Run-time error: 13 Type Mismatch" and it locked my computer up..
This is on a fresh install of latest version of RR..
bobbykokinos is offline   Reply With Quote
Old 12-04-2007, 02:27 AM   #1742
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
humm, well this is very interesting.
I just downloaded the RR Installer, normally i only use the binary releases. Installed RR and now I also get the 438 error. Not really sure what thats all about as i know i have all the dlls, but all i had to do to get the error to show up was use the installer which is very odd.
Where is my shovel.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 12-04-2007, 02:51 AM   #1743
hari-bhari can only hope to improve
yea just to clarify like i did in my previous post, installing 3.0 and then 3.2 did NOT clear up the issue. it just took longer for it to appear afterwards. and i have manually registered the gdipluswrapper dll. i have always used the installer and copied the new binary for 11-4 over, even for 3.0, and it worked fine, and is wokring fine that way on this new machine
hari-bhari is offline   Reply With Quote
Old 12-04-2007, 02:53 AM   #1744
SMKFree
Im pretty sure you have an old version of RR installed.
While trying to repro the 438 error, i downloaded the RRInstaller, also thinking it should be the latest version. Installed it and all hell broke loose. After a bit of proding, i checked and sure enough, the Installer is an OLD version of RR, 9/20 when it should be 11/04.
Now for the 436 issue which i think is somehow related to the RR installer also.
mp3car live search
Old 12-04-2007, 04:20 AM   #1745
SMKFree
well i think ive kind of narrowed it down, or at least i can generate and fix the error at will. Still not sure exactly what is causesing it, but to fix the 436 error.
copy the menu.skin file from inside this folder under the skins folders root ALT\NO ART NO LOGO bv\menu.skin
and overwrite the one in the root of the skin
I think there may be an issue with the ilist on the main menu, which is odd cuz before ran the RRInstaller they worked fine, then poof the skin wouldnt even load.
Its super later now, so ill be looking at this issue again tomorrow. Whatever fix that comes down the pipe im pretty sure you will not have to download the skin again.
Let me know if the above work around fixes anything.
Other things i did in between finding the above fix was re-register every dll used by RR by hand, multiple times and mutiple reboots. I need to test this on a fresh machine to really be sure of what i think the problem is.
mp3car live search
Old 12-04-2007, 04:43 AM   #1746
hugenius79's Avatar
hugenius79 is on a distinguished road
the problem is the ilist in menu.skin ...
doing /IL,PL,transparent.bmp,sel.bmp,end.bmp,0,70,50
solved the 438 error....
and by the way i didn't use the RR installer and re register any .dll
hugenius79 is offline   Reply With Quote
Old 12-04-2007, 08:52 AM   #1747
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
as far as i know the rr installer hasnt been updated for the last few releases. Steve hasnt been on much in the last few months.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 12-04-2007, 09:02 AM   #1748
SMKFree
odd that i only started seeing the error when i used the RRInstaller, maybe it was just timing.
But it is the ilist on the main menu.
BUT.... only if they are present when RR first loads which is odd also. There isnt anything wrong with the .skin file. If you go to the menu options, you can click each one and RR will load them all. But if you exit and try to reload with the ilist on the menu screen, RR craps out.
So seems to be a bug with RR.
mp3car live search
Old 12-04-2007, 09:14 AM   #1749
CARLOS_CET's Avatar
CARLOS_CET is on a distinguished road
That's what happened to me this morning. Everything was working fine. I had the default main menu. Than I changed to the BigVisopt1 or something like that and the next time I tried to open RR with the LS skin, I got the 438 error. I changed to the default RR skin for now. So it seems like your on the right path. Good luck! Great skin as always.
Also, one other thing. I clicked on the color picker button and RR locked up on me. Music still kept playing so winamp was fine. Not a big deal but something I noticed. Getting the 438 error fixed is more important right now.
Car PC Progress
(>>>>>>>>>>>>---) 90%
"Don't speak about it, be about it"
CARLOS_CET is offline   Reply With Quote
Old 12-04-2007, 09:18 AM   #1750
CARLOS_CET's Avatar
Quote: Originally Posted by CARLOS_CET View Post
I'm having a problem. I uninstalled RR, LS, winamp and re-installed all of the programs. When I click on the Audio button, RR freezes. Any ideas? Anyone else having this problem?
My debug file said that I had a InitDx error. I was trying this while using logmein to connect to my car PC outside, since it was about 20 degrees out and snowing. Once I got in the car, it seemed to work fine, so I'm not sure if it's related to using logmein. I'll have to test it out. I did install DirectX9c at one point before I hopped in the car but I saw the same problem. Anyway, haven't seen it since I've been driving.
Car PC Progress
Old 12-04-2007, 01:27 PM   #1751
beuz is on a distinguished road
Works, thank LS
beuz is offline   Reply With Quote
Old 12-04-2007, 02:02 PM   #1752
BReMFoX's Avatar
BReMFoX is an unknown quantity at this point
Worked for me!
| Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
BReMFoX is offline   Reply With Quote
Old 12-04-2007, 02:03 PM   #1753
so does that mean we should only stick with that main menu theme for now and not switch to any others, or after we do this the error will clear up and we can then use any other option?
Old 12-04-2007, 02:05 PM   #1754
BReMFoX's Avatar
I Played with other options, but no error so far....
Old 12-04-2007, 03:07 PM   #1755
CARLOS_CET's Avatar
Have you restarted RR? Have you restarted you pc?
Car PC Progress
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
