Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 12-05-2007, 11:49 PM   #1786
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
an updated download will be posted tonight. Fixes a few oversights, like some of the settings were not reset to there defaults, disabling ilist on the main menu screens,fix for seeq screen where it will continue to play audio when u exit, possible colorpicker fix, search button removed from bbaa screen (should not have been there), and a few small tweaks.
and also fix for the fm or hd radio setting option
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 12-06-2007, 01:18 AM   #1787
MrTrunks's Avatar
MrTrunks is an unknown quantity at this point
can someone tell me how to remove a song from the current playlist using lsx3.2?
I can't seem to figure out how to remove individual items only add them or clear entire list.
MrTrunks is offline   Reply With Quote
Old 12-06-2007, 02:48 AM   #1788
hari-bhari can only hope to improve
Quote: Originally Posted by liquid_smoke View Post
when you manually added the drive to skin.ini did you list the drive letter
like this
DISK4=E:\
or like this
DISK4=E
the first one is the correct way.
i have it the first way correctly. it was actually already listed there, i guess the last instance of checkdriveletter or whatever had logged it. but still, nothing happens when i click it. ill let u know when i get a chance to try another drive, but it may be a while.
hari-bhari is offline   Reply With Quote
Old 12-06-2007, 02:51 AM   #1789
SMKFree
You cant.
If you just want to prune a list but not actually delete the song, you cant do this in the skin.
BUT... If you actually want to DELETE the song that is playing then just click and hold the "Delete Track" button.
This button will either immediately delete (GONE FOREVER) the currently playing song or it will send it to the recycle bin.
To configure witch action it will do, edit the file delete.ini found inside of the "deletecurrent" folder.
By default the action=recycle, to delete forever without sending the file to the recycle bin, change it to action=delete
what you want to do isnt a bad idea, so ill look into adding this feature. If i weren't actually in the middle of uploading an updated release, id add it now.
But since its so easy to add, just follow these steps to enable it.
open audio_player.skin in notepad or any other text editor or use rrskineditor.
find this line
B01,715,298,86,62,"",@DELETE_CURRENT@
and replace it with this line
B01,715,298,86,62,"MINUS1",@DELETE_CURRENT@
so now after doing that, when you click the delete track button, it will just remove the item from the playlist and nothing else. Click and hold the same button if you want to physicaly delete the track from your hard drive.
ill prob upload an updated audio_player.skin file with the above changes for those that dont want to dig around in the .skin file.
mp3car live search
Old 12-06-2007, 03:55 AM   #1790
MrTrunks's Avatar
I did what you said and I also changed the text from Delete Track to Remove Track
Thank you for your help with the current workaround
Can you tell me what the Play Selected button does when browsing the Library? When I click it it doesnt do anything except clear my current playlist and winamp continues to play the current song it was playing before.
Old 12-06-2007, 05:01 AM   #1791
beuz is on a distinguished road
Hello All,
Did any1 embeded Wifi Connection labels plugin in the skin? I am having difficulties on there. Did choose an empty button from LSXVOID option and started set up, but this is where I need help.
In the Wifi Connection labels thread, it is said to put a wireless.exe in the skin folder, but once in the setup, when I try to browse for appli, it won t let me browse within LSXVOID 3.0 folder. However I can browse others skins folder.
Thanx
beuz is offline   Reply With Quote
Old 12-06-2007, 05:03 AM   #1792
sorry to erase.
Old 12-06-2007, 08:55 AM   #1793
GiODi will become famous soon enough
I found the problem with the color picker. If you don't have a picture path set in the rr.ini it will hang.
GiODi is offline   Reply With Quote
Old 12-06-2007, 09:06 AM   #1794
CARLOS_CET's Avatar
CARLOS_CET is on a distinguished road
Thanks man. I actually got it working last night. Wasn't sure how but you just answered it. I think that the same thing was happening with the other 2 buttons, themes and the background button. So setting the picture path should fix all 3 of those.
Car PC Progress
(>>>>>>>>>>>>---) 90%
"Don't speak about it, be about it"
CARLOS_CET is offline   Reply With Quote
Old 12-06-2007, 10:02 AM   #1795
I found this kinda by accident... I just added a picture path so I could put a plain white background in; I just tried the color picker and it worked.
LS: Is there supposed to be an emu_skin?
Old 12-07-2007, 01:52 AM   #1796
what exactly do we need to do to get the calendar working? i read something earlier about rainlendar2, but i don't know if that's still valid.
also, i dont really understand the apps button or what it is for. when i click it, i get 5 empty boxes along the top row and an empty list underneath. i know you have the free1-free5 slots for external programs, so is the apps button supposed to pull up everything in that list?
Old 12-07-2007, 10:15 AM   #1797
Rabid_Child is on a distinguished road
Quote: Originally Posted by hari-bhari View Post
did you register your gdipluswrapper dll?
Yes I did. No help there. I see LS has updated the installation file so I guess I can try that. But registering the dll had no effect. I'll try to get a screen capture program so I can post an image of my problem.
Rabid_Child is offline   Reply With Quote
Old 12-07-2007, 10:24 AM   #1798
CARLOS_CET's Avatar
Playlist questions...
Help! I'm playlist illiterate. One huge thing that I would love is to have multiple playlists. Maybe 10 or more. Here are some questions...
How can I create a new playlist?
How many playlists can I make?
How do I add a song to the playlist?
How do I delete a song from the playlist?
Thanks in advance.
Car PC Progress
Old 12-07-2007, 02:19 PM   #1799
BReMFoX's Avatar
BReMFoX is an unknown quantity at this point
Does someone have a mobile phone plugin working with this skin?
Tried to use Freefone, everything works fine, but how can i embed it right?
Now it's opening in a new window.
And how do i autostart this program when this skin starts up?
Also, does anyone got sound from mobile phone to speakers working?
Not sure if it's the right thread to ask??
| Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
BReMFoX is offline   Reply With Quote
Old 12-07-2007, 04:02 PM   #1800
greatwhite's Avatar
greatwhite is an unknown quantity at this point
I just noticed guino has a new rr binary posted on his site. Says it's supposed to fix ilist loading issues with menu.skin
Maybe I'll give it a try and see if the locking up on Ilist vis choices is still there.
Trying now.........
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
