Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 12-20-2007, 01:52 AM   #1981
hari-bhari can only hope to improve
is there currently any way to search for a song by its title? i.e. if the song is named 'good morning', is there any search feature where i can type part of the name and itll bring me a list of songs containing the text. someone pleaaaaaaase enlighten me.
hari-bhari is offline   Reply With Quote
Old 12-20-2007, 02:22 AM   #1982
bobbykokinos is on a distinguished road
Quote: Originally Posted by montgomeryt View Post
For the past day my RR started to crash when loading 3.2. When I look at the report it wants to send to Bill Gates it says Roadrunner.exe crashed on zipcodefinder.dll (I believe that's the correct name). If I disable my XPort the skin loads fine but obviously no GPS. Any one Anyone ?
I have the exact same problem but, I've asked several questions and am having a hard time getting any answers in here.
I did the same thing as you, tough. I turned off the GPS functionality in RR but still have iGuidance running. I don't think XPort has anything to do with it. I think its the option where it shows you what city you are in (which is always usually 20mi off for me for some reason anyway so its pretty useless) on the main screen or it has something to do with the fuel finder. My RR is running but I have no speed or compass in RR because its all disabled.
bobbykokinos is offline   Reply With Quote
Old 12-20-2007, 02:37 AM   #1983
MrTrunks's Avatar
MrTrunks is an unknown quantity at this point
Quote: Originally Posted by liquid_smoke View Post
THANKS!!
not that i know of, i could make a work around for you though, what is ur com port #. But i think the problem may be localdatacapture feature in RR. Do this as a test.
Open ExecTBL.ini and find this line
"LSONSKINSTART","ratecheck2||locate"
make it look like this
"LSONSKINSTART","ratecheck2||"
this will set RR to not automatically try to locate your position from zips.dat until after a minute has passed or whatever value you have set for localdatacapture=# in rr.ini
This feature only affects the city display on the main menu and i believe maybe auto weather update based on zip. So if u completely turn it off its not a biggie and wont screw with other things much.
Let me know what happens
My exectbl was empty besides like 5 lines that didnt look like they did anything anways...I used the exectbl.ini that you posted for the muted preset bug in its place and removed the locate like you said.
I'm using com port 5. I also checked my rr.ini and localdatacapture is set to 0. I am guessing that this means disabled. I'll let you know what happens tomorrow.
Thank LS
EDIT:
I just noticed there is an exectbl.ini in the road runner root folder and also in the lsx skn folder....Which one is being used? Should I delete one of them?
EDIT 2:
I couldn't wait...I went out to my truck and tried what you said. By removing locate from the exectbl.ini, this fixed the problem, I am able to exit and then open RR again and it starts fine whereas before when I exited and tried to start RR it froze at the locate command!
Do you plan on making the locate command on initial start to be an option to be turned on and off in setup? I'm not sure if others had this same problem as me but having a toggle button is much easier and also having it set to off by defaulted lsx install. This all make sense? Thanks LS!
MrTrunks is offline   Reply With Quote
Old 12-20-2007, 03:19 AM   #1984
hugenius79's Avatar
hugenius79 is on a distinguished road
Delete ziplocator.dll inside RR folder...
hugenius79 is offline   Reply With Quote
Old 12-20-2007, 01:02 PM   #1985
brandensin is an unknown quantity at this point
ok.. searching this thread, i think i found a solution to one of my own problems.. Running Korean version xp was the problem... I hope that will fix my other problem too.... only buttons that seem to be working now are side arrow buttons to toggle the different menu view.... None of the buttons are responding to my clicks.
brandensin is offline   Reply With Quote
Old 12-20-2007, 01:12 PM   #1986
montgomeryt is an unknown quantity at this point
But isn't this DLL needed for find location for things like the Gas finder and so on ?
montgomeryt is offline   Reply With Quote
Old 12-20-2007, 05:42 PM   #1987
mnickolson is an unknown quantity at this point
Can someone tell me were the 2 presets are stored to get the band button to work. I have tried and tried and am to the point of just giving up. I got to thinking if I knew were it was stored I could just put them in I think.
mnickolson is offline   Reply With Quote
Old 12-20-2007, 08:20 PM   #1988
greatwhite's Avatar
greatwhite is an unknown quantity at this point
http://www.mp3car.com/vbulletin/rr-s...-download.html
The jpg showing the exact location of the buttons is in the download. It should already be in your hd folder in void.
Noticed the same problem with xport and rr today while setting up the speed and direction arrow in void. Thanks, I'll give it a try.
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 12-21-2007, 05:12 AM   #1989
man.. i love all these skins.... can't make up my mind which one to go with... I guess i am just gonna rotate the skins every week.. ^^ by the way.. setting everyting to all English solved my problems.. Thanks..
Old 12-21-2007, 06:51 AM   #1990
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
Thank LS
EDIT:
EDIT 2:
what i figured, seems the locate bug is still around. Ill talk to guino about it.
There are 2 Exectbl.ini files. One is local and one is global.
The local one is the one that comes with a skin, so all code that is in the local version will only work with that skin. The global one (inside RR root) works across all skins.
It is safe to delete the global file, only if you havnt edited it with your own stuff.
It is NOT safe to delete the local version. Its the glue that binds RR, my skin and my custom code together in a happy 3 way action.
in light of the locate issues lingering around, i think i will set it up as an option that can be turned on/off and off by default.
If your location is off by 20 miles or so, you need to update your zips.dat file with more recent data. There is a thread around here somewhere with links to newer versions of this file.
i dont think that dll is needed by RoadRunner for a while now. I do not have it and everything still works.
YES AND NO
The code for searching is there, but the button is not visible to the user. If you disable ilist on the audio_browser.skin you will see the search button.
It was not intentional to remove the search feature from being accessed, but as it is now there is no way to search for anything. What i think ill do is post a new audio_browser.skin file that will split the playlist button in half and put search on the right side of that button. I may do this in the next 5 min or so, so look below or on the first page for the link.
see above
band button?
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 12-21-2007, 07:05 AM   #1991
SMKFree
ENABLE SEARCH function in the audio browser
unzip the attached file into the skins folder, overwrite the existing file.
Changes will be included in the next full update.
This will enable you to search for songs in the audio browser (LIBRARY) screen.
Next to the Playlist button you will now see a magnifying glass, clicking will bring up an OSK to input your search string.
mp3car live search
Old 12-21-2007, 07:42 AM   #1992
band button?
To change from FM to Am and back. But I found what I was looking for by just looking thought the files and got it working. Not sure what my problem is or was as I could get it to save one of the settings or invisible presets but not both. But working now. Thanks.
Old 12-21-2007, 07:48 AM   #1993
Now I just need to get some type of wireless skin working and I will be somewhat happy with my setup. I am very limited in my knowledge of coding but from some of the post on this site I am planing on giving it a try and piece something together I hope. Are there any future plans to have one for the skin?
Old 12-21-2007, 08:08 AM   #1994
greatwhite's Avatar
Wireless skin?
I don't see any wires..................
Leonardo Da Vinci
Old 12-21-2007, 08:33 AM   #1995
SMKFree
maybe.
probably.
sure why not.
mp3car live search
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
